Question about Microsoft Windows 98 for PC
I am looking for a user manual for a PC Partner motherboard I have but all I have is the Bios ID# to ID the model of the board. Can you help? The bios ID# is 07/20/1999-i810-NS366-6A69MV396-00.
    Scholar:
  • 96 Answers
They offer a free BIOS scan to identify your board at this link.
Hope this helps,
Nate P.
Posted on May 10, 2010
How can i identify my motherboard model
You can download Everest for a free evaluation. It will identify your motherboard and other components that make up your system
http://www.lavalys.com/products.php?ps=&page=11&dlid=35&lang=en
Please rate this solution. Thanks.
Apr 04, 2010 | Computers & Internet
Bios and Hdd id password protected . i want to
You should be able to clear these passwords by removing the BIOS backup battery.
You will have to take the laptop apart to access the system board.
Remove the screws from the bottom of the laptop (checking under bumpers)
You should see a flat-cell or plastic-coated series of flat-cells with a two wire cable going to the system board.
Apr 14, 2009 | Acer Aspire 4315 Notebook
Motherboard crash bios
1st remove ur mother board battery and clear cmos and press reset when machine start then shut down and change a new battery and fixd cmos. i hope ur problem will solv
Mar 17, 2009 | Computers & Internet
Foxconn P9657AB motherboard installation problem
You're Foxconn board uses the Award bios.
The long beeps you are hearing are telling you there is a problem with you're memory.
You're pic does not look like the Foxconn P9657AB-8EKRS2H MB as shown in the user manual. Found on This link.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000297
The pic on Foxconn's site does but not the manual listed.
The motherboard uses four 240-pin slots with 1.8V for DDR2 memory only.
(Question? Did you're ECS MB use DDR2 memory)?
If you have more than 1 DIMM installed remove all but 1.
Move the DIMM into the closest slot next to the CPU.
Boot the PC & check for beeps. If still presant move the DIMM to the next slot & try again. Continue this through all four slots. Than try another DIMM. If the mother board continues to beep as mentioned than call Foxconn. (There is a bios update mentioned below for memory).
The CPU may come into question. (It’s revision). You may have to call Foxconn for this information. (580-272-0035). They do not place this information in their user manual. Most users have to call. The rev of the CPU may conflick with the memory causing you to receive the bios beeps. (I have had to return 2 boards for this reason). I picked an Asus board over Foxconn.
I have come across this with Foxconn motherboards these past two years. Suggest you update you’re bios. Foxconn has a revision dated, 3-28-2008 for memory before you call. After bios update test the memory again for beeps. Still there? Return the board is my suggestion.
It’s a guess that the red led will go away after the memory issue has been addressed. Normally there is a green led on most motherboards. This means standby. The board has power connected. I could not find any reference in the user manual * .pdf, for R450.
Good Luck ninjo61!
Mike
Jun 20, 2008 | Foxconn P9657AA-8KS2H Motherboard
Re:hp compaq presario
Watch the computer as it boots.
The manufacture's name and motherboard model might be displayed as the BIOS goes through its post routine.
Use the Pause Key to freeze the screen (and any key to restart it).
Download and run CT BIOS.
This utility may grab the manufacturer's info from the BIOS. In the case of my BIOS, it listed the manufacturer's web site URL among other things.
Visit Wim's Bios Page for help identifying the board with BIOS numbers.
Some boards just may have an FCC ID number on the board/slot, in the motherboard book, or elsewhere on the computer if the same manufacturer made more than just the motherboard.
That number can usually be matched to the manufacture's name, etc. using the FCC data base at: http://www.fcc.gov/oet/fccid/.
Use that info to find the manufacturer with an Internet search engine.
This is also useful for finding the manufacturer of expansion boards, etc.
Other motherboards may just have the model number of the board on them. Run this number through some of the Internet search engines.
Jun 15, 2008 | HP Compaq Presario v3000z Notebook
Motherboard
Are you looking for this. (click the link). Foxconn.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000189
Manual for MS-7091
http://217.110.237.67/Manuals/Medion%208383XL%20mit%20MS-7091.pdf
If I can be of more service, just post back & let me know how thing go.
Good Luck!
Mike
Apr 25, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
Main board dead
is the switch ok? Clean your Motherboard for dust too. CORRUPTED BIOS Reprogramming the BIOS depends on your motherboard Model. It should correspond to your BIOS Model. Download the Motherboard's BIOS file usually in a Zip file then the contents are .bin files. Then use the BIOS manufacturer's EPROM Programming tool. Which usually comes with a user manual or guide on how to's. Just follow its examples. Hope this helps ======================= If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 21, 2007 | MSI 915G Combo-FR Motherboard
Microsoft Windows 98 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
