Question about John Deere Tractor Side Screen 1050,1520,2020,2030
How much hydraulic fluid is needed in a 1958 John Deere 730 LP tractor. I paid to have a front loader installed on it about five years ago and it worked then, but then I didn?t use the tractor for over 3 years. Now I?m trying to use it and put about 3 gallons of hydraulic fluid in it in the hole located by the transmission shifter. Everything works except for the front loader. I saw that there is a cap on the top left side of the loader but I?m not sure if I have to also put hydraulic fluid in there or what else could be the problem with the front loader not working?
  • 468 Answers
The loader that you have has its own reservoir. You should see 2 hydraulic lines going more than likely to the front of your tractor, where a seperate hydraulic pump runs the loader; this will verify this. That cap you're talking about is indeed the filling point, and most loaders hold around 5 gallons. Without knowing exactly what kind of loader you have on there, it's hard to say.
Posted on May 10, 2010
My john deere 4200 hst tractor quit moving,power steering quit,frt loader quit all at once fluid level is ok
hydraulic pump problem
check drive connection to the pump
check input line to the pump has no air leaks and sucking air
Oct 25, 2016 | John Deere Garden
John deere 332e skid steer loader
I would change hyd. fllter. Clean the hyd. screen
Jun 23, 2016 | John Deere Garden
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
Jan 09, 2016 | John Deere Garden
I have a 1020 john deere and there is hydrolic fluid in the oil put a new power steering pump on 2 years ago when it was doing the same thing Is there a ball or a setting pin that goes on the end of the...
power steering pump is mounted on front of engine where the tming gears are. Shaft leaks into crankase. Hydraulic fluid circulates through transmission, main system and power steering. Common problem with the 1020.
Apr 24, 2010 | John Deere 420,1020,2010,2020,2510,2520...
2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Mar 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
IJohn Deere whinning noise
Is the device that lowers or raises the loader a hydraulic piston type device, or more of a hydrostatic type device? Whining noises are not uncommon with hydrostatic devices...
Mar 26, 2009 | Garden
John Deere Tractor Side Screen 1050,1520,2020,2030 Logo
253 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
