Question about Eagle Fish Elite 480 Skimmer Transducer With Temp
Hi , I have a Cuda 300 and a skimmer
Hi , I have a Cuda 300 and a skimmer transducer HST WSU 200 kHz
It is brand new and works fien in simulation mode but in the real mode I get on the screen only a eronate variable depth measure, a temperature reading and a bateri vot reading. No bottom profile the creen is empty.
It is possible to teste the transducer only hanghing in the air or it must be ssunked in water
I belive that in the air it will indicate a wrong measure for the depht but it will be possible to see a bottom trace on the screen
Thank you
Elite-5HDI Screen is frozen and unit will not shut off.
Hi Thomas
I think your best bet here would be to contact Lowrance support directly I've included the link below.
-Steve
Contact Us
Mar 08, 2015 | Lowrance Elite-5 HDI with 83 200 kHz and...
Simulator will not turn off
go in your unit go to menu go to system click on simulator click off
Sep 08, 2012 | Eagle Cuda 300 Sonar Fish Finder ()
My depth finder keeps loseing the bottom and just flickers the last reading
Hi, if this happens when stationery check the angle of the transducer, if it only happens when moving check the height of the transducer also. Regards Phil
Jul 02, 2012 | Lowrance Lcx 38c Hd Fish Finder Gps (200...
We have a cuda 300, the simulator wont shut off?
To turn on/off the simulator:
1. Repeatedly press MENU until the SIMULATOR menu appears. Press ? ?
to turn it on or off.
2. Press PWR to clear the menu.
May 29, 2011 | Eagle Cuda 300 Compact Fishfinder
How do you turn off automatic sonar simulation
1. Repeatedly press MENU until the SIMULATOR menu appears. Press ↑ ↓ to turn it on or off.
Simulator is after 'contrast' and before 'Language' in the list.
Sep 05, 2010 | Eagle Cuda 300 Compact Fishfinder
Have a Cuda 300 It shows 62 ft on water or land. This is my second new unit, the first one did the same thing. Tried factory reset.
The transducer for the unit might have junked out, or else you have a floor model that is programed for that depth. lol
Apr 14, 2010 | Eagle Cuda 242 Fishfinder
99% of the time when i power unit up, it gets stuck on 54.8 feet
After testing everything out, I went out and bought the new Eagle Cuda 300 model. I hooked that up and made sure it worked, then tried the Cuda 242 unit on the new transducer. That did it, it worked fine. The problem was a bad transducer. Might have been that -30 deg weather last winter, I'm taking that off the boat this winter. Transducer cost about $50-$60, new Cuda 300 cost about $80.
Mar 22, 2009 | Eagle Cuda 242 Fishfinder
Eagle Cuda 128 does not read water depth
Hi Chris, Did you get a fix for this issue? My Dad's Eagle Cuda 128 is also having the same problem - constant reading of 60ft. I'd love to hear if you have a solution. Many thanks,
Mar 14, 2009 | Eagle Boating
Eagle Fish Elite 480 Skimmer Transducer With Temp Logo
49 people viewed this question
Top Eagle Boating Experts
Steve
Steve
ray gallant
Al Toledo
Are you an Eagle Boating Expert? Answer questions, earn points and help others
