Question about Vulcan ERD85 Deep Fryer
The oil realeser got clogged or jammed up with something tried with my hands and with slim rod to unclogged didnt work at all plz help me out need to serve my customer
    Problem Solver:
  • 11 Answers
Reverse Flush the unit with a good pressure water hose. Rod should have worked, but not always. Find a rod of larger diameter that fits ball **** hole.
Posted on May 13, 2010
When you turn the unit on it hums, but doesn't build any pressure
it could be your compressor might be laxing slow to engage!!
sometimes they need a boost! check w your local ac service provider!
best of luck!!!
Jun 13, 2012 | Craftsman 3 gal. Air Compressor, 1 hp,...
How do I unclog my shredder? The papers keep getting stuck in the teeth and the shredder keeps stopping. I've tried pulling it out with my hands but it's not working. Bummer!
Have you ever "oiled" the cutting blades...all cross-cut shredders should be oiled regularly otherwise they clog up with the paper and debris generated by the cutting of the paper...the oil helps feed this material on thro into the shredding bin.
Mar 27, 2011 | Royal VF1012mx Shredder
JAM
Hello there Ok this is just a try, you may have to help this by turning the rollers by hand to feed it trough.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 13, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Rubbing and squealing sounds/paper jams
Hello there Just try this there may be a bit of paper there.
You may not see a paper jam.
Mar 10, 2010 | HP Photosmart C8180 InkJet Printer
Im keep get the cartridge jam alert and it dosnt tell me how 2 fix it the dosnt look like these a jam could u plz tell me how i can fix it
Hello there
Mar 02, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink Leaking into bottom of printer and the paper keeps jamming up on the right hand side above the ink leak.
Hello there
Mar 01, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper jams but doesn't go anywhere!
Hello there
Jul 03, 2009 | Canon PIXMA iP1600 Printer
Canon mp160 jamming paper
Apr 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a Dirt Devil Vacuum that won't start up anymore. It was working, but then it stopped. The tube got clogged up. Now the tube is unclogged and empty and it won't turn back on. It's also hot on the...
Some of the Dirt Devils have a reset button on the back, near the bottom. But if the it is getting hot on the bottom, that may mean the motor is trying to run but can't. Maybe something has jammed it. You would have to disasemble it to find out.
Mar 05, 2008 | Vacuums
How to fix a stuck shredder
Go to your local hardware store, and pick up a quart of 3 in 1 oil, shredder oil or some other light weight oil. (With the shredder in the off position or unplugged). Use a couple of ounces and Pour the oil over the paper that is jammed in the shredder. Use enough oil so it saturated the jammed paper. Wait about 10 - 15 minutes so the oil really soaks into the paper. Don't go crazy with the oil, and keep in mind what goes in, must come out. If you pour too much oil in the shredder, the exess oil will drip out. Don't worry about having oil in the shredder blade, this will help lubricated the teeth, and it will actually make your shredder blades last longer.
Now try to turn your shredder on after the oil has soaked into the paper for 10-15 minutes. Hopefully, the paper that is stuck has gotten softer, and then it should pass the paper. If it still doesnt work, then, try some more oil on the paper, and then wait and then turn the shredder to the forward, and then reverse mode, and then back and forth.
Hopefully your shredder will be unclogged by this time.
Hope this helps.
Good luck.
Feb 04, 2008 | Office Equipment & Supplies
Vulcan ERD85 Deep Fryer Logo
117 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
