Question about Dryers
Dryer makes squeeking sound when running
I have a 12 1/2 year old dryer that makes squeaking sound when running. When it first started it only squeaked for a few minutes now it squeaks almost the entire drying cycle.
  • 88 Answers
You need to replace the rollers an idler an belt,,,this will stop your noises...call if need help...
Posted on May 10, 2010
Dryer is squeeking
You should be able to open the cabinet and identify the source of the squeak. If the dryer is several years old, the belt could be in need of replacement.
Mar 06, 2014 | Whirlpool Cabrio WED8000BW 29" Electric...
How do I fix the squeaking when the dryer starts up in a fridiadare gallery dryer with model number 341as1 and serial number x021308125
It quits down after it runs awhile?
Your Belt and Rollers are getting old. Live with the short term Squeek or replace the Belt and Rollers and idler
Dec 15, 2013 | Frigidaire GLER341A Electric Dryer
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Jan 01, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
I have a 5 yr old KitchenAid front load dry that just started to make loud squeaking sound when running or even if I turn the drum when the dry is off. Drys clothing good, just making noise and want to...
You will need to check the tub roller wheels. This is a common noise when the wheel bearings start to ware down. They are not expensive, and you should be able to do this yourself. Good Luck Friend.
Feb 22, 2018 | KitchenAid KEHS02R Electric Dryer
Model FDE546RES1 Drum squeeking with every turn. Can't dry clothes when my son is trying to sleep. You can hear it through the whole house. Is it better to have it repaired or get a new one since it is...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 13, 2010 | Dryers
Dryer just started making squeeking noise and then seems to overheat and won't run again until it cools down.
heatman101
dfgshs
Sep 29, 2010 | Kenmore 63942 Dryer
The barrel makes a rubbing squeeking sound as it turns. Sometimes it is really loud and other times it doesn't make the noise.
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up
May 20, 2010 | Dryers
Dryer squeaks when turned on, recently is getting louder and louder as drum is turning. Is it worth getting fixed, it's six years old
The squeek is probably the front 'bearing' which is generally made of felt.
Pop the top, pull off the front, remove the drum. Clean the felt or replace it.
A better alternative is to turn up the radio so you cant hear the squeek.
If you do go to this trouble, you may want to replace the belt while you have it apart.
Personally, id let it squeek. It may be annoying but on the ohter hand, you know when it is operating and when it is finished now.
Oct 21, 2009 | Dryers
My series 80 dryer squeaks
do not lubricate anything in a dryer you will damage .locate the the squeek if it is coming from the rear of the unit most likly need to replace the drum support or wheels if its intermittant and has a squeek squeeek noise that either gets worse or goes away when the dryer heats up the tensioner pully or the moter berrings are bad
Aug 10, 2009 | Dryers
Squeak
It is proably the center bearing in the back of the drum, especially if it at least a few years old. It can be replaced by you if you are very handy.
Dec 22, 2007 | GE DBL333EA Electric Dryer
Dryers Logo
354 people viewed this question
Top Dryers Experts
