Question about InFocus IN36 Projector
Projector Works for one minute then the lamp goes out.
When the lamp goes out, the wrench lights up.
InFocus IN34
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
Sounds like a fan not working or a bad power supply/ballast. If it is a fan that is not working it will cause it to shut down. That would either be a bad fan or bad main board. But, if all fans are working, most likely it's the power supply/ballast.
Posted on May 11, 2010
C185 all light on what is the porblem
Make sure your lamp cover door is closed all of the way. Try reseating the lamp and then re-closing the access door.
http://www.projectorcentral.com/pdf/projector_manual_3354.pdf
Here is the manual, see if the lights match up.
Aug 30, 2016 | InFocus SP-LAMP-019 Lamp for IN32, IN34,...
Does not turn on all 4 lights lit up on face of unit
Most likely the lamp is burned out. Check the lamp and if it is bad, replace it (unplug projector while you replace the lamp). If it turns on, reset the lamp counter and you're all done!
Be sure to weigh the cost of the new lamp vs replacing this 6-8 year old projector!
Jul 01, 2014 | InFocus Work Big IN34 DLP Projector
Infocus IN34 all indicator lights on
Power Supply problem. Check for "Bulged" capacitors in the output circuit ( 5 parts 470uf @ 16VDC). Also an indication of this problem is to remove the lamp cover and plug in the AC power cord. If the fans run slow....this is the problem.
Aug 29, 2011 | InFocus Work Big IN34 DLP Projector
How to adjust lamp light source projector lamp
Could you please explain a bit more what the problem is.
Apr 06, 2011 | InFocus Work Big IN34 DLP Projector
It says we need a bulb. Serial # ATMV 28 0276,
sp-lamp-019, but good luck finding one under $500.
Dec 14, 2009 | InFocus ScreenPlay 4805 Multimedia...
The tv shuts down and an orange light flashes
if it's the lamp led that is orange, turn off the projector for a minute and try it again. if the lamp goes out and the orange led comes on again, replace the lamp and reset the lamp timer.
Jul 25, 2009 | InFocus X10 DLP Front Projector 1080p DLP...
Bought a replacement lamp for Infocus SP7205. Lamp works fine. But the fan intermittently will come on at high speed for 5 seconds, then turn off, then do it again a minute or two later. Slightly...
I seen this problem with lamps that are not from infocus. I would recommend to replace it with the old lamp fan. if you still have it. I'm not sure why it does this.
Apr 25, 2009 | InFocus Lamp Projector Lamp for LP650,...
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
InFocus LP630
get it from projectordoctor.com or from infocus. do not get cheap replacements. you get what you pay for.
Sep 18, 2007 | 3M Projector lamp Projector Lamp
InFocus IN36 Projector Logo
383 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
