Question about Cameras
How do I transfer video from Adobe Premiere CS4 to a Canon GL2 Camcorder?
  • 1 more comment
  • bgreer7190 May 10, 2010
    Gentleman, I know how to capture a video file from my Canon GL2. Now that I have it captured and edited I want to load it back on my Camcorder on a new blank tape (that is the edited and titled project) using Adobe Premiere Cs4. This program has a load to tape function. When I try to use this function the camcorder reconize the program command and it start recording but, nothing is being recorded. I get a blank tape output. I am using the 1394 port (firewire) on my computer and camcorder.
    WT
    Shane, please read my last message to you and see what I am requesting. The solution you gave me was one that will allow me to export my video from my camcorder to my computer. I want to go from my computer to my camcorder.
    WT
    Shane do you have a solution to my problem?
    WT
  • Cameras Master
  • 4,924 Answers
Http://tv.adobe.com/watch/learn-premiere-pro-cs4/getting-started-13-exporting-your-project/
I am going to explain the main steps for doing this ..and I just linked the fist step that you have to do ..in order to be able to do that ..here on this link you will find a video that explains the exact way to export a video file in your computer as a video file..
The second step will be to make sure that the file you actually export will be readable in your camcorder...if you need it to be viewed and probably used in several future actions you want to make with your camera ..
For that you need a video file that was actually filmed with the camera and never changed with anything so you can take a look at the properties and see what framerate ..and bitrate is using (of course what format ::avi...mpeg4..divx..)This is esential cause when you will transfer the video on the camera it have to be the exact bitrate and framerate and format that your camera supports..so that it will read it ..or ...with the values a little smaller ..
In that link you will see how to export the movie in the format you need ..and if you do not have the option for the format you need on the camera ...you will have to use a video converter ..like this one ..
http://www.any-video-converter.com/products/for_video_free/
this converter will actually do what your exporter from he adobe does..but probably will complete the range of formats..with avi..(this one I didnt sow on exporter..and that 's why I mentioned...it ..cause I suspect the camera uses avi format to shoot and export )
When you finished editing you movie ...and convert it in the format you match with the camera ones...including the frame-rate and bit rate ..(in the converter you have the possibility in the right side to choose format and values)..all you need is the camera hooked on the computer ..and the driver on ..so you will find the camera in the my computer folder ..or the card from the camera ..like a removable memory device ..and just drag or copy/paste the movie in the folder near the other videos filmed and already in the memory ..(to be sure they are in the right place )or use the manager that you import with ..but in the other way around..
If the format is the right one and the bit and frame rate match ..the camera should recognize them and play them back..
I will link here the other videos for your program ...explained in the same way ...to be able to learn all that your adobe premiere can do ...
http://tv.adobe.com/show/learn-premiere-pro-cs4/
Posted on May 11, 2010
  • 668 Answers
Follow the steps to solve your problem
1.Use the LCD screen on the camcorder and rewind to the start of the footage
2. Put it into 'play' or 'VCR' mode
3. Hook it up to the computer with it plugged in and the power on
4. Open Premere Pro and create a DV-NTSC project
5. Name the project what you want and click OK
6. In Premiere Pro go File > Capture; this will start a capture dialog box.
7. At the top, name the clip something descriptive also, put it somewhere on you computer where you can find it later. The reason is these files are pretty big (14 GB / hour)
8. At the bottom right are the buttons to start the tape capture
9. When capturing, the camcorder will play the tape in real time 10. When done. end the capture.
11. The file will appear in the left upper side of the PP screen; drag and drop it down to the bottom 'timeline' sequence.
12. Here, you will trim, add titles and prepare for export
Hope this helps .
Posted on May 10, 2010
Tip
Edit flip camera files with Premiere Pro
Overview of Adobe Premiere and Flip Camcorder:
Adobe Premiere Pro is one professional, real-time,timeline based video editing software application. Flip cameras store their video in a high-definition MP4 format. However, you will likely not be able to edit the video by importing it into Premiere Pro without converting it. The best solution to make Flip Slidehd/Ultra/Mino camcorder mp4 videos edit on Adobe Premiere Pro version 1.0, 1.5, 2.0, CS3, CS4 and CS5.
Best solution - Flip to Adobe Premiere Converter is a magical app for Premiere Pro fans to import and edit flip video in Premiere Pro AVI, MOV, MPEG (MPE,MPG), AIFF, MP3, WAV, WMA, etc. Flip Video to Adobe Premiere Converter easily convert flip camera videos to Premiere Pro with no quality loss. Under the help of the Converter, you can import the output video and edit it in Premiere Pro with ease, no matter which Adobe Premiere Pro version you possess. Furthermore, it can also support you to import Flip video to Windows Movie Maker/WMM.
Guide to import/edit Flip videos in Premiere Pro with several simple steps.
Part One: Convert Flip Video to Adobe Premiere Pro Format AVI, MOV, MPEG etc.
Step 1: Load files
After download and run Flip to Adobe Premiere Converter, Press "Add File" to import flip .mp4 video to the program.
Step 2: Select the output format and its destination
Select the output format in the drop-down list of "Profile", like DV-AVI. Specify its destination when click the "Browse" button.
Step 3: Click "Convert" button to start converting flip camera video to target format.
After successfully convert Flip to Premiere Pro supporting formats, you can import the video to Adobe Premiere.
Part Two: How to import output video clips and other files into Adobe Premiere Pro?
Adobe Premiere accepts you to import a single video clip, multiple clips, or an entire folder of clips. You can also import a variety of audio and still image files, including sequences of images and layered Photoshop files.
Select File > Import from the main menu.
Tip1: To import a single file: Locate and select the file, then click Open.
Tip2: To import multiple files: Hold down the Control key to select multiple files, then click Open.
Tip3: To import a folder of files: Locate and select the folder you want to import, then click Folder. A new bin is created in the Project window, containing the contents of the folder.
Tip4: You can also import files and folders by dragging them from "Finder" into the Project panel.
Notes:
1.The pixel size of your clip cannot exceed 4000 x 4000 pixels.
2.If your imported clip appears distorted or stretched, its pixel aspect ratio may be set incorrectly.
Well Done. Enjoy Flip video editing in Adobe Premiere Pro with Flip to Adobe Premiere Converter.
Related: Flip camera review: The best flip camera after Flip Ultra, Flip Mino, Flip Ultra HD and Flip Mino HD.
on Aug 11, 2010 | Computers & Internet
Tip
Edit Flip Camera File with Premiere Pro
Premiere Converteris a magical app for Premiere Pro fans to import and edit flip video in Premiere Pro AVI, MOV, MPEG
Step 1: Load files
Notes:
on Aug 10, 2010 | Computers & Internet
Canon hv30 is't being recognized on my vista computer
You may have used a different USB port on the computer. Try a different one.
Generally, any USB port would work, except that some devices create a "Virtual USB" connection that is configured with a specific USB port.
Let us know if this helped...
Gort007
Sep 16, 2009 | Canon VIXIA HV30 DV Camcorder
I try to install adobe premiere pro cs4 with dvd but when i click on setup.exe, it shows me a box with checking system profile but it runs for just 90% and it stop it. and even it can't close.
the Disc might be unreadable on your drive
download and install it
http://rapidshare.com/files/157965627/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part01.rar
http://rapidshare.com/files/157968716/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part02.rar
http://rapidshare.com/files/157972380/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part03.rar
http://rapidshare.com/files/157975643/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part04.rar
http://rapidshare.com/files/157978110/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part05.rar
http://rapidshare.com/files/157980298/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part06.rar
http://rapidshare.com/files/157981994/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part07.rar
http://rapidshare.com/files/157983531/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part08.rar
http://rapidshare.com/files/157985026/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part09.rar
Jul 26, 2009 | Adobe Premiere Pro CS4 for PC
Tip
Overview of Adobe Premiere and Flip Camcorder: Adobe Premiere Pro is one professional, real-time,timeline based video editing software application. Flip cameras store their video in a high-definition MP4 format. However, you will likely not be able to edit the video by importing it into Premiere Pro without converting it. The best solution to make Flip Slidehd/Ultra/Mino camcorder mp4 videos edit on Adobe Premiere Pro version 1.0, 1.5, 2.0, CS3, CS4 and CS5.
Best solution - Flip to Adobe Premiere Converter Flip to Adobe Premiere Converter is a magical app for Premiere Pro fans to import and edit flip video in Premiere Pro AVI, MOV, MPEG (MPE,MPG), AIFF, MP3, WAV, WMA, etc. Flip Video to Adobe Premiere Converter easily convert flip camera videos to Premiere Pro with no quality loss. Under the help of the Converter, you can import the output video and edit it in Premiere Pro with ease, no matter which Adobe Premiere Pro version you possess. Furthermore, it can also support you to import Flip video to Windows Movie Maker/WMM.
Part One: Convert Flip Video to Adobe Premiere Pro Format AVI, MOV, MPEG etc. Step 1: Load files
Part Two: How to import output video clips and other files into Adobe Premiere Pro? Adobe Premiere accepts you to import a single video clip, multiple clips, or an entire folder of clips. You can also import a variety of audio and still image files, including sequences of images and layered Photoshop files.
Why not download Flip Pro to have a try?
on Jul 20, 2010 | Cameras
Serial key for adobe premiere pro cs4
You can go to adobe.com and purchase that key for $799.00 US dollars. If you lost yours they will help you retrieve your key.
Jun 23, 2009 | Adobe Premiere Pro CS4 Upgrade Version for...
Matrox rt.2x and adobe premiere cs4
not found in RT.X100
· Adobe Creative Suite 4 Production Premium and Adobe Premiere Pro CS4 support
They cannot work together unfortunally
Jan 26, 2009 | Matrox RT.X 100 (RT.X100) Video Capture
I need to get the video from my canon gl2 to my pc (free sofware0?
You cannot use USB to transfer video, the USB is used to take pictures on/off among other inserts. You have to use the firewire to transfer any and all video.
Jun 05, 2008 | Canon GL2 Mini DV Digital Camcorder
Cameras Logo
21 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
