Question about Jenn-Air JES9800A Electric Kitchen Range
F3 Error Code on Jenn Air Pro Style Downdraft Oven - JDS9861AAP
I have a Jenn Air Downdraft pro-style oven. The part number is: JD9861AAP. Recently when heating, the oven would give the F1 error code indicating the temp sensor. I pulled the sensor and the resistance readings were a little low at room temp (900 ohms, should be 1100 ohms) so I replaced it. I also removed the plastic connector and attached the leads with wire nuts. Now I am getting an F3 error code when heating the ovne. The cook-top which is gas is working fine. What does this mean and what needs to be replaced? Thanks in advance for any assistance.
Chris
  • 2 more comments
  • Christopher Cooke Mar 28, 2008
    The probe is new and wired in securely.
  • Anonymous Aug 06, 2008
    I get an F-7 code. Sometimes the oven works, sometimes it doesn't
  • keiththomas Aug 15, 2008
    I've thrown the breaker to it hoping it just needed for the circuit to clear but when I turn the breaker back on it shows an F3 code. I had just finished using the cleaning mode in my oven when this problem occurred.
    Is there something I can do myself or will I have to call in a repair man?
    Thanks
    Sandie from Arkansas
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    According to the information I have on Jenn-Air, F3 indicates a open or shorted oven temperature sensor. Double check the probe and wiring harness.
informatica
  • 1114 Answers
SOURCE: Finalization
Hi Zvika, when you play back the DVD on your home player you can choose to have a "menu" that will display when you load the disk to enable you to select which part of the recording you wish to view. It is like on a commercial DVD where you can choose the scene you would like to see. These menus are available in different "styles", as you see in the style options you can have different numbers of mini "windows" with a snapshot of what the scene you recorded was. If you have recorded many short movies then it is a good idea to have many "windows" to choose, or perhaps it is only one long recording you made in which case you may not want a menu (style) at all! In the example in the manual "Style 1" has 6 "windows" for you to choose when the DVD is played back. I hope this make some sense as it is difficult to explain unless you have done it before! Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 22, 2007
  • 1141 Answers
SOURCE: old style citizen wr100 blue angles watch how do you set it
Here you go this is a lin to a pdf that should help you out
http://www.citizenwatch.co.jp/support/pdf/c650/e.pdf
Enjoy your watch
Posted on Nov 15, 2007
SOURCE: Convection oven not working properly???
Model #JMW9527CAQ convection oven has no display visible.Started out very dim and eventually went to no display on the front display .
Posted on Jan 12, 2008
Oceti
  • 51 Answers
SOURCE: Jenn-Air Gas Range
F1 is a bad power relay board.
F8 is a shorted meat probe alarm (probe jack or the harness to the probe jack)
Posted on Jan 18, 2008
Eddie Rentas
  • 59 Answers
SOURCE: downdraft vent on jenn air cooktop
Hello
Just get a dryer vent tube the flexible ones and some aluminum tape and that will do it, I had the same problem and thats how the gas company told me to do it and it works excelent.
Eddie Rentas
Tupper Lake NY
Posted on Jul 26, 2008
Top electric oven will show an F3 error after being turned on and will beep. Botton oven works fine. Jenn Air electric oven model JJW927AAW. Serial number 11993640WO
HI thanks for your question.. code F3 says to replace the oven sensor, located in the oven. top left corner. Replace the oven sensor. Thanks
Dec 17, 2010 | Jenn-Air Ovens
My Jenn Air oven digital display went out, what I
Apr 10, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
Error message on JJW9530DDS Jenn-air wall oven is 4d21
no/low cooling fan rotation (No RPM) single cavity or upper oven - check connection at cooling fan if ok, replace blower - DO NOT REPLACE CONTROL
Mar 06, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
Beeping and displaying F1. Press stop and 30 seconds later it starts again.
too high temp F1 fault code its either the keypad, or the control board.if the thermostat or oven sensor is bad,it could have got the keypad or control board too hot, and caused the F1
Aug 30, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
How do you get a Jenn air oven out of the wall???
The JennAir website should have the installation manual for download. Go there, type on your model number, and it should come up.
Sometimes these ovens just get "stuck" in place, and take some easy levering to break free, or to help you find other fasteners.
Jan 15, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
Jenn-Air JES9800A Electric Kitchen Range Logo
122 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De GO PATS
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
