Question about Nikon Coolpix S210 Digital Camera
Will not take picture
When I turn the camera on, it says "Memory card is write protected". And when I look at the pictures that I've taken recently, it will not let me delete them, or edit them.
    Guru:
  • 1,705 Answers
1) Take the card out of the camera, check about half way up on the left hand side there may be a small sliding notch, slide it to wrtie enable and re-incert it in your camera.
2) If 1 didn't work, there's also a photo protect option in you camer menu, ensure that is also off.
Posted on May 10, 2010
Protected momery card
If you did not remove the memory card before, it could be there is a bad contact on the memory card or in the camera. It also could mean your card is full. (you should delete some pictures) First put the pictures on the computer or another memory, like external hard drive, or somewhere in the cloud.
If you recently had your memory card out, it could be you accidentally switched it to lock. See the picture how the switch on the SD card should be. The 64GB card is unlocked, the 32GB card is locked. Make sure your switch is up like on the picture.58575d9b-f54f-431e-b178-18861b326f77.jpg
Jan 26, 2014 | FUJIFILM FinePix JV200 / JV205 Digital...
Camera comes on, says card is locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 14, 2013 | Casio Exilim EX-S5 Digital Camera
My DSC W90 is 4 years old -- I love it -- and I've never had problem -- with it until now. It rotates pictures on its own! When I view the pix that I've JUST taken, they look fine. When I turn...
If you have an exceptional amount of pictures on your camera...This could be a simple problem solver? You need to remove some or all your of your pictures from your camera to create more memory and storage.
You have a couple of options
Save all your pictures to memory card, from the memory card save to your computer in a file or to a USB Flash Drive (Cruzer), or on a CD/DVD disk.
Or, install a new Memory card that has more Storage Capabilities.
You need to check your setting as to how the pictures are viewed and stored, it's possible you have your camera set to auto rotate and also auto set format...change these settings to manual!
Kind regards!
Sep 12, 2011 | Sony Cyber-Shot DSC-W5 Digital Camera
I've had the Samsung L200 with the same Panasonic 1GB memory card for the last 3 years and it's been great, but all of a sudden today it started saying 'memory full' after only taking a few...
The camera is telling you that the internal memory is full. To get your card to work, you must clear it. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, your card should work unless you formatted it in the computer, in which case you'll have to format (completely erases it) it in the camera.
Aug 21, 2011 | Samsung L200 Digital Camera
Screen reads "memory card is
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 24, 2011 | Nikon COOLPIX L18 Digital Camera
I purchases a vivitar vivicam 8025. Unfortunately the instructions got thrown away. I've only taken a few pics and the camera says "memory full insert sd memory card to transfer and take more...
You can download the manual from the manufacturer's web site at
http://www.vivitar.com/files_products/13/VC8025%20User%20Manual.pdf
The camera needs a memory card in order to save pictures. You can take pictures without one and view them on the screen, but those pictures are lost when you turn the camera off.
Jun 16, 2011 | Vivitar ViviCam 8025 Digital Camera
I turn on my camera and it says "memory card is write protected" what does that mean? because it won't let me take any pictures i can view pictures I've already taken but i can't take pictures. How can I...
It means just that, you can't write new files (take pictures) while its in that state.
Take the card out, and check the left hand side of the card. You should see a small notch that can be moved betwee "Write protect" and "Write Enable".
slide it to the "Write Enable" position.
Jul 01, 2010 | Nikon COOLPIX L18 Digital Camera
Camera does not show taken ( saved) pictures
problem is in memory card...i think. try with cleaning memory card contacts. use pure alcohol and small piece of cotton to clean dust or other dirt. if this not help, try some card reader to transfer images from camera to PC. try also with some other camera. it's possible memory card is damaged and you can't do nothing. try reinstall nikon software on your PC.
Feb 19, 2009 | Nikon Coolpix L15 Digital Camera
Memory card is stopping my camera working
Check the memore card. The write protect switch has been moved.
Jan 04, 2009 | Olympus FE-210 Digital Camera
Vivicam 5386 copying images to memory card
To copy pictures from memory to your memory card turn your camera on and press the button above the menu button. This will start showing the pictures already on your memory card. Next, press menu and the down arrow. This down arrow is located on the round button with the "OK" in the center. Your choices should be DELETE, SLIDE SHOW, PROTECT, QUALITY CHANGE, RESIZE, and the one that you want,COPY TO CARD. Press OK and the camera will copy pictures from internal memory to the memory card. This information is on page EN-62 and EN-63. I know that this works because I was testing the information as I was typing it!
Oct 02, 2007 | Vivitar ViviCam 5386 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
50 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
