Question about John Deere Tractor Side Screen 1050,1520,2020,2030
I have a 1958 John Deere 730 LP tractor that I don?t know much about. I paid to have a front loader installed on it about five years ago and it worked then, but then I didn?t use the tractor for over 3 years. Now I?m trying to use it and put about 3 gallons of hydraulic fluid in it in the hole located by the transmission shifter. Everything works except for the front loader. I saw that there is a cap on the top left side of the loader but I?m not sure if I have to also put hydraulic fluid in there or what else could be the problem with the front loader not working?
  • girdthysword May 10, 2010
    I did check the lines. There is a screw on cap on the top left side of the Duall loader. Does the frame of the loader also require hydraulic fluid in order to work the loader, since the hydraulics on the back of the tractor seem to work just fine? It worked for a second when I tried to use it then it quit. There are no broken hydraulic lines. I checked them.
    This was good information but it did not answer the question I asked because I keep asking if there is hydraulic fluid needed to be put into the actual loader that I had installed which seems to have some sort of fill area with a cap on the front left side of this Duall Loader. All the rest of the hydraulics work on the back of the tractor. This was my question. I did previously check all the lines and electrical already.
  • 19,396 Answers
Hi.
Check and clean linkage.
Ensure that you have connected the hoses in the right ports. There should be bucket hoses going to one valve and boom hoses going to the second valve.
Inspect the controls and the wiring from controls.
If the joystick looks loose, then it may be broken.
If the front loader does not try to move, inspect first the controls and all electrical wiring. Wiring are tested using a voltmeter (Electrical Circuit Tester Pen for Car Auto).
If wiring is OK, inspect the high pressure lines going from the pump to the valve assembly. Ensure that there is no blockage or leaks. The pump is probably located in front of the motor, I do not have schematics for this model.
If that does not fix the problem, then either cylinder or valve may be faulty. A faulty cylinder is far more common than a valve problem.
Regards.
Posted on May 10, 2010
I need a drive belt routing picture for a John Deere x300 mower
For a routing or installation diagram, contact John Deere directly.
Sep 11, 2017 | John Deere Garden
730 john deere crankcase full of gas after sitting 2 years what repairs
make sure it hasn't damaged the crankcase seal on bottom drain and replace the oil. it is full of gas because the carburetor failed. put a rebuild kit in the carb. (needle and seat). should stop the gas from leaking in. should be fine
Jul 28, 2016 | John Deere Garden
What year is a john deere 440c serial number t4467jdpo?
To find the 440C Serial Numbers Location: Its on the Instrument panel on the diesel models and on the clutch housing on the gas models.
1958: 440001 - 444127
1959: 444128 - 453872
1960: 453873 - Final: 461929
Jun 24, 2014 | John Deere Garden
John deere 1020 front loader stuck in raised position will not dump or go down with gravity
Full full Up... hmmm sounds like the Cylinders are slightly c ocked and bound up.
Apr 05, 2014 | John Deere 420,1020,2010,2020,2510,2520...
How do I find the model or year on 38" John Deere with no hood?
A ten year old mower that probably cost about $1500.00 at least twn years ago that has not been taken care of is not worth much.
John Deere is a good name as in Kohler. How much is it worth? It is currently worth what you paid for it, you just made it worth that much.
Mar 08, 2010 | Garden
2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Mar 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Tractor Side Screen 1050,1520,2020,2030 Logo
90 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
