Question about Trampolines Hedstrom 8' Ft Round Trampoline Enclosure
Manual instructions hedstrom #9-844c tramploine
Manual instructions hedstrom #9-844c trampoline
FoxhunterTrampoiline setup instructions
Deano, could not find your exact trampoline, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 30, 2016 | Sport & Outdoor - Others
Trampoline Set Up Instructions
Connect all the poles together in a circle and atach teh trampoline mat to the circle.
Sep 13, 2013 | Sport & Outdoor - Others
I want to buy a trampoline for our backyard but there is only one place I can put it and the ground is slightly on a slope. Is this dangerous? Can I even put a trampoline on uneven ground?
It is obviously a preference to put a trampoline on a level ground; however this may not always be the case for some people. If your yard is slightly sloped or uneven there are things you can do to make it safer for a trampoline. Take a look at the following instruction guide:
http://www.ehow.com/how_7761632_put-trampoline-slope.html
Jul 31, 2012 | Sport & Outdoor - Others
I have a Hedstrom crib model #34017X but all the screws are missing. Do you know what sizes and types I will need to put this back together? Thank you, kathleen Sterling, kasterling1@comcast.net
Hello Kathleen,
You can contact us directly at parts@productsamerica.com and one of our friendly customer service representatives will be happy to help you with your Hedstrom hardware.
Nov 10, 2011 | Baby Gear
Need instructions for 8ft plum trampoline
Instuctiones on how to put up a plum trampoline as we have lost the instructiones 8foot
Jul 18, 2010 | Toys
How to take a household trampoline apart
When I assembled my 14ft trampoline a few weeks ago the instruction were to attach springs at the 12 and 6 oclock positions then 3 and 9, then symetrically around the perimeter. Disassembly would be the reverse. Start by removing the spring at 12 then 6 oclock, then 3 then 9 oclock. You will always remove the spring 180 degrees away from the last spring removed. This means you'll be running around the trampoline many times but I think the idea is to remove tension evenly so that the mat isn't damaged. Once the springs and mat are removed I expect the frame will easily disassemble. My framo was like curved piping that fit together and is only held in place by spring tension. Hope this helps.
Jun 13, 2010 | Trampolines BQC1620
I need an instruction manual for my 14ft trampoline with enclosed netting
May I get the make and model # of the trmpoline to help you more.
Apr 28, 2010 | Trampolines BQC1620
I did not recive instruction with my tramploine and do not know how to put it together
hi,
how do you put a 10ft trampoline together i put it down and now i am struggling to put it up,could you please tell me how to in a easy step instructions.
thanks,
from sian
Jun 26, 2009 | Trampolines BQSM20DL
Trampoline net
Hope this helps. The trampoline net will either have a sleeve for flexible poles to form a ring at the top or there will be at least four obvious "loops" to hang from the poles. Then you need to sew the net to secure it to the mat/trampoline itself with rope. A good idea to buy new rope to do this as it wears with use. I have replaced my securing rope with "tie-down" rope from the sporting good department. The soft nylon kind seems to wear better. To sew: use a good knot to secure it to the underside of the trampoline (spring/Loop) then simple go through the net at the bottom skip a few holes come back through the net and go down around the bottom of a spring hold. repeat all the way around.
Apr 05, 2009 | Trampolines BQC1620
Trampolines Hedstrom 8' Ft Round Trampoline Enclosure Logo
345 people viewed this question
Top Trampolines Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a Trampolines Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
