Question about Samsung ML-3051N Laser Printer
Internal error ENPNIC_Drv.c 469 rip? anyone know the fix for this?
My nobis 9" tablet keeps popping up windows saying unfortunately blah blah has stopped working. i turned it off and turned it back on and now i can't even get the home screen. please help
Nobis 9 tablets are defective. Many, if not most, of them end up having bad internal memory. They might work for a week, a month or maybe even two months but, sooner or later, theminternal memory goes bad. When this happens you get the stopped working error messages and in many cases it will no longer boot up. Just Google, Nobis NBO9 stuck on go and you will see you aren't the only one who got ripped off when you bought this POS.
I know, I have one. I sent it in when the internal memory went bad. Cost me 20 bucks postage. They fixed it and sent it back. It worked about two weeks and the internal memory went bad again. Then they gave me the runaround and refused to issue me an RMA.
Stay away from anything sold by Bidwell that uses the Nobis brand. Better yet stay away from Bidwell period. They are rip off artists, IMO.
Apr 07, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
Problem with Juki DDL-5550N-7 Sewing Machine, Error Code E24
El Drv se refiere a la tarjeta interna que controla el motor, est? se encuentra da?ada.
Email: ingcegadan@gmail.com
May 11, 2012 | Juki Sewing Machines
No soud on video you tube
Copy everything under the dotted line
Paste into a text file. rename the file fix.reg. Double click on the reg file after it is done you need to reboot pc and it should allow for audio on flash again. The reason is that registry keys seem to get messed up sometimes and stuff gets lost. This is a sure fire way to fix it
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32]
"midimapper"="midimap.dll"
"msacm.imaadpcm"="imaadp32.acm"
"msacm.msadpcm"="msadp32.acm"
"msacm.msg711"="msg711.acm"
"msacm.msgsm610"="msgsm32.acm"
"msacm.trspch"="tssoft32.acm"
"vidc.cvid"="iccvid.dll"
"VIDC.I420"="i420vfw.dll"
"vidc.iv31"="ir32_32.dll"
"vidc.iv32"="ir32_32.dll"
"vidc.iv41"="ir41_32.ax"
"VIDC.IYUV"="iyuv_32.dll"
"vidc.mrle"="msrle32.dll"
"vidc.msvc"="msvidc32.dll"
"VIDC.YVYU"="msyuv.dll"
"wavemapper"="msacm32.drv"
"msacm.msg723"="msg723.acm"
"vidc.M263"="msh263.drv"
"vidc.M261"="msh261.drv"
"msacm.msaudio1"="msaud32.acm"
"msacm.sl_anet"="sl_anet.acm"
"msacm.iac2"="C:\\WINDOWS\\system32\\iac25_32.ax"
"vidc.iv50"="ir50_32.dll"
"wave"="wdmaud.drv"
"midi"="wdmaud.drv"
"mixer"="wdmaud.drv"
"VIDC.WMV3"="wmv9vcm.dll"
"VIDC.VP40"="vp4vfw.dll"
"msacm.voxacm160"="vct3216.acm"
"MSVideo"="vfwwdm32.dll"
"MSVideo8"="VfWWDM32.dll"
"wave1"="wdmaud.drv"
"midi1"="wdmaud.drv"
"mixer1"="wdmaud.drv"
"aux"="wdmaud.drv"
"vidc.VP70"="vp7vfw.dll"
"vidc.X264"="x264vfw.dll"
"VIDC.FPS1"="frapsvid.dll"
Nov 30, 2010 | Computers & Internet
E71 system error has appeared on screen with one red ring lit. Does anyone know how to resolve as my machine is out of warranty? Thanks in advance Firefly
the way to get around this is to contact Xbox support via phone/email and tell them you have three red lights on your console and your warranty will be automatically extended to 3years FREE and will be booked in for a FREE repair
Tel: 0800 469 9263
Jan 30, 2010 | Microsoft Xbox 360 Console
Unable to get onto internet explorer
Hello
Thank you for using FixYa.
Use another computer to download "combofix" from bleeping computer, run this and part of the fix is to reset the IE settings back
IE should restart after this, If not download say Firefox and get this installed and see if that will work, most cases it will and IE not, it can be bugs causeing your IE to stop working
Thanks
Richard
Nov 17, 2009 | Acer Aspire 4530-5889 Notebook PC
.drv unknown file
Do you have Diable or some other blizzard game installed. It appears to be related to that.
Always a good idea to scan anyway, do a thorough virus scan, and malwars scan with your favorite scanner (malwarebytes antimalware, superantispyware, Spybot S&D)
Feb 08, 2009 | Microsoft Windows XP Home Edition
TV one side slight blurr
hello, here some help with this
hope this help below are adjustments
and values
How to enter into Service Mode
While pressing [VOLUME ( - )] button of the main unit, press [RECALL] button of the remote control three times within 2
seconds.
10.1.1. Key command
"1" button...Main items Selection in forward direction
"2" button...Main items Selection in reverse direction
"3" button...Sub items Selection in forward direction
"4" button...Sub items Selection in reverse direction
"VOL" button...Value of sub items change in forward direction ( + ), in reverse direction
Value is shown as a hexadecimal number.
 ·Preset value differs depending on models.
 ·After entering the adjustment mode, take note of the value in each item before starting adjustment.
Main item Sub item Sample Data Remark
ADJUST CONTRAST 000
COLOR 3F
TINT 03
SUB-BRT 800
WB-ADJ R-CUT 80
G-CUT 80
B-CUT 80
R-DRV E6
G-DRV F0
B-DRV FC
ALL-CUT 80
ALL-DRV FC
OPTION BOOT ROM Factory Preset
STBY-SET 00
Emergency OFF
CLK MODE 00
CLOCK 000
AGING RGBW
COUNT
ALL WHITE
ALL RED
ALL GREEN
ALL BLUE
ON/OFF
RAMP WHITE
RAMP RED
RAMP GREEN
RAMP BLUE
1% WINDOW
COLOR BAR
A-ZONE B-ZONE/4 TRIO
SCROLL
WHITE FLAME
RM-SET CODE A Fixed
SRV-TOOL - See next
10.1.3. How to exit
Switch off the power with the [POWER] button on the main unit or the [POWER] button on the remote control
good luck hope tis help.
Jan 18, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
!SisRegistryServer error
The error message you got suggests an internal software corruption. I suggest that you update your P990 firmware if it isn't already on the latest firmware and then perform a master reset. This should solve your problem. Don't forget to back up all important data. Good luck!
Dec 10, 2007 | Cell Phones
My OS is Windows 3.11 and I am getting communication errors. (Fuji DS, DX and MX digital cameras only)
There is a problem due to comm.drv which is located in system folder of Win.3.11. If the comm.drv is dated Nov.1. 1993 and is 5,968 bytes, please check the property of the comm.drv within your PC. Although the problem is due to the comm.drv, FUJI has prepared a new sdt-7 for Win.311. Please call Customer service at to obtain the sdt-7 or go to the ftp site and download sdt7w31v20.exe. It is important that your PC has Win 32s loaded before install your new sdt-7.
Aug 30, 2005 | Fuji DX-7 Digital Camera
Samsung ML-3051N Laser Printer Logo
297 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
