Question about HP LaserJet P2015dn Printer
The printer (hp laserjet p2015) appears offline
The printer is in a network
  • 231 Answers
Press and hol the green 'go' button until the lights flash, (about 4-5 seconds) and release the button,
Wait for the config pages to print out, and then check your network configuration, i.p address, Subnet mask and gateway.
If no network page prints out, you might have a dead Network Interface in the printer.
Posted on May 11, 2010
  • 1,218 Answers
Windows sharing based printers are dependent on the computer where the printer is attached. This means that if the computer is turned off, or is in the sleep/hibernate mode, then all the computers that can print through that server will not be able to print. To solve this issue you can use external print servers to share printers in the home/office. External print servers are connected to the router which allows it to be available on the network without being dependent on any other computer system. External print servers are available in both wireless and wired versions, and the choice between those options is based on the needs of the home or office. get more information and help for Network Printer Configuration .
Posted on Sep 07, 2010
3 Suggested Answers
SOURCE: Printer status offline
I just ran into the same problem. The computers on the network that were running XP were showing the printer as "Ready", but all of the computers running Vista were showing the printer as "Offline".
After trying a number of solutions that I found on other message boards, I accidentally discovered that the problem was an IP address conflict. It seems that the server changed the address on the printer, which didn't bother the XP machines but brought the Vista machines to their knees.
Press and hold the blue button (HP called it the "Go" button) for 5 seconds, which will print a configuration report. In the TCP/IP section you will see the IP address for the printer. Next, open the Printers window, right-click on the P2015 and click Properties. Click the Ports tab. Find the port that is checked and click the "Configure Port..." button. If the "Printer Name or IP Address" field differs from the IP address on the configuration report, change it to the one on the report. It took a few seconds after hitting OK for the computer and prrinter to link up again, but that solved the problem for me.
Posted on Dec 03, 2008
There is a firmware update for this problem. Check out this link:
http://www.hp.com/pond/firmware/hidden/P2015FWUpg20080312.html
Posted on Apr 07, 2009
Hello , I need to know if hp-laserjet p2015 printer have a "built in" network card ? if not how can i share it between two computer by using a switch ?
HP Laser jet P2015n & P2015dn models having network facility, there is no option to add on network card for this series.
1. Install the printer locally through USB in one system and share it to others if its non "N" printer.
2. You can connect use network to USB convertor to print thorugh network. pl see the link for one of the sample product..
http://uk.shopping.com/Conrad-USB-2-0-NETWORK-ADAPTER/info
Sep 20, 2011 | HP LaserJet P2015 Printer
I replaced a hp laserjet p2015 printer with another hp laserjet p2015 printer but it can't print.what's the problem,pls help me
This HP printer is comes with the USB cable. To install the printer software, you need to install the USB driver compatible to your printer and then it will ready to print.
Dec 08, 2010 | HP LaserJet P2015 Printer
I do not have the cd for installation of printer in my pc
You can get the drivers for the HP LaserJet P2015 from HERE.
Just select the Operating System from the list and download it.
All The Best.
With Regards:-
Subhankar Ghosh
Nov 17, 2010 | HP LaserJet P2015 Printer
I have a printer hp laser jet p2015 and laptop with vista the windows can not recognized the device what i can doo
From the manufacturer's web-site: http://support.hp.com
enter 'P2015' and do a search.
Select your model of printer.
Select Windows Vista.
Select the device-driver, download it, and install it.
Sep 28, 2010 | HP LaserJet P2015 Printer
Install HP LaserJet P2015 Printer
Click Here for your hp p2015 driver, input your operating system and it'll give you the appropriate driver for that system. hope this helps and if so please mark a FixYa!!
Aug 24, 2010 | HP LaserJet P2015 Printer
in printer properties disable the power saving mode.
Jan 28, 2010 | HP LaserJet P2015 Printer
Hp Laserjet P2015d has suddenly stopped working. jobs don't reach the printer. printer has to be shut off and "reset" to get jobs to print. Why?
Check to make sure the printer isn't set to Offline mode, if is ok then it sounds like a driver problem, you need to uninstall the printer driver and then reinstall it again.
Aug 03, 2009 | HP LaserJet P2015 Printer
Sep 08, 2008 | HP LaserJet P2015 Printer
Stopped printing
Sounds like you need a new formatter board, you could verify this by swapping it with the good printer
May 15, 2008 | HP LaserJet P2015 Printer
HP LaserJet P2015dn Printer Logo
6,128 people viewed this question
Seeker5211
Seeker5211
