Question about Toshiba TLP S30 Multimedia Projector
Toshiba TLP projector identifiation part
Lamp went out during use and after that power won't come out... return to standby after 2 minutes and two red lamps appear( lamp and on)
Put new toshiba lamp but this not fixed the problem.
Because I am overseas from USA where I bought this equipmant could you plse indicate what parts is with defects to allow me to import this part- because there is no parts for thios in Brazil
Thanks
  • Toshiba Master
  • 19,396 Answers
You need to check lamp again, it may be not well mounted.
Posted on Mar 28, 2008
  • Ginko
    Ginko Mar 28, 2008
    If you put a new Toshiba lamp either the new lamp is defective, or it had not monted in the right way. Ensure that the right part had been installed. The original Toshiba lamp costs nearly same price as projector. Here is an example of new lamp for sale, its price is over $300. Part number for the lamp is Part #:TLPLV1. If you bought an original Toshiba lamp you should have 90 days cashback warantee on the lamp. In this case take it back to retailer and get a replacement.
    Regards
  • Ginko
    Ginko Mar 28, 2008
    This international seller sells second hands parts for your device for a cheap price. Buy at your own risk if you want. Here is a part search with links to more seller. Your projector has only one lamp, and its RRP is over $400. Chech that the lamp you got it is well in place, if it is and is giving you the mentioned error msg., then either lamp is faulty, is not well installed, or is not right lamp for your model.
AFTER REPLACEMENT OF TOSHIBA PROJECTOR TLP791 LAMP IS NOT WORKING . PLEASE SUGGEST THE LAP TIMER RESET METHOD. R K MISHRA SATNA MP INDIA
To reset the lamp hour of Toshiba TLP791, do the following.
1. Turn-off the device by pressing the "ON/STANDBY" and unplug the power cord.
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord .
3. The lamp operation counter will automatically turn to zero.
4. Check if the lettering "0H" appears on the lamp operation counter in the status display.
5. After the lamp operation counter has turned to zero, turn off the projector by pressing "ON/STANDBY" and unplug the device.
The lamp reset procedure is over.
ok
Jul 16, 2011 | Toshiba TLP 791 Multimedia Projector
Toshiba TLP s30 projector identification part
http://www.nextag.com/toshiba-tlp-s30/search-html
Mar 28, 2008 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP S30 projector
HI,
Make sure the lamp cover is in place as it has a plunger on it which closes a switch . If the switch is open you will never power on. With the cover remover you can manually activate the switch too and it will power up.
For more troubleshooting steps you can see the user manual from HERE
Goodluck,
Please don't forget to rate the solution.
Mar 27, 2008 | Toshiba TLP 261 Multimedia Projector
How do i reset lamp hours for a toshiba TLP-T721
I have not actually tried this but on a different post, here's the wild solution:
Reset the lamp counter hours of operation for the projector TOSHIBA TLP-T720
Sep 02, 2010 | Toshiba TLP T721 Multimedia Projector
What bulb is needed to replace in the projector?
three green lights come on then the standby light goes red and remains on when the projector is plugged in. The lamp and fan do not come on when the power button is pressed instead the lamp light comes on red.
Jul 13, 2010 | Toshiba TLP S30 Multimedia Projector
My toshiba tlp710 projector wont power on
check your power cord first, if good, if not replace it. if the problem still occur, check the power supply board of your projector. and replce it.
jahting
Oct 08, 2009 | Toshiba TLP-710, TLP-711, TLP-G5, TLP-G7...
How to reset the bulb timer for TOSHIBA TLP-XD2000
The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
Mar 12, 2009 | Toshiba Office Equipment & Supplies
Toshiba Projector TLP 651 lamp problem
yes resetting the lamp hour might be the issue but not necessarily. It could also be a temperature issue as the fan (s) might have stopped or a temp sensor issue is faulty. check your manual for resetting lamp hours. Regards Kevin Andreassend www.iceav.co.nz iceavtech@gmail.com
Oct 28, 2008 | Toshiba TLP450, TLP451, TLP650, TLP651,...
Toshiba TLP671 - lamp red LED
It is problem with temperature. So please check with filter and clean it. Other wise check any of the fans are not functioning properly. So check the same and replace
Nov 14, 2007 | Toshiba TLP 261 Multimedia Projector
I NEED SOLUTION
Hi, Pls check the small Fuse for the supply of the fan. Or you can send it to us to repair.
May 26, 2007 | Toshiba TLP T50MU Multimedia Projector
Toshiba TLP S30 Multimedia Projector Logo
80 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
