Question about JVC TH-S5 System
PSU problem The unit will not swich on, when power is connected to the dvd/tuner unit the switch-mode power supply can be heard cycling on and off at a rate of approx 2 cycles per second. Is this a known fault? If so, is it the psu or something dragging the output from the psu down.
  • kiz1 Mar 28, 2008
    I have fixed the power supply fault on my th-s5. In case you have a similar problem I changed the main smoothing capacitor 68uf 400volt and the only other electrolytic capacitor in the oscillator section ie. 39uf 25volt Now up and running again.
  • 4,234 Answers
The most likely problem is something dragging down the power. There could be a problem within the power supply as well. This is a "switch mode" power supply. That means that if the primary side does not oscillate correctly, you will get this cycling as well. These are hard to diagnose remotely. Typical power problems such as this run about $15 or so for parts plus the local labor rate if it is within the power supply. The parts cost will rise to the $30-$50 range if the output amp section is the problem.
Dan
Posted on Mar 28, 2008
What is psu?
Power supply unit computer
A power supply unit (PSU) converts main AC to low-voltage regulated DC power for the internal components of a computer. Modern personal computers universally use a switched mode power supply. Some power supplies have a manual selector for input voltage, while others automatically adapt to the supply voltage.
Apr 25, 2014 | HP Pavilion a1253w Notebook
My pc starts up without pressing power button, cant switch it off with power button so iff i switch it off on the power supply and switch it back on it immediatly starts up not showing anything on screen...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem hope this helps
May 25, 2011 | Gigabyte GA-EP43-UD3L Motherboard
Will not power on
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 21, 2011 | E-Machines Emachine T2865 Power Supply...
Was told there should be a switch on the motherboard to test whether the power supply is supplying power. Can't find anything of that sort.
May 20, 2011 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
CPU phase led1 on- in 1 phase power mode only, no signal received by the monitor
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
hard drive
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
if this fails to fix the problem
or it might be your graphics card make sure its securely seated and there is no dust built up
on and around the graphics card hope this helps
May 06, 2011 | MSI 870G45 AM3 AMD 770 ATX AMD Motherboard
I have a Gateway Intel Pentium 4 that won't turn on, the power button light turns on but nothing else. The power supply test switch shows that the power supply is good, and when the switch is pressed all...
Apr 26, 2011 | Gateway Computers & Internet
I push the power button It doesn't boot all the fans come on the light come one and a second later it off, then it tries again, it keep trying to cycle but can get anywhere. I have just assembled this...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Mar 10, 2011 | Computers & Internet
On powering up the front lights flicker and a clicking noise is heard but nothing happens ie will not boot up.
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Mar 03, 2011 | Fuji Computers & Internet
Computer acts like it in standby mode will not power up, made a weird noise according to my daughter and quit
hope this will help
don
Feb 23, 2011 | Dell Dimension 4400 Power Supply ** FREE...
DvD Rom Drive opens and closes over and over and won't quit
Hello there bakers_girl2.
Here's your GEEK-steer ...
If it's occurring during "power saving mode" also as you say, it's likely drive replacement time. But let's not be hasty. Perform the following:
  1. Shutdown system.
  2. Turn off PC's power supply unit (PSU) switch.
  3. Unplug power cord from PC's PSU.
  4. Wait 5 minutes.
  5. Open case to gain access to the problem drive.
  6. Prior to touching ANYTHING inside the case, touch any metal part of the case-frame to rid yourself of any built-up static-electricity.
  7. Disconnect the ATA cable from the back of the problem drive (but leave the power cable connected).
  8. Reconnect power cord to PC's PSU.
  9. Turn case PC's power supply unit (PSU) switch back on.
  10. Reboot.
If it still occurs:
  • You now know the problem is isolated to the drive itself.
  • It could be, the eject button's gunked up. In which case you might try a shot of silicone spray on it, then work it in by pushing it several times.
  • if under warranty, return it as it's repair/replacement time.
If not:
  • Something software related is likely sending hokey-pokey commands.
  • Reboot system into Windows "Safe Mode".
  • If it stops occurring, you know it's a non-Windows application (software) process that's likely the culprit, which means it's time to play "process of elimination" to isolate which one. Getting SysInternals "AutoRuns" and "Process Explorer" can come in handy with this chore.
Good luck, and please do post back to ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback.
  • if you have any further questions,
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 09, 2009 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
JVC TH-S5 System Logo
152 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
