Question about Fagor 24 in. FI-48W Dishwasher
Dosing THe machine is not dosing itself with detergent or rinse aid
  • janice-mason Nov 30, 2008
    servis dishwasher no model number the machine is not dosing itself with detergent or rinse aid
  • 185 Answers
Make and model please
Posted on Mar 28, 2008
Why does the low rinse light stays on?
The obvious answer is that you need to add rinse-aid to the rinse-aid dispenser. Barring that, then you probably have a bad level sensor in the dispenser and would need to replace the whole detergent/rinse-aid dispenser assembly. On the other hand, it could just be a loose or disconnected wire going to the detergent/rinse-aid dispenser.
Oct 09, 2014 | Samsung DW7933LRABB
Dishwasher cloudy glasses
I do not have enough information to be able to answer with hundred percent certainty.
From my experience, the most common problem is the improper handling of the appliance. Driven by overwhelming commercials we often pass from detergent to tablets. The largest number of tablets contains rinse aid that we already have in the dispenser. Practical adding a double dose of rinse aid resulting in poor washing results and glasses look like washed in milk. The solution is to open the dispenser and put the dosage rinse aid to minimum. In electronic dishwashers new generation is even possible to completely exclude the dosage rinse aid if you are using tablets.
Dado
Aug 26, 2014 | Indesit Dishwashers
AEG 50879
This option can be selected by pressing the corresponding button, and remains in memory until the same
button is pressed again. This option modifies the phases of the programme in order to optimize performance
when "3 in 1, 5 in 1, 7 in 1, ......." detergent tablets are used:
- variation of the duration of the programme and the temperatures required to dissolve the detergent tablets.
- reduction of water exchange
- exclusion of introduction of rinse-aid
- exclusion of regeneration
If you use a dishwasher in the traditional manner (detergent, rinse aid, salt) then the Multitab function is disabled. If you use tabs that are already on the market with rinse aid and salt there is a possibility during washing cycle to add a double dose of rinse aid. From rinse aid dispenser and rinse aid from tabs. This will lead to poor cleaning results, glasses will look like they have been washed in milk..To avoid that you must turn on "Multitab" function and thus exclusion of introduction of rinse-aid from rinse aid dispenser. This function also stops the regeneration and will not spend salt because salt is already in a tabs. Also extends the washing time because tablets need more time to dissolve in relation to the traditional powder detergent.
Dado
Jul 15, 2014 | AEG Dishwashers
The problem is the glasses are very foggy and spotted is there a certain detergent I should use?
without knowing the make and model of your dishwasher, I can only suggest you first check if the Rinse aid is there and try to change the dose if your dishwasher can allow you to adjust this. Use the detergent recommended in the dishwasher manual.
Mar 21, 2011 | Dishwashers
LG Inverter Direct Drive, at the end of the cycle there is a grey -white residue on everything, interior,glasses,pots n pans. We use Cascade packets and Rinse-aid. Please help!!
The packets usually have detergent and rinse aid together, built in. If you also have liquid rinse aid in the automatic dispenser, you are getting a double dose, and that is causing the film. Use standard dishwasher detergent until the automatic rinse aid dispenser is empty, or at least turn the pointer indicator (located by the rinse agent filler) to the lowest setting possible to help somewhat.
Mar 05, 2011 | LG LDS4821ST Stainless Steel 24 in....
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
My dishwasher is leaking huge amounts of foam to the floor. This is what happened before I ran the cycle: I had mistakenly poured detergent into the "Rinse Aid" slot in the inner side of the dishwasher...
OK.... The rinse aid dispenser holds enough rinse aid for a lot of washes and dispenses very little each time. So you may nedd to have the dispenser emptied by a technician. If you take the door liner off you can see the back of the dispenser and maybe you can work out how to empty it. Holding the actuator in manually could allow the rinse aid dispenser to run out. Then wipe the tank dry with a towel. Putting high fat milk in the machine while it is rinsing will neutralise the foam. Just one cup will do. Good Luck.....T.
Aug 01, 2010 | Dishwashers
Neff Integrated slimline - Programme does not complete.
IT SOUNDS AS THOUGH ITS NOT HEATING DETERGENT AND RINSE AID INTRODUCED INTO COLD WATER WILL GENERATE A LOT OF FOAM,IS APPLIANCE WARM INSIDE AT END OF CYCLE?OR IT COULD BE TOO MUCH RINSE AID IF IT IS FILLED WITH RINSE AID AND YOU ARE USING A TABLET WITH RINSE AID COMBINED IT WILL HAVE TOO MUCH TO USE IN ONE WASH.
Aug 03, 2009 | Neff Dishwashers
Not using detergent or rinse aid
Do you have a Manual for your machine, if not get one in USA 800.858.4477 in Canada 800 263 5798 we goes from there. God Bless Dickson
Apr 28, 2009 | Moyer Diebel 24 in. 301HT-40 Built-in...
Hard scratchy towels. Have used all wash cycles, and use fabric softener
have you tried just white vinegar as your rinse aid. Do a full cycle of your washing machine using white vinegar instead of detergent, to clean any residue from pipes, and then in the next wash try white vinegar as your rinse aid.
Apr 18, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Dishwashers Logo
347 people viewed this question
Top Fagor Dishwashers Experts
dannydoesita
ray gallant
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
