Washer got electrical burn smell, filled up and then stopped. permanent press side of dial still works though
  • 88 Answers
Its possible the motor ,might be going bad...
Posted on May 10, 2010
My whirlpool ultimate careII quiet wash washer stopped working in mid cycle. It won't agitate, drain, spin, fill with water, nothing. The washer makes a humming sound and an electrical burning smell.
If your smelling electrical burn.. It's most likely to be the motor is bad.. Or just stuck, new washers made today are DC motors and contain a circuit board in the motor.. And are not serviceable.. Just replace them..
Dec 02, 2016 | Whirlpool Washing Machines
Started filling, made a loud noise, stopped filling immediately, door wouldn't open. I tried everything to get it to open. Running the spin cycle finally got the door open at the end of the cycle, though...
The washer drain the water if you put on spin. all electronically controlled washer won't unlock the door and or spin if there's water inside the water has to be drained out first.If the basket didn't move(no motor movement) and it finished the cycle, POSSIBLE problem is the motor control board. Motor Control Board 00436461
Nov 22, 2017 | Siemens WFXD5200UC Front Load Washer
What is causing the bad electric smell from my dishwasher?
one or more components is burnt on the board of the unit. Or there might be a bridge of wire which is causing the smell....
Jan 05, 2012 | GE Dishwashers
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
Nov 18, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
Washer stops at rinse cycle-hums and has a smell.
Problem is with your lid switch which has to be replaced. This is if your filter is all clean.
Feb 28, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Replaced Motor Coupling but now I have electrical smell when running
You can test the washer with the case removed by by-passing the lid switch. You will need to jumper the two BLACK wires at the lid switch connector (where it connects to the timer).
With the case removed, and the washer UNPLUGGED. Locate the lid switch connector and jumper the two BLACK wires. Plug washer back in and carefully turn the timer on to start. You will be able to visibly inspect the washer while it is running. The Drive Motor should not start running until the washer fills completely. Set the washer on the lowest water setting to reduce fill time. Usually electrical smells are attributed to the Drive Motor and/or Start Capacitor. Make sure the connectors are all on properly and not loose. Loose or corroded connections can cause arcing and/or burning. Inspect all the wiring for any signs of chaffing or burning. Use caution not to touch any of the electrical connections while the washer is running or energized. Running the washer with the case removed is primarily for giving you a visual for any obvious signs of problems. Any wire and connector checks should be done with power removed. I hope this information helps you. Please post back if you require further assistance.
Jun 05, 2008 | Washing Machines
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
