Question about Body Solid Body-Solid Fusion 500 Personal Trainer
Hi the weight plates get struck when i am doing workout when I put on 2 weight plate and when I do heavier weight it feel i like not smooth. I notice that the weight plate is little side way when I pull up. Is it a main cable problem cause the main cable is a bit shorter?
    President:
  • Body Solid Master
  • 832 Answers
I would the entire sequence of pulleys that lead from the lat/chest press cable to the weight stack itself to see if any of the pulley are dragging or the cable is snared. Another thing I would look for is that top plate selector pole is straight . I would loosen the allen bolt 8mm put the selector pin in one lower plate holes then tighten the bolt. If that solve the problem I take the weight stack apart and inspect the bushing for burrs that may be causing the drag.
Posted on May 10, 2010
Plates do not feel smooth stainless steel not shiny
could be the quality of the cleaning detergent you are using, the temperature of the wash water or other factors that you are not mentioning
Aug 09, 2016 | Stainless Dishwashers
Selector knob spins, no clicks, does not select the weights. The metal disk near the handle does not move.
1. Check to assure that the ******** handle is fully depressed into the ******** base. If not fully depressed, the locking mechanism will not be released and may be keeping the adjustment knobs from rotating. 2. Check to see if any weight plates have been put into the base assembly backwards with the "support ******" facing the grip of the ******** handle. All weight plates must have the selection ****** facing away from the grip of the ******** handle. 3. Check to see if there is any dirt, debris or other obstruction in the ******** base. You may need to remove the weight plates from the base to accomplish this check. Remember to put each weight plate back in its appropriate location with the selection ****** facing away from the ******** grip.
Aug 15, 2011 | Bowflex Selecttech Dumbbells
Hi i have a question about clutch slipping i have put a 6spd vt box to a 6l ve motor in my vx the clutch slips down low but at hi rpm it grips kind of feels like theres wait on the pedal the hol time
CLUTCH PLATE CONTAMINATED WITH OIL OR CLUTCH PLATE AND PRESSURE PLATE WORN.FLYWHEEL SURFACE TOO SMOOTH GLAZED.MACHINE SHOP CAN REMOVE GLAZE FROM FLYWHEEL IF NEEDED.
Jul 18, 2011 | GMC Sierra Cars & Trucks
My bowflex dumbells are jammed and i cant remove them from the holder
Hi I called 1-800-628-8458 (the number in the manual) after trying several of the methods shown here. None worked. your dumbbell needs to be on a flat surface, no roll the dumbbell over to where the weight is facing the floor and the base is up in the air. With both hands lift the base and gently shake, the weight should fall out. Put the base back on the floor face up and inspect the grooves where the weight plates go for any debris. Clean this area if you find debris. Now you will need a pen or pencil with your weight. Grab your weight, still facing down and you will see a black release button on both sides on the inside of the weight. It is in between the metal dial and the inner part of the weight. Now press down on that button with your pen or pencil and start turning the dial (caution: the weight plates are going to fall out) keep turning until all of the plates are out. Do the same thing for the other side. Now grab each plate and put it back on the base where it goes, the smallest plate on the outside to the largest plate on the inside, make sure the small metal piece on the bottom of each plate is facing away from the inside of the base. Do this for all of the plates. Now back to the dumbbell. Grab your pen or pencil again and press down on the black release button and turn the dial to where the number 5 or lowest weight is selected where it reads Bowflex. Do this for both sides. Now grab your dumbbell and carefully put it back into the base. It is important that you put the dumbbell down straight, avoiding any shifting in plates.
I hope this helped.
Dec 21, 2010 | Bowflex Selecttech 1090 Dumbbells
Weight Plate falling off
Thank you! I found the reset button and now it works again.
Jul 16, 2010 | Bowflex Selecttech 1090 Dumbbells
The weight plate get struck when i doing workout when on the 2 plates and when doing working with more plates it fell like not smooth. is the main cable problem cause it more shorter
May 10, 2010 | Body Solid Body-Solid Fusion 500 Personal...
Shocks FXST
Loosen the lock nuts ...u'll need a spanner wrench ( harley part # 94455-89) .
Mark the adjuster plate for reference....turning that plate out increases preload to carry a heavier weight.... turning in decreases the laod.... keep the adjustment the same for both shock.... tighten the locknuts and u are done.......
happy trails
Mar 01, 2009 | 2003 Harley Davidson FXST Softail Standard
Bobbin thread/feed dog eating fabric
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Dec 03, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Body Solid Body-Solid Fusion 500 Personal Trainer  Logo
98 people viewed this question
Top Body Solid Exercise & Fitness Experts
Howard
Howard
John
Tom Chichester
Are you a Body Solid Exercise and Fitnes Expert? Answer questions, earn points and help others
