Question about Kitchen Ranges
The lights don't go on: pushing the lamp button illuminates the symbol on the display, but no lights go on. Blower works fine
    New Friend:
  • 31 Answers
I presume the light builb is burnt, try a new one.
Jacques.
Posted on Sep 04, 2010
Where is my ign fuse located on my car
Below dash instrument panel, R16 ignition relay
98 Ford Contour SE Fuse Box Map
Fuse Panel Layout Diagram Parts: passenger side air bag, heater blower, interior lighting, heater blower motor, parking lamp, interior lighting, electric mirror, clock, wiper motor, ignition, reverse voltage protection, rear window defrost, engine management system, instrument panel illumination, radio, wiper motor, power windows, ABS module, backup lamp, brake lamp, door lock, main light, cigar lighter, electric seats,
link below should be the same as yours, press the helpful button
http://www.autofuseboxdiagram.com/1342-98-ford-contour-se-fuse-box-diagram
Jan 30, 2016 | 1999 Ford Contour
Where is my ign fuse located on car
Jan 30, 2016 | Cars & Trucks
HOW TO PULL CODE ON 2012 HARLE
1- Turn motorcycle ignition switch to OFF & Run/Stop switch to RUN.
Push odometer reset button in & hold.
Turn ignition switch to Ignition and release odometer reset button. Background lighting will illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting will illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carburetor])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC in an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed. NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9 - Press and release the odometer reset button to continue to the next module.
10 - Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
The actual error codes will appear (format) as "P0374", for example.
Sep 30, 2014 | Harley Davidson FLHTCUI Electra Glide...
My 2007 harley fatboy will quit when it gets hot on occasion. will restart and rum fine for 100 miles or so then quit again
Have you checked for any error codes?
To actually get to the diagnosis mode (to read error codes):
SP = speedometer
T = tachometer
Sep 29, 2014 | 2007 Harley Davidson FLSTF Softail Fat Boy
Hey guys, I have a 2007 H-D XL883C and I am having a little issue with my Fuel Injection light on my HUD. Normally, when I turn the bike on I will hear a slight whoosh noise of fuel feeding in, and I will...
For a quick check of speedometer function, a "WOW"
test can be performed. Press and hold odometer reset
switch then turn ignition switch ON. Release reset
switch. Background lighting should illuminate,
of motion, and indicator lamps (sixth gear, check engine,
low fuel, battery and security) should illuminate. The
sixth gear indicator lamp will illuminate even though it is
not used in normal vehicle operations. The security lamp
may illuminate even if the vehicle is not equipped with a
security system.
Sep 03, 2013 | Harley Davidson XL 883 Sportster...
I cant open
Push the power switch up as far as it will go and see if the blue ring on the front of the player lights up.
The Fuze's power button is not a traditional button but a slider, so if you did not push the slider up all the way, this may be the only reason it was not powering on.
Reset the Fuze by pushing up on the power switch and holding it in the up position for 10 seconds.
Try to power on the Fuze again after it has fully rebooted.
Connect the Fuze's USB cord from the Fuze to a USB port on your computer.
You should see a yellow charging light illuminate and the battery symbol blinking on the Fuze's main display.
Once the battery stops flashing, the Fuze is fully charged and you can try to power it on again.
hope this helps
Sep 27, 2012 | SanDisk Sansa Fuze MP3 Player
Where the fuse box to a 88 ford thunder bird 5.0 liter
The fuse panel is located underneath the dash, to the left of the steering column, next to the emergency brake pedal. You need to remove the under-dash insulation to access some parts of the fuse panel.
If it doesn't have a diagram inside the box, here's one I found online: http://www.coolcats.net/tech/reference/images/fusepanel.jpg
1 15A Lt. Blue Stop Lamps, Hazard Warning Lamps, Speed Control, Cornering Lamp Relays 2 6A - CB - Windshield Wiper/Washer Pump 3
Spare - Not Used 4 15A Lt. Blue Taillamps, Parking Lamps, Side Marker Lamps, Instrument Cluster Illumination, License Lamps, A/C and Heater Illumination, Radio Illumination, Digital Clock Illumination, Autolamp Relay 5 15A Lt. Blue Turn Signal Lamps, Electronic Day/Night Mirror, Lighted Vanity Mirrors *, Backup Lamps, Illuminated Entry, Keyless Entry, Cornering Lamps 6 20A Yellow Rear Defrost Timer, Chime, Back-Up Lamps, Cornering Lamps, Rear Reading Lamps, Trunklid Release, Digital Clock Display, Illuminated Entry, Anti-Theft Module, Turbo Buzzer 7 15A Lt. Blue Fog Lamps (Turbo Only) 8 15A Lt. Blue Courtesy Lamps, Key Warning Buzzer, Illuminated Entry Module, Glove Box Lamp, Door Lock Relays, Radio Memory, Cluster Memory, Outside Mirrors, Tripminder Module, Analog Clock, Anti-Theft Relay 9 30A Lt. Green A/C Heater Blower Motor 10 20A - CB - Horn, Cigar Lighter, Fuel Filler Door, Flash-to-Pass, Speed Control 11 20A Yellow Radio, Tape Player, Premium Sound Amp, Power Antenna, Graphic Equalizer 12 20A - CB - Power Seats, Power Locks, Keyless Entry 13 5A Tan Instrument Cluster Illumination, Radio, Climate Control 14 20A - CB - Power Windows, Power Moonroof 15 10A Red Taillamps, Rear Side Markers, License Lamps, Electoluminescent Coach Lamps 16 4A Yellow Electronic ATC 17 15A Lt. Blue Electronic Cluster, Tripminder Display, Fuel Gauge (non-electronic cluster), A/C Clutch, Speed Control Module, Graphic Warning Display Module, Electronic Blower Speed Controller 18 10A Red Warning Indicator Lamps, Autolamp System, Throttle Position Sensor, Low Fuel Module, Dual Timer Chime, Tachometer, Washer Fluid Level Indicator
May 20, 2011 | 1988 Ford Thunderbird
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Cavaliere 218 series range hood lights don't work.
It's the connectors that lead from the transformer to the lights.
I had the same problem with the Vetron series and hard wiring them with new clips fixed the problem.
Nov 14, 2009 | Kitchen Ranges
Strange symbol
The same thing happened to me, and here is what I found in an online user manual (but not the one delivered with my watch). Switching the Backlight On
Press the Light button and the display is illuminated for a few seconds.
After you have illuminated the display once while exercising night mode symbol (MY WORDS HERE : the "eye symbol") appears in the display. The display automatically illuminates each time you press any button or bring the wrist unit near the Polar logo on the transmitter, until you stop recording the exercise.
Sep 16, 2008 | Polar F6 Wrist Watch
Kitchen Ranges Logo
178 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
