Question about Quasar VV-2002 20 in. TV/VCR Combo
Connection for cable
It seems to be a problem on the tv end of the cable connection. I have a picture and sound but very snowey. Can I take the back off and make sure everything it still connected, or is that an ordeal?
  • 4,234 Answers
A snowy picture is usually an indication of a bad ground. Check the cables at both ends to be sure that the braid(shield) is still intact and connected to the F-connector. Also, check the connections on the exterior of the house. You can also call the cable company and have them check the connections at the poles.
Dan
Posted on May 10, 2010
What could be the problem with my tv cause it searches continously without finding any station.it thereafter remains on channel 0 with no image or sound.i have changed tuners but that doesnt help.plea
There seems to be an incompatibility between the TV's setting and the antenna's input.
The TV doesn't see the antenna connection and keeps searching.
Somehow you have to get the TV's 'cable' setting in the menu to 'over the air'.
Is there a clean signal coming to the TV? Sometimes a cable can be compromised where the signal never reaches the input connection. Check both ends or at least replace the cable temporarily.
Last but not least, the TV maybe set to a PIP (secondary tuner with a picture in a picture) and the tuner is not electronically connected.
Jan 05, 2015 | Televison & Video
I have picture but no sound. We just had our surround sound system go out and are trying to run our tv on it's own internal speaker system. How do you hook it to our direct tv hd box
Hi.
You need to use audio cables. Connect two red and white audio cables from the output on the HD box to the relative input at the back of TV (nr.4 in picture below). The best way to connect the HD box is by using component cables, that are the red-green and blue trio of cables, plus a white and red audio cables.
Here what you need:
Three plus two:
Component Video Cable
Audio Red / White Cable
or single set of five:
Cables Unlimited - Video / audio cable
Once you have the five cables, connect them to the output at the back of the Direct TV box, and then connect the other end of the cable to either group of connectors 6, or to one of the columns in connector 7. Do connection with box and TV power off. After re-applying power use the source-input selector on remote to select the source from Direct TV box.
May 24, 2011 | Samsung HCM4215W 42" Rear Projection...
I DON'T KNOW WHERE TO PLUG MY DVD CABLE IN TO MY KV SONY TRINITRON- THERE DOESN'T SEEM TO BE ANY PLUGHOLES
Hello
You can connect the DVD player ot your Sony TV in two ways. One way is via AV cable, and the other is S-Video cable. If you use AV cabel, connect the cable's one side ends to output sockets of the DVD player, marked as Audio-L, Audio-R and Video. Connect the other side of the cable's respective ends ot TV's respective sockets, marked as Audio_L, Audio-R and Video. This socket can be located at the back of your TV. If you expects a beetter picture quality, you can connect the TV-DVD by S-Video cable. If you connect it via Audio Video cabe, switch the TV to get AV-1, AV-2 etc, by input selector option. If you connect S-Video cable, Select TV' to recive S-video input via its input selector option. You can do these selections by the help of TVs remote control. OK.
Feb 23, 2011 | Sony KV-36XBR200 36" TV
I have a Sharp 32" Standard TV ... picture will get fuzzy either due to someone walking by or sometimes if sound coming from tv is vibrating. If we shut tv off and turn it back on it is clear again. The...
Hello: Your problem seems to be in or around the tuner of the television, More then likely you have cold solder joints on the turner that needs to be resoldered. Also check the coax end protruding from the back of the set where u connect the cable and make sure it is not loose, a bad ground on this connector to the turner shield will cause this symptom. My professional diagnostic is that when the television is cold the solder connections are making contact with the board, and as heat builds up in the television while watching these connections tend to seperate and make limited contact, causing fuzzy picture and in most cases no picture just snow...
Sep 06, 2009 | Sharp 32C-240 32" TV
No picture or sound
Have you re-connected the cable connection back into the TV from the player? There should be a lead going from the player & into the rear of your TV, I expect you are using a HDMI cable which has a a small flat-like end on the cable, re-connect this & try again.
Aug 22, 2009 | Sony BDP-S350 Blu-Ray Player
No tv picture - only audio - after pc to tv box hook-up
Hi I am a silver surfer but this is how I got it working
First off get the program tou want to watch up on PC Moniter(screen) Then connect 3 cables
Yellow cables / One end to tv other end to yellow hole rear of PC/TV Box
Grey cable small end goes in PC/TV Box just behind the wirds "kworld" other end goes into back of your Computer ,you need to check your Computer manual to see the which one is the connection to your Computer screen(moniter),mine was blue with 2 screws , disconnect this and screw in Grey cable
Black cable narrow flat end into front bottom of Computer ,other end intoPC/TV Box end hole next to yellow cable
Switch on TV and change AV until you see your program, sound will be thu your Computer Speakers NOT your TV
THIS IS FOR A DESKTOP COMPUTER
Jun 15, 2009 | KWorld PC to TV (0872880887527) Video...
PS3 hdmi connection
With your PS3 on standby (red light) hold the on/off button down until it goes green and then back to red. This restores your PS3 to "factory settings", i.e. it is waiting for you to tell it how you want it to connect to your TV. Now disconnect any HDMI cables you may be trying to use and connect your PS3 to your TV via a scart connection. Now switch your PS3 on and turn to your AV channel and you should have both sound and pictures.
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
Unable to get sound when connecting DVD player to TV
connect one end of white cable to dvd/vcr audio output and the other end of white cable to tv audio input L .
connect one end of yellow cable to video output on dvd/vcr and the other end of yellow cable to video input jack on tv
If you connect like this after checking you connections this should fix problem.
Jan 02, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Problem
You could have a bad tuner or I have found location number R106 could be open and not passing the voltage. It is a 39K resistor at half watt. The voltage goes to the tuner.
Oct 27, 2007 | Sanyo DS31590 31" TV
Quasar VV-2002 20 in. TV/VCR Combo Logo
51 people viewed this question
Top Quasar Televison & Video Experts
Radames Pagan
Radames Pagan
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
