Question about Cooper Lighting Lighted Switch
I am trying to wire a double toggle switch one would work an outside light and the other the garage light. help!!!!
  • 843 Answers
I can probably help you, but I need more info. Are you replacing a single switch that operated both of these lights together? Do you have 3 black wires and three white wires in the box now? Are the 3 white wires all connected together? Were 2 of the black wires connected to one terminal of the old switch, and 1 black wire connected to another terminal of the switch? ----- I'm doing lots of guessing here so that you understand the kind of info I need.
Posted on May 10, 2010
How do I wire double elrctrical switches?
i assume both switches are single pole? How to wire depends on what wires you have in the box (i.e. the circuit they are in).
Aug 10, 2014 | Leviton White Double Wall Light Switch...
I need to wire a outside light and a inside light to one double toggle 2 way switch as separate switches for each light.
9k=Here is a double wall switch. Power into switch as with any switch, and each switch will operate separately. This type of switch is a common item in any big box store.
Jan 24, 2014 | Electrical Supplies
I am trying to install a double pole pass and seymour toggle switch to electric outdoors for a pool pump and pool timer. this switch appears to match the old one so I tried to wire it exactly the same. All...
Hi Jeremy,
You need a double pole or S2 switch rated at least for 240V / 20A.
It sounds like you're describingt a four way switch or S4. A quick check of the handle (if the traditional toggle type) can help you identify the switch; it should have "ON" and "OFF" indicated on it if it is an S2 and nothing at all if an S4. S4 switches almost always have four brass or gold colored screws while S2 switches nearly never have four brass or gold colored screws (not counting the green ground screw - of course).
One or more S4 switches are used between three way or S3 switches when 3, 4, 10, 20 or more switches are needed to control lights or other devices (typical usage to turn lights on and off at each floor to a stairway in multi-level buildings. These are typically 120 volt residential circuits in the U.S..
S2 switches are required when controlling two hot wire circuits that need both hot wires to be opened when shut off. These are typically 240 volt residential circuits in the U.S..
I hope this helps & good luck!
Apr 15, 2012 | Electrical Supplies
I have a 3 gang box in my kitchen on switch is a double switch for the kitchen , one is for the outside flood light and the other is to the garage lights. I need to replace the garage light switch beacuse...
Your switch has 2 wires, and 2 brass screws, and new switch will have same.
Connect either wire to new switch.
Connect bare ground wire to green screw.
Turn power off, remove screws that hold switch into box, pull out switch, take photo of wiring, install new switch.
If wires are pushed into back of switch, then use small screwdriver and push into slot to release wire.
http://waterheatertimer.org/How-to-wire-switches.html
Dec 05, 2011 | Cooper Industries Cooper Wiring 2158V 3...
I am trying to replace a 1 toggle switch along with a receptacle with a 2 toggle switch. The present toggle switch controls an outside light. I am planning to put a small hard waired light on the inside...
I specialize in wiring devices and timers.
You are adding a new light.
You need to wire a switch to the new light.
The existing box has a switch and receptacle.
Here's where I am confused:
I am uncertain if the original switch and receptacle are a single device.
Of if you have separate switch and separate receptacle?
And then:
What kind of device are you adding, a single switch?
Are you replacing the receptacle with a switch?
Or are you installing a double switch as shown below?
Add a comment and tell me the devices you are working with and the color of the screws on sides of each devices and I will get it wired correctly for you.
The double toggle switch shown above has brass screws on one side and silver screws on the other side.
The brass screws are connected by a brass plate.
The silver screws on the other side of the device are separate.
The hot wire connects to the brass screw.
The outdoor light connects to one of the silver screws.
The new light connects to the other silver screw.
Nov 06, 2010 | Pass & Seymour #690WGCC6 15A White 2SP UL...
Dual receptacles (hot all the time) next to dual rocker switches. One switch controls a light, the other a disposal. I've got three black and one white wire ( ground). The post set up on the rockers...
What are you doing? I can't figure it out.
I think you have a new double rocker switch and you are trying to replace a double toggle switch and you don't know which side to put your wires?
The screws are color coded. Look at the screw colors on old and new switches and follow same pattern.
If this is incorrect, answer back and I will help.
If you are adding another circuit.
That means running a new wire into the box to power another receptacle box, or to switch another light fixture.
If this is the case, the best place to connect any new circuit is the existing receptacle.
Connect new black wire to brass colored screw
Connect new white wire to silver colored screw.
Oct 25, 2010 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
How can I can a second wall switch to open/shut my garage door
The 2 wires from your toggle switch need to be connected to terminals 1 and 2 on the rear of the motor unit.
Aug 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Remote garage door openers work intermittently.
check to see if your ant. is up inside of the cover it's a little black wire that hangs outside of the operator shiould be about 6 inch.
Jun 02, 2009 | liftmaster Chamberlain Garage Door Opener...
3 ways not wired correctly
Im not sure if you know what you got yourself into but i hope this helps. Sorry for all the words but this does take some reading if this is new to you.
http://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
Dec 13, 2008 | Electrical Supplies
Cooper Lighting Lighted Switch Logo
133 people viewed this question
Top Cooper Lighting Electrical Supplies Experts
john h
Ottoniel
Gene Haynes
Are you a Cooper Lighting Electrical Supply Expert? Answer questions, earn points and help others
