Question about Remington Electric Pole Saw
Pole chainsaw not working
A few years ago, i purchased a 10 in bar pole chainsaw. i lent it to my neighbor, and the chain came off, and he put it back obn wrong. when i went to use it, there was no power
    Brigadier General:
  • 4,088 Answers
No power could be a broken wire in the power cord, usually near the plug end. It could also be the switch, or the motor brushes. More rare is a broken wire in the motor or the saw case. Hope this helps!
Posted on May 10, 2010
How to install a new blade for my 10 inch electric chainsaw - model 358-34010
Loosen the chain adjuster and remove the bar bolts. Remove the side cover. Remove the existing chain. Thread the new chain over the sprocket making sure the drive cogs are engaging the sprocket correctly, then thread it over the end of the bar ensuring the drive cogs are inserted correctly in the bar groove. Install the bar/chain onto the bolts aligned with the chain adjustment pin and install the cover. Snug the bolts and tighten the chain with the guide bar tip elevated. Once you are satisfied with the chain tension, tighten the bar bolts and....... VOILA.... you are done. Head for that pesky neighbors tree that drops leaves in your yard.....
Of course, make sure the chain orientation is correct !!!! I have seen them installed backwards on the shelf in the big box stores....
Apr 19, 2015 | Craftsman Garden
What chain oil in RM1015P
Hello, The chain lubrication oil is called bar and chain oil. It is specially formulated to cling to the bar and chain to ensure maximum lubrication. You can obtain bar and chain oil at any hardware store or power equipment shop.
Jul 14, 2014 | Remington 10" Model Rm-1015p Electric Pole...
No user manual for pole chainsaw
the chain should not have slack but not so tight it will not roll by hand (wear a glove) when u pull down on the chain in the centre of the bar there will be about 1/8" max slack. be sure the guide that runs in the bar groove does not clear the bar when pulling down. Chain will loosen over time so check ea time u fuel.
Jug is for bar oil, assuming a separate compartment has been identified for gasoline oil/ mix. when buying bar oil buy the grade to the climate u are in , heavy for summer -- light for winter -cold climate
Nov 22, 2013 | Garden
Loose chain
you have to loosen the bar then there should be a screw behind the bar or a slot in the bar to put a screw driver. turn till tight then you hold it there and tighten the bar back up
Sep 28, 2013 | McCulloch 10" Electric Pole / Chain Saw
Remington Pole Saw RPS2N1 takes what type of oil?
Amazingly I read the owner's manual online and there is no mention of what type oil to use. However, this is a chain saw, albeit and electric chain saw. Therefore it is reasonable to assume that you would use bar oil which you can purchase anyplace that sells chain saws. Just ask for chainsaw bar oil. If you want to clarify this call 1-800-858-8501.
Apr 25, 2010 | Remington Polesaw Wizard
Need new chain for remington pole saw, model 106890-02, part # 091371-03s[ 10" bar, 25.4 cm chain ]. lowes has replacement 10", 25 cm chain for remington pole saw # 106821, cant find that model anywhere,...
It should, I have been on this earth to long for a definate answer. Both saws have 40 drive links, are 3/8s, and a gauge of 0.050. Please verify my findings here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Have you contacted a local saw shop? With your chain as a pattern they can make a replacement in couple of minutes. Inquire by phone about a price you may be pleasantly surprised. Give them Oregon number 91VG040G (low kickback, most likely what your saw is fitted with). If you feel adept you might try a slightly more agressive chain but the odds of kick back increase. HTH
Lou
Feb 06, 2010 | Remington Polesaw Wizard
MAC 7-38 chainsaw stalls when you open the throttle. Any ideas?
We are talking about an electric chain saw ?
I would say you are not getting oil to the bar chain sprocket. Do you have enough bar oil in it ?
Feb 01, 2010 | McCulloch 10" Electric Pole / Chain Saw
Chain fell off chain saw remington 10" pole saw, need directions to put back on.
Look from the side of the saw the motor/engine to left and the bar nose to the right. The thinnest part of the chain (sharpened edge) on the top of the bar is to the right.
Sep 26, 2009 | Remington Electric Pole Saw
What kind of chain oil to use for a 10in remington electric
According to the manufacturer... "Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil." So, I suggest for any Remington electric chains saw not to use bar and chain oil. I hope this helps...
Jun 25, 2009 | Remington Electric Pole Saw
Remington Electric Pole Saw Logo
156 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
