Question about Canon PIXMA MP530 All-In-One InkJet Printer
I need a wiring diagram or picture of the logic board with all connectors in place on a Canon Pixma MP530 Printer. I completely disassembled the printer to replace the absorber kit. I have acquired the service manual and the parts manual (which I can share), but no guide to which connectors go where on the logic board. While I did label the parts and covers for re-assembly, I was not dilligent enough with the connections to the logic board.
  • jscurmaci May 10, 2010
    Thanks, but I purchased the Service Manual and the Parts catalog already. They show the logic board, but without any connections.
  • 666 Answers
Http://www.nodevice.com/manual/Canon/page15.html
this has both a parts list and a spec sheet
hope it helps
Robb
Posted on May 10, 2010
  • Canon Master
  • 3,866 Answers
I have a service manual to take care of this but they (not us want money for it)
pixma
-mp530-printer-service-manual">http://www.tradebit.com/filedetail.php/4593149-canon-pixma-mp530-printer-service-manual
I will keep looking and see if there are any free alternitives but I seriouly doubt that.
I sure hope this does help, please if you have questions please ask.
please do click the accept button for my efforts.
  • Grand Canyon Tech
    Grand Canyon Tech May 10, 2010
  • Grand Canyon Tech
    I do not know if those are going ot be aviable someone would have to take a part there own device to even do this.
    I gave you a service munal that basically tells you a diagram of said action. if you like i can give a you a repair shop where this can be done for e a fee.
What does the print head look like in the Canon MP530?
The print head is what's connected to the drive belt. It requires a lot of printer disassembly to get to. Check you tube for a video in how to change it.
Jul 24, 2016 | Canon PIXMA MP530 All-In-One InkJet...
Printer blinking error 6500 help
The error code of 6500 is a PCI bus error and this is a Service Error Code. Typically this is an internal error of one of the ASIC chips on the logic board and can only be repaired by replacing the logic board at the Canon Service Center.
Sep 13, 2011 | Canon PIXMA MP530 All-In-One InkJet...
My Canon Pixma MP990 stopped working. First the wi-fi light went out, and the LCD screen went dead. Then the blue light stopped coming on at all, and all I have when I plug in the printer is the yellow...
It sounds like you have an electronic problem, it is most likely a faulty scanner or logic board. although a faulty print head can take out a logic.check that there is no burning smell or damage evident on the underside of the print head before trying a logic.
the machine will require disassembly and parts replacement.
Aug 16, 2011 | Canon Pixma MP990 InkJet Printer
Canon pixma mp530 will not turn on.
Disconnect power supply and let sit for about 10 minutes, then reconnect and try again. If this doesn't work, likely the internal power transformer and/or the logic board have gone bad. If this is not under any sort of warranty any longer, it may be time to replace.
May 06, 2011 | Canon PIXMA® MP530 All-In-One Printer
Canon mp530 error 6500
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. Solution is first of all you can try to reset your printer -
  • Turn the printer off with the Power button (if available).
  • Disconnect the data cable from the printer.
  • Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
  • Turn the printer back on. If this works you're done,
If it not works then try following
  • After confirming that the printer is powered on, open the paper output tray.
  • Open the top cover and wait until the print head moves to the center.
  • Open the inner cover and check that ink tanks are properly seated.
  • Properly seated
  • Press down on each ink tank until a click is heard.
  • Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement
Best of luck
Feb 19, 2011 | Canon PIXMA® MP530 All-In-One Printer
My Canon MP530 is giving 6A00 error message and alarm light is flashing along with copy button. i have replaced empty ink cartridges with new ones. Can anyone help, please?
Error code 6A00 indicates an error occurred in the AP motor during purging operation. You need to replace sheet feed unit, logic board assy and purge unit to fix it. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 09, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP530 All-In-One InkJet Printer Canon mp530 error 6a00
Hello
Unfortunitly this is not an easy fix. IF you still have under warranty you can contact Canon and they will fix it. If its not under warranty they can refer you to the nearest Canon Service center.
The 6A00 error is an internal error which can be caused by one of the following things.
- Sheet feed unit - Logic board - Purge unit
Good Luck
Dec 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
The power went out and now my canon mp530 all in one printer won't turn on...the power supply seems fine...so what could be wrong?
You said the power supply `seems fine', have you removed and tested it? there should be dc voltage present. I cant remember the voltages, I think +24VDC, but it doesn't matter, either you have it or you don't.
If the power supply is good, then the problem is most likely the logic board, and is not worth repairing.
Oct 31, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Says Check printer 6A00. Any ideas?
[6A00] or Light blinking 12 times = AP position error. It's mean there is an error occurred in the AP motor during purging operation. You may need to replace Sheet feed unit, logic board or purge unit. Thank you
May 28, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
123 people viewed this question
old marine
old marine
