Question about Hitachi 53FDX01B 53" Rear Projection Television
PHILIPS 55PP8620 I have a problem with extreme bluryness on PHILIPS model (55PP8620). The picture twitches horizontally to the right on occasion. Anyone know why? or how to fix it? Thanks in advance.
  • 1 more comment
  • ram_rtg Mar 30, 2008
    Hi, I have also noticed that when the picture twitches to the right it shows a red line/shadow could this have anything to do with the red light globe/gun? This problem is gradually getting worse. Any help appreciated.
    Thanks
    Thanks
    Thanks
  • 927 Answers
Good Day;
It sounds like the CRT COOLANT needs replacement, it is a fluid that trys too keep the picture tubes cool , but it some times get "dirty". The fluid is called 'PROJECTION TV COOLANT', it contains; High Concentration of Ethylene Glycol. You can purchase at M.A.T. Electronics; (215) 354-7667, in PA. Part Number 212072-16.
BUY at least 2 containers. CAUTION: remove tubes from TV, just alot of plugs,remove plugs, clean "fluid" chamber, replced discarted fluid. Good Luck, big IRISH. PS more INFO; come back.
Posted on Sep 09, 2008
I have a phillips rear projection tv model no 55PP8620/79. Its showing a a red haze and poor picture quality. How do I fix this?
If the red haze is not convergence---that requires parts.
The set has three picture tubes---with set unplugged and back cover removed clean the three large lens that are topside---as for the red haze a quick way to know what is wrong is with set on turn the color to zero----what color is the screen? Should be black and white--if red to some degree tracking or screen controls may need adjusting inside the set---Yellow picture in that situation is a different issue.
Jun 05, 2012 | Philips Televison & Video
Size of phillips 55pp8620 There is no picture and
Good day!!!!
I need to know first if your TV is on standby mode (red LED lit) or not?..If the green light lit your TV your high voltage (HV) is switch but you have open line on heater that cause of no picture and the sounds is chirping because of analog(antenna)/digital connection or bad audio chips..
I need this information above for specific diagnosis and to prevent more damage and failure..Also I need this information to avoid mistakes to buy a parts with no help...
also I need the model # because on my tread there are 2 model # which are correct? is it 60PP9202 60" or 55PP8620?..for specific diagnosis and for possible get a diagram..
Thank you very much for choosing my service!!!!
Rossiel Gomez (nineng)
Jan 20, 2012 | Philips 60PP9202 60" Rear Projection...
Adding a hd set top box to 55pp8620
hdmi id the best way to go
see if it is high defition input "HDMI" or s-video or av hook ups are not high def
Mar 15, 2009 | Philips Televison & Video
Hi i won a 55pp8620 philips th eremote is not working and i have the letter F in the top right hand corner
It means the unit is in factory mode... Press both Volume Down and Channel Down on the TV itself until F is gone. Takes about 5 seconds.
Bill
Dec 21, 2008 | Philips 60PP9202 60" Rear Projection...
Colour misalignment and focus
Inside of the tube assembly, there is a cooling liquid. This could be a job to change, and then re-adjust everything. It is also possible that on top of this, there are problems with the convergence and bias control circuits.
Typical repairs can run in the area of about $400 to about $800 depending on the amount of work and type of parts required.
Personaly, I would go out and get a good Plasma or LCD TV at this point!
Jerry G.
May 21, 2008 | Philips 60PP9202 60" Rear Projection...
Philips TV Model 32DW6557/05 Screen Problem
hi it sounds like a capacitor in the verticle circuit located on the main board. it is near the verticle ic. the verticle ic also could be bad the cost is around 85 dollars for a tv shop to fix. sometime a cold joint could be found around vert ic. a soldering iron is required with solder.tap the side of tv if picture comes back it is just cold solder joint.
thanks Doctor video
Apr 25, 2008 | Televison & Video
"nervous twitching"
"twitching" horizontally stilltwitches near upper and lower edges and occasionally through the middle. the above problem is due to horizontal oscillator section . some capacitor is faulty in that section. if you are not tech. person please call tech. to fix it. it is not a major problem. also please check for little sparking in high voltage section. hope this will help. good luck.
Oct 01, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Hitachi 53FDX01B 53" Rear Projection Television Logo
94 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
