Question about Dell Inspiron 6000 Notebook
Can ac adapter run computer without battery installed
    Scholar:
  • 137 Answers
You might want to be careful doing this. Most newer laptops don't, but some older model laptops use the battery as a sort of "buffer" to help stabilize the voltage coming from the power supply. If the battery's not in place, a sudden voltage spike or surge could toast something in your computer. I know it's a hassle, but I'd recommend you contact Dell to find out their opinion on this for your particular model.
Posted on May 14, 2010
  • 977 Answers
In one word - YES!
Very handy when your battery is dead - or just very heavy to carry around... :)
If it doesn't work for you - something;s probably bad with the power adapter or with the laptop itself.
Best regards,
Pelu.
Posted on May 10, 2010
Asus a3a laptop
Probably the AC Adapter is no good....Go to e-bay and purchase a new AC Adapter for that model # notebook. But if it shows charging then try first by taking out the battery and see if the AC adapter will run the computer without the battery in it (if so, then the adapter is good, the battery is actually bad, so replace the battery instead).
Good Luck.
Nov 29, 2013 | ASUS A3Ac Notebook
Laptop reboots when ac adapter reattached.
There are three parts in the computer that you need to check.
1. Ac Adapter - it could be defective.
2. Battery - it could be that the battery and ac adapter won't work together because the battery has gone bad. We cannot tell without checking that.
3. Motherboard - it could be that the motherboard's power port is defective.
Do the following so that you can isolate the problem.
1. Remove the battery and use the Ac Adapter only and turn on your computer. If it turns on without any problem, then replace your battery.
2. If the computer still reboots with the ac adapter plugged in (no battery), then replace the ac adapter. or try using a different ac adapter which is compatible with your computer and check if it produces the same problem. If the other adapter produces the same problem, then it's in your motherboard and you need to get it fixed by a technician.
David
Jun 09, 2013 | Computers & Internet
Approximately 5 weeks ago I started getting the message when on AC power that the "smart AC adapter is not providing enough power" (something like that anyway!) And even though plugged in would...
first, you need to try to power on your laptop with another battery with the AC adaptor plugged in. if your problem was not solved you need to check the power jack on your mothernorad.
Jan 02, 2011 | HP Compaq 6735s Notebook
Few months ago I started having issues with the ac adapter it did not provided power to the unit, if you unplug and plug it again from the power cable it worked, until one day just stop. I purchased one in...
Apparently, either the AC adapter isn't compatible (check the voltages and power ratings) or you have a battery charger issue. If you're sure the adapter is OK, then the battery might wrongly report a full charge at a higher voltage than the AC adapter.
So when the battery is plugged in, it will always preempt the AC adapter - possibly even shutting it down - except that, having almost no power left, it will also force the computer itself to shut down.
What might have happened is that the faulty AC adapter actually damaged the battery. I'd suggest checking with another battery if any is available, and not to use both together lest the battery now damage the new adapter. But first of all, check the power ratings and polarity on the adapter against the old one and whatever is indicated (usually) on the PC underside, just to be sure.
Oct 27, 2009 | Gateway 6022GZ Notebook
Toshiba satellite m35
Are you sure that you fixed the power issue it sounds like there is still a bad connection in the power socket if you want info on this problem go to this site http://www.ask.com/bar?q=laptop+repair&page=1&qsrc=0&ab=1&u=http%3A%2F%2Fwww.laptoprepair101.com%2Flaptop%2F2006%2F01%2F04%2Ftoshiba-laptop-overheating%2F
Mar 29, 2009 | Toshiba Satellite M35-S456 Notebook
Battery won't charge
This is true, you will not be able to charge the battery without the correct charger. For mostly all laptops, when the charger is not maintaining a charge, it is time for a new one. However, it does not have to be the manufacturer's adapter, but I recommend purchasing the battery made for the Compaq Presario M2000 Notebook.
NextTag.com has decent deals on these adapters. http://www.nextag.com/ac-adapter-compaq-presario-m2000/search-html
I hope this helps. Please let me know if you have any other questions.
Thank You, Raph30
Jan 25, 2009 | Compaq Presario M2000 Notebook
Keeps loosing battery/power
If it will not work on AC Adapter without battery in it, then you have a bad AC Adapter and the battery is fine. You don't have to get an expensive AC adapter from the original manufacturer. Just look on the bottom of the AC adapter and write down the Volts and Wattage. You can get another at a place like Lowe's or Home Depot. But you must make sure that the Voltage matches exactly, to much voltage and it will fry your computer, to little voltage and it will not run your computer.
Dec 23, 2008 | Toshiba Satellite 2455-S305 Notebook
IBM T30 - power issues
You might try cleaning the battery compartment. Makeing sure there are no damaged pins. Often times even a single messed up pin will cause this. Also this is a very good indication of adaptor failure. If you haven't allready I suggest getting another ac adapter specific to you machine. Even a substitute will casue the same issue you are now experianceing.
Jul 11, 2008 | IBM ThinkPad T30 2366 Notebook
Battery or No
Yes it will (or should ) work without a battery, just make sure you don't unplug the connector while you are working with your computer or you will loose your work w/ no warning, laptop power cords become detached easily so be careful!
May 13, 2008 | Computers & Internet
Dell Inspiron 6000 Notebook Logo
78 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
