Question about Sony Optiarc AD-7240S 24x DVDRW DL SATA Drive Burner
Optiarc 7240 sata
I have installed this dvd burner but most of the time it is not seen by os
  • jo_barley May 14, 2010
    not sure how to update bios
  • 107 Answers
Try updating the Bios , it should work . U can also update the Firmaware of the Drive using this link
http://www.sony-optiarc.eu/supportservice/downloads/fwdownloadpages/ad7240sfwfile.html
Posted on May 10, 2010
Sony Optiarc AD7260S shows in explorer, but does not detect CD/DVD
When you insert the disk, can you hear the motor spinning the disk?
If not- the Nidec drive motor failed. It may still be under warranty or you can try to replace just the motor if that is the case.
If you are hearing it spin, something on the pickup may have failed.
Will it play an audio CD? If so, the DVD pickup failed.
Dec 18, 2011 | Sony NEC Optiarc Sony Optiarc AD7260S...
Just installed my dvd drive ad-7261s and my system could not load the driver for it. is their an fw update for this drive or is there a new driver for it.
Downloads for Sony optical-drives you'll find at http://www.sony-optiarc.eu/en/supportse ... loads.html
Optiarc AD7245S - 1.04
Optiarc AD7260S - 1.01
Optiarc AD7261S - 1.01
Optiarc AD7263S - 1.01
_________________
MCSE ThreadUtilities
please read the firmware request rules
hope this helps
May 14, 2011 | Sony Optiarc AD7261S Disk drive DVDRW (R...
Mon lecteur est en panne je veux le changer
You can change the dvd rom by opening the computer case and taking out the sata cable and power cable.
you can replace it with any SATA DVD+/-RW SATA Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136216
Windows XP, Vista and 7 will automatically install the new DVD drive for you.
Vous pouvez modifier le DVD-ROM en ouvrant le boîtier de l'ordinateur et en tenant le câble SATA et câble d'alimentation.
vous pouvez la remplacer par n'importe quel DVD SATA + /-RW SATA Drive
Windows XP, Vista et 7 installera automatiquement le nouveau lecteur DVD pour vous
Mar 01, 2011 | Sony Optiarc AD7240S DVD?±RW (?±R DL) ...
My writer is ot showing in my computer
In any SATA device the data cable becomes hard after being used for some time. Try replacing the data cable with a fresh one and it should solve this problem, provided the power supply to the drive is present (check if the drive tray is operational when the PC is powered on). A bend on the data cable also results in the above symptom. Best replace the data cable.
Nov 10, 2010 | Sony Optiarc AD-7240S 24x DVDRW DL SATA...
I have a Optiarc DVD RV Ad-1560A that is not reading my cd's I cannot play my mucis cd's
try and install the dvd driver and make sure to install a software that can interact with your pc like win dvd that will enable you to watch movies on your pc
Oct 08, 2009 | Sony Optiarc AD-7170S Burner
How to install driver vista ultimate my dvd & cd not work on vista
Here's a link for firmware and software for the optiarc.
http://www.downloadplex.com/Drivers/Firmware/Sony/Sony-NEC-Optiarc-AD-7170-S-ATA-Firmware-1.03_105120.html
Bill B.
San Antonio
May 16, 2009 | Sony Optiarc AD-7170S Burner
Optiarc DVD-RW AD 7560A - well recording CD-ROMs, but not DVDs
i had the same problems so i updated the firmware for the cd/dvd drive and now its working perfectly
Jan 01, 2009 | Sony Optiarc AD-7170S Burner
NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mike
Mar 22, 2008 | Abit NI8-SLI Motherboard
Sony Optiarc AD-7240S 24x DVDRW DL SATA Drive  Burner Logo
401 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
