Question about Nintendo DS Lite Console
DS won't start
Replaced housing on my ds lite because of broken hinge. now when I power it on green light comes on bottom screen flashes on for a second and goes back off. can anyone help?
SOURCE: Nintendo ds hinge fix
My sons ds hinge broke and i taped the console, he removed the tape and eventually he broke the cable and the black wire. we bought another case and a new cable and replaced them both and now the ds only flicks on then goes off. we assume its the wire,as its a small coaxial one,we soldered it together. it charges fine but wont power up any more,we have tinkered with it so many times and cant get a result. I am currently trying to find a repairer to look at it. I dont recommend repairing it yourself to save money, put the money towards a repairer.
Posted on Oct 13, 2007
SOURCE: Nintendo DS Power problem powers on but goes straight off
You may have not put a connector back on properly....
http://www.instructables.com/id/Replace-the-top-screen-of-a-Nintendo-DS-without-o/
Go there and read it through - there are also other walk-throughs for repairs on this site that are very thorough.
Best of luck
Posted on Dec 25, 2007
  • 125 Answers
SOURCE: Broken DS Hinge
No, there is too much pressure. But you can buy new cases. I have fixed three this way. The procedure is not for the squeemish, but here is how to dissassemble it:
http://www.youtube.com/watch?v=vRzTgfo2PsM
Cases are available on ebay or many gamer sites. You will also need a triwing screwdriver, also available in the same manner.
www.gamersection.ca is one example, but certainly not the only.
If you want to do this and you are not handy, I strongly suggest you find someone who is.
Posted on May 10, 2008
SOURCE: Nintendo ds lite not turning on
see if you need new carger or if it needs new batteries
Posted on Jun 27, 2008
SOURCE: Broken nintendo ds lite hinge
Nintendo will fix the hinges depending on a few things, first thing would be to determine how the hinges were broken. The hinges are tested before they leave the factory, the only way that they actually break would be because of physical damage/impact. Physical damage is not covered under the manufact warranty so you would get a discounted price depending on if your under warranty or not. Regardless giving them a call and having their techs fix them will be the best bet, not only because you know it will be fixed right and your warranty will start over the day it gets repaired.
Posted on Dec 26, 2008
My ds lite power gooes off as soon as you turn it on
The bottom screen flashes an then the green light goes off new top screen is needed very common on ds lite i repair them for a living an can sort yours for about 18 quid
Simon
Dsdoc
Nov 26, 2011 | Nintendo DS Lite Console
My sons ds lite will not turn on the green light comes on and a white light flickers on bottom screen and thats all, I changed the battery and still no luck. Help! thanks
it's likely that the top screen ribbon cable has either become damaged or loose, the entire top screen will probably need replacing (along with the casing if the hinge is broken).. if you are not confident with technical or fiddley things I wouldnt recommend attempting it yourself.
Jan 08, 2010 | Nintendo DS Lite Console
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
My sons nintendo ds wont turn on, when we charge it, turn power on , the green light comes on and bottom screen blinks for a split second then goes dead.. Is this fixable , if so what do i try??? thanks
yes it is fixable sounds like your fault is with the top screen are the hinges ok has it been dropped.
most green light and screen flashes point to a defective screen or connection on the mother board or sometimes fuses. id start with checking the motherboard connection if its ok check the fuses if all is ok buy a new top screen and replace it.
Jun 30, 2009 | Nintendo DS Lite Console
DS Lite Top screen is all white after replaced for new one
you should use a crystal casing because every time you open the ds the wires get messed up or put some thing on the hinge so the ds hinge will not get loose.
May 12, 2009 | Nintendo DS Lite
Nintendo DS Lite Broken Right Hinge & failure to stay powered on
the nintendo DS IS A *******!!!!!!!!!!!!!!!!! PIECE OF **** YOU ******* ****
Feb 07, 2009 | Nintendo DS Lite Console
Nintendo ds lite has a broken hinge
You can buy a new plastic housing for your DS lite on many different sites. Some are great quality. If the DS still works (despite the broken hinge) it makes sense to replace the housing.
You should be able to find enough videos on youtube to learn how to disassembe the DS and not do any harm. Make sure that you buy a tri-wing screwdriver (also called a nintendo screwdriver).
Hope this helps
Dec 23, 2008 | Nintendo DS Lite Console
Jun 26, 2008 | Nintendo DS Lite Console
Ndsl power problem
As Bob (HowlingMad) said, the Ds and Ds Lite will turn off immediately after being turned on if the connection to the top screen is broken.
Check the connections between the screen and Ds, if they look damaged then try replacing the ribbon cable for the top screen (or you may have to replace the whole screen - i'm not sure if it is built together on the Ds Lite). If the connections appear fine then it may be that due to the movement the connector has come out of it's socket/plug (also like Bob said), this is easily fixable if this is the case and would require you to take the casing off your Ds and plug it back in.
Hope this helps
Mowcius
May 07, 2008 | Nintendo DS Lite Console
No power and battery is charged
try going to game stop they sell ds or ds lite batiers i think thats the problem
Nov 19, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
56 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
