Question about Braun Activator 8595 Electric Shaver
Clean and Renew stand for braun 8595 does not seem to cycle properly...after shaving and placing in unit, it randomly seems to clean and is stuck on cleaning cycle (normal light blinking, no charge) I then remove the shaver and put it back in and it shows clean and begins charging...
    Novelist:
  • 124 Answers
The circuit board on the shaver may have become faulty. One thing you can try is to fully charge the shaver first, directly connected to the outlet, and then try using the cleaning base. Also, be sure that the fluid level is sufficient. Lastly, you may be able to buy a used but working condition cleaning station off of eBay. New replacements are a bit costly.
Posted on Nov 07, 2010
  • IwatchYuTup Sep 09, 2013
    has circuit board something to do with the cleaning system? how does cleaning process work? is there any software involved? my shaver had a problem with charging using the cable only and I gave it to a service to repair. they repair it but this time, It wont clean. I recognized that after they repaired it, display menu looks different. Can it be something to do with that?
Braun 8595 screen does not work. Where can I get a replacement? and can I replace it myself?
You say 'it does not work. You mean it doesn't shave well, or not work at all. If it doesn't work at all, you need to send it for repair to the local authorised dealer where you live.
If it is just the LCD screen, you will need to have it serviced. The problem is getting into them. You need to remove the correct hidden screws and press the case in just the right places using a tool called a 'budger'.
The foil and cutter block come as a kit and are very easy to replace. Remove the foil and pull off the cutter block. Replace with new. The problem is going to be getting one though. I get mine from Amazon for my 7 Series. Although
I live in Canada, they come from Ireland in 7 days.
Let me know if you need any further help by clicking COMMENT under my name.
braun 8595 replacement foil and cutter Google Search
Repairs
Braun 8595 repairs Google Search
Jul 30, 2017 | Braun Health & Beauty
After not shaving for anything more than one day, my 8595 seems to bind up when I try to shave. Unless I move it very slowly, it sounds like it's "stuck" and it pulls my whiskers if I move the...
Ali decides to invest a certain sum of money in business atthe end of each year in the form of an annuity. He wants to get a sum of Rs.40,000 after 20 years. If the payments accumulate at expected profit of 8%compound annually, how much should he start investing annually?
Jan 13, 2011 | Braun Activator 8595 Electric Shaver
Making a funny noise and not shaving well
8585 shaver gave higher tone and stopped cutting especially after a few days growth, even with new cutter and foil. Cutter wasn't pressing against the foil properly due to a bit of wear on the spring clip holding the cutter pin. Fixed with about 1cm of cigarette paper moistened and rolled into a 1-2mm ball. Stuffed that into cutter pin hole and rammed home with the cutter pin. Take the foil off and wiggle the cutter - if its feels loose, this might help, though the battery might just be getting old.
Jul 10, 2010 | Braun 8585 Electric Shaver
Can I repair a cleaning unit (5468) for a Braun 8595 shaver? I think I pulled it out before releasing it from the clean function!
Does the cleaning station no longer recognize the shaver? If so, it's possible that the contacts have been bent out of position. It's a bit tricky to fix, though. You'll need to take the unit apart and then bend the contacts back into position. Alternatively, you can buy used but working examples of these cleaning stations off of eBay.
Apr 15, 2010 | Braun Activator 8595 Electric Shaver
Braun Clean and Renew not working
I took the file on a nail clipper and turned the impeller inside the unit. Remove the cleaning fluid from the unit. Turn the unit upside down, On the part that sticks into the large hole of the fluid reservoir you'll see the impeller. Just turn it it enough to dislodge any whiskers and try it again. Worked for me. Good luck
Jan 10, 2010 | Braun Health & Beauty
Braun 8595 clean and renew will not charge or clean my razor, in fact it just ignores my razor
it sounds like your clean and renew base will need to be replaced. you will find a replacement at shaveroutlet.com
Dec 17, 2009 | Braun Activator 8595 Electric Shaver
Braun 8995 clean and charge stand
Use your Warranty. Or you could simply buy another one and return the Lemon one with the reciept for the new one.
Aug 17, 2008 | Braun Syncro 7526 Electric Shaver
Cleaning base
I have been shaving with electric razors for 48 years, and the Braun 8595 is by far the best one yet.
I have had the problem of the refusal of the cleaning station to recognize the level of fluid in the cartridge, three times over the last couple of years. It seems to relate to a build up of shavings in the unit. To get it working again I inverted the unit, and carefully flushed water via a small tube, back through the 1cm diameter hole in the underside of the open base. Of course, the unit must then be thoroughly dried before use, or the sparks may fly. Does anyone know how to dismantle the unit for a safer and more thorough clean?
Oct 27, 2007 | Braun 360° Complete 8985 Electric Shaver
Braun Activator 8595 Electric Shaver Logo
1,036 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
