Question about Acer Extensa 5620 Notebook PC
I am trying to replace a hard drive in my Acer Extensa 5602Z and when I start it up it says Broadcom Error cannot find media cable. When I go into the operating system recovery it says no partition. How do I get this machine to recongnize a new hard drive. The new hard drive shows up in the bios but cannot be used.
frankzjm
  • 191 Answers
SOURCE: My acer 5620Z laptop cannot find its operating system
you can do check HD follow me:
1) open the cover at back of laptop
dc0d736.jpg 2) take out HD body see picture
5d35e3d.jpg 3) put it back in same way, then power on if bios find HD, the error message should be gone.
4) if still show error, you need change other HD, till the bios find out HD drive.
here you can download the service manaul to reference.
hope you fix it well, any question ask me any time please
Posted on May 14, 2009
  • 108 Answers
SOURCE: ACER 5315 IS DEAD ON BOOT UP IT DISLAYS
Sounds like it is trying to boot from network drive. Have you changed the bios boot order. If so, change it back to boot from hard drive first.
Posted on Jun 10, 2009
pagebor
  • 2785 Answers
SOURCE: rest bios Password acer extensa 5620z
plz check the link
Posted on Jun 22, 2009
  • 52 Answers
SOURCE: acer extensa 4630z windows complete restore
I wrote to Acer myself about this and this is their reply.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
durtopian
  • 408 Answers
SOURCE: media test failure, check cable
Go into the bios and reset everything to its defaults.It sounds like its trying to do a network boot and failing
Posted on Oct 18, 2011
If you starts it, there is black screen with the message: media test failure
Go into the BIOS settings at boot up. Disable the option to boot from network, that must solve it :)
May 27, 2014 | Acer Aspire 5100 Notebook
I have a fiujitsu hard drive in my acer aspire 5315 my keyboard has no keys just some rubber tips and when i turn on its says broadcom UNDI PXE-2.1 v10. 0. 9 copyright yada yada and then it says: PXE-E61:...
The keyboard needs replacing. Replacement keyboard for your laptop maybe available from this WEB site.
PXE-E61 ERROR
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Dec 18, 2012 | Computers & Internet
I have a Acer Aspire 7741Z-5731 and when I turn it on this is what it says: Broadcom UNDI PXE-2.1 v12.2.2 Copyright (C) 2000-2009 Broadcom Corporation Copyright (C) 1997-2000 Intel Corporation All rights...
When you start your PC it goes through a power on self test (POST) procedure to make sure all the hardware is working and there are no compatibility issues. It looks like some of your hardware has failed. This could be the hard drive that has failed, or possibly the RAM. One thing to try is remove the RAM, clean out the bay by blowing or using compressed air and reseat the RAM. Try it in a different bay or if you have two sticks, try replacing one at a time and try to boot the machine each time. Another thing you can try is booting to BIOS (your machine should tell you which button to use to enter setup when it starts, possibly F2) and check the info tab to see if you can see all the drives listed. You should probably see at least two, the hard drive and the cd drive. If you don't see the hard drive then it's probably failed.
It may be best to take the machine to your local PC repairer to have it checked.
Mar 29, 2012 | Acer Computers & Internet
I tried to download windows 7 on my ACER 5351, and near the end the laptop restarted. It came up with this error code : Cannot boot from CD: Code 5. When I took the CD out, the following error code...
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Aug 11, 2011 | Computers & Internet
PXE-E61: Media test failure, check cable PXE-M0F: Exiting Broadcom PXE ROM Operating System not found Acer Travelmate 5720G
This error is a result of your computer not finding the operating system. This is usually the case when the hard drive has failed. You will need to take the computer to a technician to replace the hard drive and have windows reinstalled.
Mar 06, 2011 | Computers & Internet
Went to shut down comp. and screen said, and still is. broadcom undi pxe-2.1 v11.4.1 copyright [c] 2000-2008 broadcom corporation copyright [c] 1997-2000 intel corporation all rights reserved. ...
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system.
"Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
Dec 05, 2010 | Acer Aspire 5610-2328 Notebook
Broadcom UNDI PXE 2.1 v11 . 4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel Corporation All rights reserved. Broadcom Base Code PXE- 2.1 v1.1.0 Copyright (C)...
This is showing because the computer is not seeing the hard drive that contains the operating system. In some cases this is because the hard drive has come dislodged from the interface on the motherboard. Dells are good for this because the hard drive slides into the side of some models. Try reseating the hard drive and reboot. Your worse case scenario is that your hard drive has failed. The reason you are seeing the PXE-MOF etc. is that the laptop ias now looking for a network hard drive to boot from. It can't find the intenal hard drive so it is searching for other means to boot.
Jun 16, 2010 | Acer Aspire 3690-2196 Notebook
Acer 5620-6266 notebook will not boot--Media Test failure
Open BIOS and configure your boot devices priority. First boot device should be the hdd. Also check if the laptops see the hard disk, i think your hard disk have a problem and thats why laptop wants to boot from network.
Jul 18, 2009 | Acer Extensa 5620 Notebook PC
May 13, 2009 | Acer Extensa 4620 Notebook
ACER BOOT
Sounds like your hard drive may be bad or has become disconnected from the system. If your handy working on computers then I would make sure the hard drive is seated correctly. The last part of the error message sounds like your computer is trying to boot from your network interface because it can not find the hard drive.
Dec 30, 2007 | Computers & Internet
Acer Extensa 5620 Notebook PC Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
