Question about Kenmore Microwave Ovens
The timer works, but the heat does not work? - Kenmore Microwave Ovens
  • 1 more comment
  • duke5551 May 10, 2010
    The timer and other controls work fine, but the mag. does not come on and heat. Kenmore model 99701
    CAN NOT READ THE schematic, it is too small
    this is a kenmore model 99701
    Guru:
  • 415 Answers
Start with testing all of the internal door switches by ohming them out. Also inpsect for any loose wiring or wiring or connections that appear abnormal (such as from overheating).
Do you have a make and model of your microwave oven?
Posted on May 10, 2010
  • laura Newman May 11, 2010
    I'm not having any luck locating a Kenmore Microwave with that model number. Try using this Troubleshooting Guide to test your transformer and magnetron. Let me know what you find out. I look forward to hearing back from you. :-)
  • 668 Answers
This type of diagnosis will require accessing the EOC, electronic oven control & making some voltage checks with a volt meter. We need to know if you have 240volts coming in & going out of the EOC. If you have a volt/ohm meter please see the wiring diagram provided in the link below. L1 to L2in has to read 240volts. Turn the oven on to bake & check for 240volts from L2 out to BK. If you do not have 240volts I recommend replacing the EOC. If you read 240volts then I suspect a wiring problem between the EOC & oven elements.
Remember to use extreme caution when working with live voltage.
Link to wiring diagram
Hope this helps .
  • Kenmore Master
  • 17,970 Answers
Its likely your Electronic Clock/Oven Control Board went out.
Here's the one for sample model: Clock/timer
Instructions are not included, but its very easy to change out, just pull your range out from the wall, unplug it, then take off the back console panel #56 here: http://www.searspartsdirect.com/part...2102-00001.png
Then your electronic clock assembly is #20, its mounted with 4 screws, just remove the screws, make down down on paper were your wire connections go to, then just install the new one.
Also take the face plate #20A off the old one, and put it on the new one, it just sticks in place.
Check your right part model across info with your right model device. If it doesn't fix your range just return it within 30 days for a full refund.
Hope help.
Everything working but no heat
Timer working but not heating - Microwave - iFixit
https://www.ifixit.com/Answers/.../Timer+working+but+not+heating
iFixitMy fridgadire microwave oven is not heating, it acts like it is heating by the timerworking and .... I have a GE Profile and everything worked but it would not heat.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
If the water is not consistently warm, you've confirmed there's a problem. ..... Everything works except the microwave- it wontheat anything up. ... How to Fix a Microwave Oven - Simple Fuse Replacement - Duration: 18:04. by
Nov 28, 2015 | Electrolux E30SO75FPS 1000 Watts Microwave...
Timer panael,light fan,,auto off,,every thing ok,,but no heating
I had a problem similar to yours and I thought somehow I had ruined the microwave oven. Try unplugging it for about a minute and then plug it back in. My service tech did this and it worked fine after that. Then he billed me $110.00 for the service call.
Feb 11, 2015 | In Microwave Ovens
I have a GE JES831WB 001 microwave that I'd love to fix. The light, clock & timer are working, but that's all - no fan nor heating. Any suggestions?
The door switches are often a problem, one or two are probably defective which would cause the symptoms that you are describing.
Apr 05, 2012 | Microwave Ovens
MMV4205 1150 Watts Microwave Oven: all boards and timers work will not heat food m...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
syjs
May 18, 2010 | Maytag MMV4205 Microwave Oven
Not heating or defrosting although light works, timer etc works
heatman101
fjfh
May 11, 2010 | Neff H5470 Microwave Oven
Microwave Model JVM 1870 stopped heating, all else works (timer)
heatman101
ggk
Nov 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson MW9111 will not heat- all timers & clock work
Normally when you take the cover off, the fuse will be on the right of the oven on the circuit board.
Sep 10, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
Jul 02, 2008 | Microwave Ovens
Microwave Ovens Logo
47 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
