Question about Samsung CLX-3170FN All-In-One Laser Printer
Samsung CLX3175FW Goes Offline
I use the wireless connection with my CLX3175 rather than hard lead. Periodically when I go to print a document it says that there are netweork problems. When yuo search for the printer you find that it is offline and there appears to be no way to get it back on line again. The only solution is to reinstall the printer driver again.
This seems to happen when I take my laptop away from home and then return.
Open the "Devices and Printer" dialog, select "Printer Properties" from the context menu and go to the "Ports" tab. It seems that somehow your printer doesn't always get assigned to the same port. Try checking the correct port and your printer will be online again.
Posted on Jun 04, 2010
Testimonial: "Thanks so much. This is great help."
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 35 Answers
Samsung CLX3170 / CLX3175 Printer Reset n Refill Toner Cartridge Easy
www.chipresetters.com
email: pateltraders@gmail.com
skype: indianrefiller
msn: howtorefill@hotmail.com
Posted on Sep 07, 2010
POwer botton flashing light.. cant print and the status is offline.. how can i fix this problem pls help
The flashing light is because the printer will not print if it's offline. Be sure the printer is connected to the Internet. It may be offline because you have tried to print too many documents. If that's the case, you will need to delete all the documents that have been sent to the printer and haven't printed. Don't delete the actual document from your computer, but from the print queue. Hope this helps.
Nov 20, 2017 | The Office Equipment & Supplies
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
HP LASERJET P1606DN goes to offline
Happened on our print server this morning for the first time. We have 4 of 1606dn in our organization. Reset the print spooler and that brought it out of offline mode
Jan 09, 2012 | HEWLETT-PACKARD LASERJET PRO P1606DN...
ML1865W offline
Try disconnecting the printer completely from power.
Reboot your system and re-connect the printer again.
Check for paper jams and clear them.
Delete any print queues.
Hope it helps.Thanks!
Jan 05, 2012 | Samsung ML1865W Laser Printer
My canon mx340 will not print from my laptop wireless....keeps saying offline
Is the Printer switched on? Do you have enough rights to use the printer wirelessly? Have you printed documents over your wireless connection previously?
Mar 15, 2011 | Canon PIXMA MX340 Wireless Office...
Printer is offline how do I get it online?
Try to print. Once an error appear on your computer, right click the printer icon on the taskbar and click open printer connection.
Printer window will appear.
Highlight the pending print job. Click the File menu and uncheck the Print Offline.
Right click on the pending print job and select Restart printing documents.
Jun 23, 2010 | Canon PIXMA MX340 Wireless Office...
Printer offline HP 4500 series wireless.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 31, 2009 | HP Photosmart C4580 All-in-One InkJet...
Samsung CLX-3170FN All-In-One Laser Printer Logo
3,045 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
