1997 Saturn SL Logo
Posted on May 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IT TAKES ME 15 MINUETS TO GET TO WORK BY THE TIME I GET THERE OR MY CAR IDLES THE TEMPERTURE GAGE GOES UP HALFWAY OR A LITTLE HIGHER,I TURN AC OFF TURN HEATER ON UNTIL TEMP COMES DOWN WHY IS THIS.
Anonymous
Level 2:
Sergeant:
  • Expert 196 Answers
  • Posted on May 10, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
196
Questions
0
Helped
76219
Points
502
THE TEMPERTURE SENSOR IS BAD CAUSES BOTH
1986 dodge d100 225 engine dodge oil light goes off when idle stays on when giving it gas
It sounds like the oil sending unit is bad. the safest way to check it is to pull out the sending unit and install an oil pressure gage directly to the motor start it up, bring the RPMs up and see what the oil pressure is. Ideally you want at least 15 psi at an idle and prefereably anything above 25 psi at crusing RPM.
Jumping Idle, Unstable air temp and running hot
Yes it helps the A/C when stoped at a stop light idling . the cooling fan coming on pulls air through the A/C condensor taking away the heat . Before replacing the fan , check to see if it is indeed bad by jumping the socket where the relay plugs into . Pull the the relay an look on the bottom , you will see four sets of numbers 30 &87 plus 85 & 86 . 30 & 87 are the two you want . Take a paper clip or a piece of 12 gage wire an jump 30 to 87 if the fan runs it's OK if not replace it . Just replaced fan on my 05 cavalier last summer .
Have code 0463 fuel levelcircut input high what do I look for
There is no module under the dash on your vehicle .
P0463 - Fuel Level Sensor A Circuit High Description: The powertrain control module (PCM) monitors the fuel level input (FLI) circuit for electrical failure. The test fails when the signal moves above the maximum allowable calibrated parameter for a specified fuel fill percentage in the fuel tank. Possible Causes:
  • Fuel pump (FP) module concern
  • Incorrectly installed fuel gauge
  • Damaged instrument cluster
  • FLI shorted to VPWR
  • CASE GND circuit open
  • Overfilled fuel tank
  • Damaged fuel gauge
Diagnostic Aids: See the diagnostic aids for DTC P0460. Application Key On Engine Off Key On Engine Running Continuous Memory Ranger GO to Pinpoint Test HX . All others Refer to the Workshop Manual Section 413-01, Instrument Cluster for fuel level indicator diagnosis.
You start by taking to Dealer or someother qualified repair shop .
Instrument Cluster Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1202 Fuel Sender Circuit Open Instrument Cluster Go To Pinpoint Test B . B1204 Fuel Sender Circuit Short to Ground Instrument Cluster Go To Pinpoint Test B .
2answers
Engine idles fine till you turn on a.c. then slow & shakes badly
Hello good sir or mam
So here is goes when you turn on your ac system you put a harder load on you engine as it engages the ac compressor clutch. That being said if you are low on freon your ac compressor will be harder to turn as refrigerant contains oil for your system too.
You may also want to check your serpentine belt as a worn belt will cause this to look for frays,cracks,or a depth Gage. also you may need a tune up check your spark plugs,igniton coil, and or distributor cap & rotor if applicable older models.
You may also need to replace your idle air control valve as it can definatlly cause this
well i hope it helps if so please leave 4 thumbs up
Ford Taurus Part # WT724
sounds like the gauge and sensor r workin properly....but you do have to address that coolant leak...that causes your temp to fluctuate cuz you cooling capacity is being reduced
Temperture gage not working
If you unplug temp sending unit and turn ignition on check guage. It should read all the way hot or cold. If so then replace temp sending unit.
1990 Honda Prelude. Low idle after warm up.
Hopefully fixed the problem by setting the idle a little higher. I think the IACV is ok.
Problem with idle
engine coolant temp. sensor is probly cracked it will cause the idle to race, car may smoke, and at time could be hard to start.. It is about 15 dollars, and it is located on the right side of the head if you are looking at the engine.. pull it out you will be able to see if the tip of the ceramic tip is cracked.
15helpful
3answers
No Heat in 99 Taurus
Just finished fixing my daughters 1999 taurus heat. It would blow warm only when running down the road. At idle it blew cold. I started with replacing thermostat, and water pump because they are the easier fix. Still did not help. Then I replaced the heater core. A daunting job but not that hard to move the dash slighly out of the way to replace. There is a good write up at tarusclub.com. After that, heat was better but at idle, it would still blow cool sometimes. Researched and found answer. Park car on the steepest hill you can find with front of car up. Start car and take off reservoir cap. Let car warm up and keep rpms about 1500. After a while the fluid will come running out of the car and all over the place but it will bring air bubbles with it. Reduce rpm, add more fluid and repeat about 3 times. It will make a mess but after that, the heater works perfectly. We get heat long before the temp gage indicates any and it never blows cold unless you lower the temp.
1989 Honda intermittent cooling problem.
need to know how to change the fuel pump, do i have to drop the fuel tank or can i get to it from under the back seat
Top Saturn Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Expert? Answer questions, earn points and help others
