Question about GE Profile PSC25MSWSS Stainless Steel Side by Side Refrigerator
3 Years old GE Profile PSC25MSWSS Side-Side Refrigerator - refrigerator side not cooling, currently at 43 degrees although the set point is at 37 (recommended). Freezer side is working fine, Express Chill working fine, Turbo Cool not working. Unplugged and replugged from wall but problem persist.
  • GE Master
  • 19,396 Answers
Hi.
To start ensure that there is no problem with the defrost system. This is the most common cause for poor cooling, and will affect the fridge section more than the freezer section. A way of testing the defrost system is by leaving the unit disconnected from power for 24 hours, allowing full defrost.
If the unit is cooling regularly after defrost, that means that defrost system is malfunctioning or that damper fan was blocked by ice.
If the problem is the defrost system, then the fridge section will restart malfunctioning within few days or weeks.
If immediately after full defrost the fridge is still not cooling , then the problem can be a faulty damper fan, a faulty electronic temperature control, or a wiring problem. A problem with compressor on a three years old fridge is quite unlikely.
If defrost system was not causing the problem, then the fridge will still display the same problem after complete defrost.
If problem is defrost system, then parts to be tested are:
Defrost thermostat - If it is faulty it will read no continuity when using a multimeter to read impedance. Test must be done at room temperature. The thermostat can also be tested by jumping its contact.
Evaporator - See here for test and repair
heating element - It must have continuity.
Fan - the motor is tested jumping contacts and energizing it directly.
Here parts and diagrams for your appliance:PSC25MSWASS.
See here how to locate parts and diagrams from more sellers: Where do I find parts and diagrams?
Here also an old solution I wrote for a Kenmore side by side. Things are slightly different on your GE, but the article explains how to test element, fan and thermostat:side by side is not cooling , and...
To contact an authorized technician or to check warranty status call the manufacturer at the number listed on the owner manual.
Calling GE you can also find out if parts are still under warranty. Parts warranty last longer than repair warranty.
See also GE Appliances Service and Support
Regards.
Ginko.
Posted on May 10, 2010
GE Profile Side-by-Side Refrigerator - Freezer Warms Up - Motor Gets Loud - Eventually Cools Back Down
Sounds like your thermostat is faulty this should be covered by a warranty This problem eats electricity so will need attention asap
Oct 29, 2012 | GE Profile PSHS6MGZSS Side by Side...
Fridge side working but only cooling to 50 degrees
My 14 years old GE profile refrigerator keep cooling above 50 degrees and not going down to below 40 degrees. I did clean condenser coil and fans are running fine. I adjusted temperature control to maximum cold .Do you think it my be short of refrigerant?
Jun 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model. http://appliancehelponline.com/sxsfreshthermistor.html
Jul 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Side-by-Side Refrigerator gets to too cold
turn the temp setting up to40 then check in a couple of hrs
Nov 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Jun 08, 2009 | GE PSS25NGM Side by Side Refrigerator
Both Freezer and refrigerator are not as cold as they should be
We may need to look at the control circuit board the back of refrigerator if the refrigerator has stopped cooling. Let me know if the compressor is running or not. Let me know, I have a repair manual if you like.
Thanks, Sea Breeze
Apr 21, 2009 | GE Profile CustomStyle¿ 22.6 Cu. Ft....
Profile refrigerator section not cooling
We are not sure what precipitated the temperature swing up; however, within about an hour of emptying quite a lot of foodstuffs from top and bottom sections of the unit, I felt the cold air start to flow out of the rear vent. Within two hours, the upper section had dropped to about 50 degrees and by the next morning to 36. The freezer seemed to recoved on its own too, having risen to almost 8 degrees and then recovering to 0. Just patience and a smaller food payload?
Oct 02, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile  PSC25MSWSS Stainless Steel Side by Side Refrigerator Logo
128 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
