Question about Casio FX-300MS Calculator
Calculator i have a problem were all numbers i put into my calculator come out as fractions instead off proper answeres how do iresolve this???
  • Anonymous Sep 15, 2008
    the default answer display is a fraction (100/7 shows 100 over 7) instead of 14.2blahblah. I have to press the S<-->D to show decimal. How do we get default display to be decimal? Reset doesn't work.
  • 3 Answers
Turn on your calculator.
hit (shift) (clr) and number (3)
screen on your calculato will appear as (RESET ALL) hit (=)
your calculator is as good as new.
You are good to go.
Naveen
Posted on Mar 28, 2008
SOURCE:
How do I put this calculator into regular math mode. When I ask it to solve 25/5 it gives me a fraction??
After calculation, just press key [SD] to display it as decimal number.
If you want to see solutions as decimal numbers press [SHIFT][MODE][2].
Please rate my answer if I helped you :)
Sep 07, 2011 | Casio FX-115ES Scientific Calculator
My new casio fx-300ES calculator outputs answers as a fraction... how can i change the output to a decimal point?
To change a displayed result into a fraction, press the [S=D] key.
To force a result to be displayed as a decimal number before it is displayed, press [SHIF][=] instead of [=].
Aug 15, 2011 | Casio fx-300ES Calculator
It is showing fractions instead of Decimals when i do equations like (4 divided by 9) it gives 4/9 instead of the decimal.
Calculation results will be displayed using
fractions, r, and ?. When you press CHANGE, the display will cycle
through the following display styles:
• Mixed fractions (with or without ?) ? improper fractions (with
or without ?) ? decimal numbers
• Proper fractions (with or without ?) ? decimal numbers.
Feb 03, 2011 | Sharp ELW535 Calculator
How do you do a fraction on a sharp el531w
Hi eamon at hom,
Doing fraction on the Sharp El 531W really isn't that bad. I had to use pictures because, the symbols will not transfer over to your posting for me to show you. When you select the [ON/C] this clears the calculator of previous calculations and, data so that they won't interfere with your new calculations.
Let take the first example where a mix number is being added to a improper fraction. Because I used the [a^b/c] key this makes the calculator display the answer in a mixed fraction format or, a proper fraction format. If I press the [a^b/c] key again after the answer the format will change to a decimal format. The fractional formats are displayed in a mixed number, improper or, proper fraction formats. A improper fraction is really a proper fraction number with the top number (numerator) is greater than or equal to the bottom number (denominator).
[ON/C] [3] [a^b/c] [1] [ [a^b/c] [2] [+] [4] [a^b/c] [3] [=] mixed number results. Now let's do the same calculation as a improper or, proper fraction format.
[ON/C] [7] [a^b/c] [2] [+] [2] [a^b/c] [3] [=] still a mixed number result. Even though I enter the fractions in a improper and, proper fraction formats the calculator will still display in a mixed number format. This is because the calculator first displays as a mixed number if it can. If it can't then it will display the value as a proper fraction and, never as a improper fraction. To convert from a mixed number to a improper fraction format if the calculator did not convert it to a proper fraction, I have to use [2ndF] [d/c] keys on the command line.
This show a little more complex raised power use of the [a^b/c] key.
This shows the [2ndf] [x^-1] keys being used to calculate fractions.
When I first saw this question being asked it, was answered with just use the / command. Which that isn't really a good answer because, in math we like to use elimination. If you use the / command eventually the numbers are going to be rounded off and, your not going to be able to eliminate anything. If you have any further question on how to preform fractions with this calculator be sure to post your comment and, I'll be glad to help.
Jan 13, 2011 | Sharp EL-501WBBL Calculator
How do I get a fraction as an answer instead of a decimal?
The TI-83 can only convert a small range of numbers to a fraction. To try so, use the >Frac function on the MATH menu. Press MATH 1 to invoke it.
Oct 25, 2010 | Texas Instruments TI-83 Plus Calculator
Reset calcuator
try this, press shift mode, then line 10. It will make it permanent. the answer will always be in decimals. if you are using a casio with ES models.
Jun 14, 2009 | Office Equipment & Supplies
Mixed numbers
Proper fraction e.g. 3/5, input 3, divide, 5, =, answer 0.6
Improper fraction, either enter as improper fraction, or enter the whole number first, then +, then the proper fraction as before, then =.
E.g. 8/5 which is "1 and 3/5': enter 1, +, 3, "divide", 5 =, answer is 1.6
Or, just 8, "divide", 5, same 1.6 answer. Why go to mixed number first?
13/5 which is "2 and 3/5", enter 2, +, 3, "divide", 5, =, answer is 2.6. Or, just 13/5, same answer
Dec 17, 2008 | Texas Instruments TI-30XA Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
Fraction problem
follow the following sequence of steps
mode>exact/approx and then select approx
Jun 05, 2008 | Texas Instruments TI-89 Calculator
Fractions
When performing the calculations, put the fractions in parentheses. Then once you get your answer, press 2nd and Math (above the times button). Then press F5, MORE, and F1. It will have Ans Frac>. Then hit Enter and it'll change it to a fraction.
Feb 03, 2008 | Texas Instruments TI-86 Calculator
Casio FX-300MS Calculator Logo
100 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Ekse
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
