Question about Remington Polesaw Wizard
Broken oil reservoer cap, how do i get a replacement?
I have 2 remington pole saws. they work wonderfully, but i need a replacement cap & bulb assy.
how do I order one?
    President:
  • 2,220 Answers
Are you aware they are no longer in production?
Find it here (probably "NLA" or "Back Ordered"):
Over the years the size of the cap has changed. There is only one cap available and replacement tanks to fit the current are NLA everywhere. I suggest you talk to a living breathing human on this, it may save a headache later.
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
If "NLA" or "Back Ordered" try here.
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
There was a 3 pack available the last time I checked.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 10, 2010
"Campbells Supply" can get them. It is where I got mine and it works perfect.
Posted on Dec 04, 2012
Am I wise to purchase a Remington Pole Saw or should look for another manufacturer? Which Remington Pole Saw would you purchase: a. 18V Cordless b. 10" Electric
Remington Saws have ceased operations and, unless you like to make your own replacement parts, they are prone to failure. The gearbox is sealed and the motor brushes are not available anywhere. Look elsewhere!
May 11, 2010 | Remington Electric Pole Saw
Remington electric Pole Chain saw - what type of oil do I use?
SAE 30 motor oil if the temperature is between 30 & 75°F.
-Colder use SAE 10 oil.
-Warmer use SAE 40 oil.
take a look on amazon: Amazon com SAE 30 motor oil
Apr 24, 2010 | Remington Electric Pole Saw
What kind of oil solution do I use in my remington chain pole saw
I recommend bar and chain oil (SAE 30 with additives to make it adhere) available at hardware stores and home centers.
From a Remington OM, page 9 (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F
  • Colder use SAE 10 oil.
  • Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
  • It is normal for oil to seep when saw is not in use.
  • Empty oil tank after each use to prevent seepage.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 30, 2010 | Remington Polesaw Wizard
I have pole saw model 108526-01 I need a new chain and a cap and bulb assembly where can I get these parts?
The good news is:
Your manual containing a parts list can be found here:
http://lawnandgarden.manualsonline.com/manuals/mfg/remington/100089-04_5.html
There is an IPL near the bottom, please save copy to your hard drive.
The part number for the oil cap & bulb assembly is 107319-02, I found it here:
http://www.remingtonpowertools.com/products.cgi?cat=11
I make no guarantees about availability. If you take the existing chain to a local chainsaw seller/mechanic they can almost certainly use it as a pattern to make a new chain
The bad news is:
Remington Power Tools have ceased production. Parts availability is limited to what is on hand. I recommend rather than purchase parts for this discontinued brand you put the funds toward the purchase of a new saw. Poulan offers 8 different electric models, have been in business for a very long time and are a subsidiary of Husqvarna. HTH
Lou
We can provide no further help for your saw.
Oct 08, 2009 | Remington Electric Pole Saw
Lost oil cap and bulb
Remmington's parts department.
Sep 14, 2009 | Remington Electric Pole Saw
Lubrication
The cap on top with the bulb, screws off. Use bar oil. Give the bulb a pump every 30 seconds of operation or so. This will keep your chain and bar lubricated.
Regards, --WoobieDog--
Jul 10, 2009 | Remington Electric Pole Saw
What kind of chain oil to use for a 10in remington electric
According to the manufacturer... "Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil." So, I suggest for any Remington electric chains saw not to use bar and chain oil. I hope this helps...
Jun 25, 2009 | Remington Electric Pole Saw
Remington Pole Saw Model # 106890-020 - Chain Oil Cap broke
Call Master Parts at 1-800-446-1446, or go online at www.masterparts.net. They have the part (107512-01) you need. I hope this helps...
Apr 26, 2009 | Remington Electric Pole Saw
I have the model 108526-01 Remington pole saw which has the round pole with a plastic compression nut (which recently broke). Can I buy the newer octagonal pole and if so, does it use the same saw mounting...
I have the sollution, had the same problem with the broken compression nut. Just use two hose clamps, one to hold the pole extended and the other clamps around compression base. Its a cheap easy fix and it work great fo me. The Real Mr.Fixit
Apr 03, 2009 | Remington Electric Pole Saw
Remington Pole Saw
LOOK UP ( PARTS FOR.COM ) FOR THE TRIGGER SWITCH
Jul 04, 2008 | Remington Polesaw Wizard
Remington Polesaw Wizard Logo
177 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
