I have a whirlpool washer. Model GVW9959KQ2. It starts out the in the wash cycle ok. Then it jumps from 25 minutes to 4 minutes on the wash cycle.
    Brigadier General:
  • 3,917 Answers
Hi
Most probably the timer is bad. Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
Let us know if you want something more else please accept the suggestion.
Thanks for contacting fixya.com
Posted on May 10, 2010
Whirlpool washer setting comes up with an 8 hour cycle, it used to be 47 minutes!
Hello Kim, we're sorry to hear about your Washer. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Washer. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 12, 2017 | Whirlpool Washing Machines
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
The digital timer skips 9 minutes out of the wash cycle. After starting the normal 140 degree wash cycle (46 minutes) the washer will start and wash normally until it has counted down to 41, then it...
hi shotgun - sometimes the mieles with auto adjustment functions do make changes to the wash time - usually based on a smart sensor technology.
Unfortunately I have no data or information for your particular model, I have info on earlier & the latest models only. In hindsight what this function does is adjust water levels based on the load weight or amount of the wash, the computer then calibrates the water levels and accordingly the amount of time to wash.
Eg - 4 kg load would be longer than say a load 1.5kg to process - if can understand this concept. However I cannot be 100% certain it applies to your particular model, if the user manual is availbel it may just pay to read thru in case it applies to the washer.
Jun 21, 2011 | Miele Super Novotronic W1986 Front Load...
I am just trying to figure out how many cubic feet my whirlpool calypso washer (model gvw9959kq2) is? Thank you.
The 3.5 cu ft Whirlpool GVW9959K is a unique washing machine that is Energy Star Qualified. It features the Calypso technology which helps prevent piling, shrinking and provides excellent stain removal. Save money and energy (up to $100 in utility bill savings) with this Energy Star Quiet Wash washer. The multiple cycles which include the hand washables cycle, the wool cycle, the bulky items cycle, give you the many options you need in determining the right cycle for your laundry. Automatic water level settings, multiple wash/spin speed combinations, 5 wash/rinse temperature combinations, and stainless steel wash basket with limited lifetime warranty are just some of the many reasons why this washer is the best choice for you. However the washer has a quirkiness also. They tend eat garments from time to time and take a dump when overdosed on detergent. The basket is suspended on four rods and is easily removed for servicing the motor and pump. The pump has a motor mounted on it. The whole time the washer is in motion water is continually poured over the clothes. It has a heck of a spin cycle at the end. Theory of operation, how to operate, repair and diagnose them fault does is HERE in the service manual.
Apr 06, 2011 | Washing Machines
Where can I get a User/Owners Manual for Whirlpool Washer, Calypso Model # GVW9959KQ2
My buddy Robert and me got into a couple of these washers; an older one and a newer one. I took some photos and included your manual HERE and HERE
Mar 07, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My whirlpool calypso washer just quit working no codes no power just dead. GVW9959KQ2
Won't Power Up
  • 120VAC electrical supply.
Check voltage supply to washer.
  • Open AC cord.
Check for voltage at the power cord connection to the line filter.
  • Line filter open.
Check voltage into and out of line filter.
  • Machine control board open.
With the washer off but connected to the AC outlet, measure the AC voltage between Pins 4 and 2 at connector P16.
Dec 23, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Whirlpool Calypso washing machine, model
communication error. changing the MCU. sometimes a bad pump could be the problem
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Mod: GVW9959KQ2, stops and shows "ob" as code for fast final spin. Also making high pitched whine during wash cycle. Appl svce place has suggested bearing or xmission. Any possible...
Sorry to say but they are right. The Calypso washer was a horible design given to whirlpool from maytag. I would suggest you go buy new machine. Buy someting that looks simple and easy to use. The more complicated the unit the more problems you will have down the road.
Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
When doing quick wash "25 minutes" why does it take an hour?
one think comes to mind if you have extra rinse selected un select it all preset cycle times arent based on extra rinse
Sep 05, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
