Question about U-Line Icemaker
Fan runs but compressor won't start - U-Line Icemaker
  • 11,896 Answers
Check to see if you have a relay there. It's a little black square box. They can go bad. You can test them with a relay on each part of the solder joint. Some of them can pull out so you can test them, but not all of them do that unfortuantely. I would test the relay. If you have a voltmeter, you can test the power going to the compressor to see if you have power. If you do, then compressor could be shot, if no power, then you could have a bad relay or another faulty component such as capacitor or resistor.
Posted on May 10, 2010
My ac fan works but the compressor won,t kick on
The fan on the condenser or air handler? Check the capacitor on the condenser. If you don't have a meter that does uf you can take the amp draws of the comp multiplied by 2650, divided by the voltage between com and herm on the cap. If cap is good be sure compressor is not off on thermal overload, cool with water hose, careful to not soak electrical. If not hot and cap good , try hard start kit. If still no compressor ,ohm compressor, com to start plus com to run should equal start to run on ohms. Hope this helps.
Apr 04, 2016 | Heating & Cooling
Why my A/C condenser fan won t stop running, dodge ram 2008
To clarify, the compressor and fan will run in defrost mode. The compressor and fan runs to dry out the air blowing onto the windshield.
Now if the condenser fan runs in "heat" you may have a problem with the fan relay or the main controller.
Sep 25, 2014 | 2008 Dodge Ram Pickup 1500
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
It freezes but won't stop
as long as the compressor is running on your freezer the longer the fan runs has to too cool the compressor . . .thermostat problem
Jan 11, 2013 | Boating
Fan won't run / won't cool
It may have a faulty compressor relay or overload, best to change both at the same time. It's either that or a bad compressor.
Jan 06, 2018 | Kenmore 73055 Air Conditioner
Motor hums but won't kick in
Hi simpsonruth1..
In the back of the compressor motor you will see a fan, remove the plastic cover to get to it..
Once you have the plastic cover removed and the fan exposed, plug the compressor in and spin the fan with your fingers...be quick as the fan could cut your fingers if you do not get them out of the way..
If the compressor starts working, then the start capacitor is bad on the compressor...if it does not run then you have motor troubles, either replace the motor or get it rewound.
Please take time to rate me
Sep 06, 2011 | Paasche 1/8 HP Diaphragm Compressor
Fedders 208/230 split system w/ dual cap , compresser runs but fan wont unless you give it a push , compresser won't restart if relay is hot
All kinds of stutt happens when you dont have a condensor fan motor. You need to change the run cap on the motor.
Aug 06, 2011 | Heating & Cooling
Compressor tries to start but won't ...odd odor when fan runs....approx 8 year old unit... will trip surge protect power strip, but not 20 amp circuit..
IT PROBABLY IS OUT OF FREON AND AS IT TRIES TO START DUE TO THE LACK OF REFRIGERANT AND OIL IN THE LINE IT SHUTS OFF OR IT COULD BE A BAD STARTING DEVICE ON THE COMPRESSOR THAT POPS THE POWER TRIP.
Aug 01, 2011 | Breezaire WKL 4000 Wine Cooler
U-Line Icemaker Logo
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
