Question about Thermos Gas Grill 4617222
My grill lights, but won't really heat up. I
My grill lights, but won't really heat up. I won't keep a flame. This is a new problem, the grill is several years old.
  • Thermos Master
  • 2,514 Answers
Try cleaning the burner and the orffice , check reg is giving right pressure
Posted on May 18, 2010
My new roadside coleman grill doesn't produce a flame. It heats but not enough to have a visible flame. I am using a 1lb. propane cilynder.
Flames are merely particulates that are heated enough to glow. If a fuel is burning cleanly there will be no visible flames.
Oct 16, 2013 | Coleman Roadtrip Grill LXE 9949-750
Just bought a new Jenn-Air grill and cant get the temp past 250. Any ideas what i am doing wrong?
First, check that all the gas lines and flame bars are clear of any 'things' or bugs. I had a similar problem with a Webber grill and found out my problem was with the gas bottle. The new Overflow Protection Valve required on LP bottles can closed off or severly slow the flow of gas when the bottle is full and the valve is opened quickly. It will let enough gas flow to light the grill but won't let the fire get high enough to heat the grill up. Turn all the valves off on the grill and gas bottle. Open the gas bottle valve slowly then turn on the grill burner and try lighting it. If the flame is still very low try again or you have to let it burn at the low level until the OPV float drops down and the valve doesn't impede the gas flow. The best way to avoid this in the future is to not fill the gas bottle to the top when you have it refilled. Just ask the LP attendent to not fill it all the way.
Jun 06, 2011 | Garden
Low Heat ? i have a brand new napoleon grills. paid a lot to get quality. I dont find it very performant. It seems there is heating problem. I read a lot about regulator reset. I tried it but im not...
Not sure what you're grilling, that would require 500 degrees or higher. Unless, you're really trying to char-broil and I do mean char. In any event, it may simply be the thermometer on the hood of your grill, reading incorrectly. Keep in mind, the thermometer is not reading the temp at the cooking grate surface, it's reading the air temperature when the hood is closed.
I do a lot of grilling, I do grill shows for local food stores and I love to grill. But, I have learned to never rely on what the grill thermometer says. I use an oven thermometer that sits off to the side, on top of my grill grates. When I compare the temp on the grill thermometer to the oven thermometer on the cooking grates, there will be a difference of 50 degrees. Now, certainly the temp will drop some, when the hood is opened after preheating. That's normal. But the heat loss, at cooking grate level, is not more than 10 degrees, depending on the outside ambient air temperature. Of course if it's the dead of Winter, the temperature will drop significantly. In that case, grill with the hood closed 90% of the time.
With all of the above said, what do the flames and flame heights look like on each burner? Do they respond as they should when you raise and lower the flames? If not, then you have a gas pressure problem. That can be resolved by turning OFF the tank valve, disconnect the hose from the tank and waiting 5 minutes. Then reconnect the hose to the tank and open the tank valve VERY, VERY, SLOWLY (slow motion, slow). Once the valve is fully open, light the burner farthest from the tank first and turn it to high. Do the flames look higher than they did previously? If so, light the remaining burners following the same procedure as the first burner. Do all the flame heights look correct. If so you solved the problem of low flame height.
I hope all of this has helped you troubleshoot and solve the problem, if there is one. Please let me know. Thanks and Happy Grilling!!
May 12, 2011 | Napoleon "Prestige I P450RBNSS" Gas Grill
I just purchased a brand new tank of propane and i still have the same problem that the propane burns out of all 4 burners but at a really low flame even on high. I can not get the grill to heat up...
Turn the tank off. Disconnect the grill hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the LP tank valve on VERY, VERY SLOWLY until it's fully open. Now, light each burner one at a time and turn it up to the highest setting. If that didn't solve the problem, repeat the previously listed steps.
If after the second attempt the burners still only maintain a low flame, you will need to replace the grill hose/regulator.
Hope this solved your problem and Happy Grilling!
Feb 27, 2011 | Brinkmann Charmglow Stainless Steel LP...
My kenmore elite grill has a ceramic cooking grid. it is 1 yr old.recently a problem developed. the ceramic grid lights as usual, but does not stay lit.once i let go of the knob the burner goes out. thanks...
check thermo coupling., its purpose is to keep heat at flame area-helps keep flame lit,like a pilot light... clean it with a finger nail file LIGHTLY- or use sand paper LIGHTLY, just to clean surface..
Nov 27, 2009 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Char Broil grill w/full tank and cleaned air jets, no heat
try opening the tank really slowly. if you open it too quickly the overfill protection devise in the tank will restrict the gas flow to the burners. hope this helps.
Sep 17, 2009 | Uniflame FG2204C Grill
KEEPING GRILL LIT
There is a safety device that shuts the gas off or nearly off if there is insufficient back pressure, such as can be caused by a leak. Check to insure that all of your new burners are properly seated.
Jul 02, 2009 | Weber Q Grill
Cannot get good flame on the burner of my baby weber grill. I've tried cleaning it checked hose, tank, regulator, seems to have good flow, but low flame only, even when set in high????????
I had this problem with a brand new grill so it wasn't grease in the hose. Due to the new propane regulators you have to turn the propane tank on for at least a minute before turning the grill to light. Let the tank sit in the light position for five seconds and then you light the grill. This will keep air from getting into the intake hose and will keep your gas flame roaring high.
I was only able to get the grill up to 250 degrees before I found this fix posted on the Weber site. It is listed as the number one solution in the FAQ section.
May 18, 2009 | Weber Baby Q Grill
Gas grill conversion
It's safe, but you need to keep in mind that propane burns hotter than natural gas, so you won't need to turn the burners up as high for the same heat. Here's an article that explains some of the differences (but doesn't really answer your question): http://bbq.about.com/od/gasgrills/a/aa030505a.htm
Bottom line -- it's safe if you don't leave it cranked up to high flame. Two-thirds flame on propane should give about the same heat as full burner on natural gas.
Of course, you could change the jets. That would compensate for all the differences between NG and propane, and you could run the grill on full high heat if you wanted to.
Aug 05, 2008 | Barbeques Galore Capt'n Cook 3-Burner...
Flame not hot
If the propane tank is full, it could be the pressure regulator. Some regulators have an adjustment screw on the top.
If it's REALLY cold outside, the propane may not be evaporating fast enough to keep the pressure up. Also on a cold or windy day, heat is drawn away from the grill very quickly, and it may be difficult to keep the temperature up inside.
(And Happy Grilling!)
Mar 31, 2008 | Vermont Casting The Extreme VCS5005BI...
Thermos Gas Grill 4617222 Logo
132 people viewed this question
Top Thermos Grilling Experts
paulcarew
jdthefixer
kc5133
Level 1 Expert
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
