Question about Microsoft Windows XP Home Edition
Power/screen saver Hi My screen saver sometimes comes on, some times not! I can go out for a few hours and find whatever I last looked at still on the screen! Other times I nip to the kitchen, com back and screen saver on! Most frustrating.
  • gwenisgreat Mar 30, 2008
    did you set up power setting right ? if do so happen when on line or is there a program running in the background or may have a intruder in your system go start ,cmd,netstat -a and see if there is a connection active -
    Hi I went to start, no cmd, so went to run; cmd - came up with black screen, typed in netstat -a, and it didn't recognise it.
  • 149 Answers
Did you set up power setting right ? if do so happen when on line or is there a program running in the background or may have a intruder in your system go start ,cmd,netstat -a and see if there is a connection active
Posted on Mar 30, 2008
Hi My Benq t52wa wide screen monitor works fine for some time and then its goes off for a few seconds and then comes back in regular intervels. This keeps on happening. Also im unable to get the auto...
First check-up the VGA cable of monitor to CPU, fix loose connection. also disable your screen saver and power option.
Click start>control panel>display>screen saver (choose none>click power option (turn off monitor (choose never then click Apply). then restart your computer.
Use and observe again.
Hope can help you.
Regards.
Jul 15, 2011 | Computers & Internet
There are marks on my LCD 42" TV ,its on the screen itself.It looks like water marks.It started of small marks and it then it getting bigger.
Things You'll Need:
  • Burn-In Reduction Screen Saver DVD
  • DVD Player
  1. Instructions
    • 1 Plug DVD player into your TV and power on. Make sure you plug the right component cables into their corresponding inputs on the back of the TV. This is usually done by simply matching the colors of ends of the cables with the colors of the input holes on the back of the TV.
    • 2 Turn TV to the proper input to display the DVD. Make sure there is not a DVD in the player.
    • 3 Place burn-in reduction screen saver DVD in the player. Allow a few seconds for the DVD to start playing. A pattern of white "video snow" will appear on your screen. The entire screen should be taken up with this patterm.
    • 4 Run the DVD for at least several hours; this will help wear the TVs phosphors evenly. Depending on how long the image has been burned into the screen, the amount of time you should play the DVD varies a lot. A good rule to follow would be to play the DVD at least four times the period the image has been displayed. If you have an image that has been on the screen two hours a day for a whole month, run the screen saver for at least 240 hours
Jan 17, 2011 | Televison & Video
My screen goes black, with green light still on. I have to turn off monitor and turn back on to get picture. However, in short while It will repeat the problem and go out, each time taking less time to go...
it seems like a fault with the power saver or economic mode whatever named on that set, try to disable that function to see if the issue is resolved or not.
Nov 19, 2017 | Hanns.G Corporation 27.5" Widescreen...
The battery on my brand new missil MP4 only last 20 minutes
Hi There,                Make sure you fully charge the device for 4 hours. On the setting on your device you should have a screen saver to shut off the screen display in a few second. Set this to saver battery time and set the auto off function if not in use for a long while to save more battery time. If your display screen stays on all the time that is the reason your battery dies so fast. Also playing your music loud for long period of time can drain the battery fast too.
Dec 29, 2008 | Network Computing Devices (NSH800S/A)...
Monitor won't stay on
Your computer may be in screen saver mode, it has instructed the monitor to go to power saving mode, or the the monitor's video cable is not properly connected to the computer. Another possible cause of this is a locked-up or in-operative computer since the computer is what supplies the monitor with all the display data or information. Move the mouse or press a key to de-activate the screen saver or power saving mode. Check the monitor's video cable and make sure it is snugly connected to the computer. To see if the computer is operating properly, press the CAPS LOCK key on the keyboard repeatedly while checking the CAPS LOCK light. If the light is not turning ON & OFF, the computer is non-functional. Contact your computer manufacturer for help.
Dec 02, 2008 | Computers & Internet
Does the mouse & keyboard turn off or sleep?
check your windows settings. They are in your power settings. You can adjust your computer to whatever you want.
right click on destop and goto properties, then click on screen savers tab.. see the power settting button now?? You should be able to tell it what to do for everything to do with Power.
Apr 06, 2008 | Logitech Cordless Desktop EX110
FLM 2601
We have the same problem and what worked for us (until now) is holding it in until it comes on. Used to be just a few minutes but now I prop a book next to it. Last time, I just left it on with a screen saver on my PC which worked until the power went out. I think it's a power supply issue.
Apr 04, 2008 | Polaroid FLM-2625 26 in. HD-Ready LCD...
Microsoft Windows XP Home Edition Logo
53 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
