Question about HP Photosmart 3210 Printer
Getting Error message:
I have a HP Photosmart 3210 Printer and am getting error message:
"Carriage jam. Open door, clear carriage jam, and them press OK to continue."
I opened all the doors I could. Can't seem to find what is jammed. No paper is stuck or anything like that. Won't print! Help.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • 53 Answers
Unplug the USB cable and the Power cable of the printer.
First of all make sure there is no paper pieces stuck inside the printer. Now ..!
Take out the Back door ( A door at the back of the printer which has two buttons at the ends of it which you can press to detach it from the printer )
from the back of the printer.
Once you take it out you can see the ROLLERS and the ROD which takes the printer page and rolls back to give you the out put.
Take a lint free cloth and clean the rod and rollers. Try to move the rollers in clock wise or anti clock wise direction. If it moves fine Other wise hardware issue.
Now attach the Back door back to the printer.
Now open the front door and move the carriage jam manually and check if it has any obstruction. If it has check if you can remove the abstruction if not and even then it is not moving smoothly. The printer has gone bad.
If it has no obstruction then follow this.
Now Reset the printer:-
To reset it.
Connect the printer power cord to the Wall Outlet or Wall Jack.
Make sure it is not connected to the Serge Protector or power strip.
Partial reset :-
Now on the printer itself. --> Press and hold the
# and 3 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 3 button the hold time )
(On the printer screen it should say part nvm reset.)
Now try to turn on the printer and check if it shows the carriage jam option. If it works perfect. If not then do this :-
Semi-Full Reset:-
Open the front door and take out all the cartridges from the printer.
Now close the door.
now clean all the cartridges using a lint free cloth and make sure you do not touch the nozzel of the printer.( nozzel :- from where the ink comes out ) while cleaning.
# and 6 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 6 button the hold time )
( On the printer screen it should say Semi-Full reset )
The printer might shut down automatically or may be it won't. At this point Put the cartridges back into the printer and then turn on the printer if it was shut down or If the printer is on turn it off and then switch it back on.
The problem should be resolved up till now.
If still the problem Exist Call HP as the product has gone bad.
HP :- 1-800-474-6836 ( Tech Support )
Posted on May 10, 2010
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My hp photosmart printer is saying Error carriage jam, open dorr clear carriage jam and then press Ok to continue. Which door should I open and how do I clear the carriage jam? Linda
Without any paper in the machine I would try powering off and powering on. Lifting the scanner lid will clear so the carrige goes back to the correct side of the printer. Even rebooting the printer and loading the software will sometimes cause the carriage to go back to where it was supposed to be.
Jan 16, 2010 | HP PhotoSmart C4180 All-in-One Color...
Carriage Jam
>follow the steps on this link to clear carriage jam on your printer
>please inform me if this has resolved your issue.thanks
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00243856&cc=us&lc=en&dlc=en&product=421139
Sep 29, 2009 | HP Photosmart 2610 All-In-One InkJet...
Carriage jam error
The Jam error is most likely cause by one or more of the sensor flags these are the plastic usually black things hanging along the paper path. One of those are either stuck or broken. Check the path and look for those items.
Feb 13, 2009 | HP Photosmart 3210 Printer
Carriage jam on HP Photosmart 3210 Printer
most likely the sensor on the paper path out of position, chech it out and put it back to where it have to be, good luck!
Dec 13, 2008 | HP Photosmart 3210 Printer
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
How do I get fix a "carriage jam"?
I was able to run run a piece of photo paper through a couple of times and printer now seems to be working again. The theory was that running a heavy piece of paper through might help clear little piece of paper that was not visible. The photo paper is less likely to tear if it gets jammed too.
Apr 18, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
Carriage jam
firstly open door of printer
and clean any soft cloth then start printig .if not solve problem then check belt of carriege motor and screww
Oct 26, 2007 | HP Photosmart 3210 Printer
HP Photosmart 3210 Printer Logo
146 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
