Question about Tech Solution TS-8000 Cross-Cut Shredder
It turns but does not shred
It runs but does not shred
  • 59 Answers
Hi i think broken gear inside to drive the shreder rollers
thanks
Posted on May 15, 2010
We have a Fellowes Powershred C0320C shredder which will does not take the material to be shredded except on one end and does not pull it in and shred it.
Try to use the reverse action of the shredder. This runs the shredder blades in reverse and sometime CLEARS the left over shredded material that can cause a malfunction. Careful...watch your fingers as the blades are sharp and they can injure you. Never place your hands or garments near the open blades when it is plugged in.
Check also that the small switch is free and clear of derbies. When the cutting gears are in place on the container box, the small actuator switch is free to turn on or off until the shredding box is full. Once the box is full of shredded material the switch will turn off (a safety provision) and you must empty the container before it will operated again.
Jan 12, 2018 | Fellowes Office Equipment & Supplies
My shredder won't shred
If the motor will not run, then probably there's paper clogged in the shredder. Turn over the shredder, after unplugging the power cord, and remove the papers.
If the motor will run but not shredding any paper, then the drive gear has broken teeth. This is not usually worth fixing.
Hope this helps.
Mar 27, 2015 | Shredder Office Equipment & Supplies
My shredder worked fine but now when I turn on it does not stop running and does not shred paper ?
Most shredders will have a shred and a reverse setting. Is it running in reverse? Has the bin been emptied? With the power off, you can remove the bin and manually pull excess shredded paper jammed in the cutting heads -watch out, sharp metal . Once cleared run single sheets for the first minute to help clear rollers.
Jan 05, 2015 | Shredder Office Equipment & Supplies
Anti jam light is on unit will not run
The "anti-jam" light actually is a jam light and it is notifying you that the shredder is jammed. If you turn off the power and examine the shredding unit you will find shreds of paper stuck in the mechanism. Removing all of the shreds will get your shredder back in operation and the anti-jam/jam indicator will be off
Apr 15, 2013 | Office Equipment & Supplies
Secure-Shred
Home paper shredders tend to accumulate bits of paper that have to be cleaned out from time to time. With power off, turn the shredding mechanism upside down and look for scraps or wadded up strips. Sometimes only tweezers and persistence will get rid of all.
Dec 18, 2012 | Shredder Secure Shred Shredder
My Fellowes ps-40 will not shred. The motor is
you have some shredded gears. i don't think fellows has replacement parts for their personal shredder line.
Nov 15, 2009 | Fellowes 3011001 Shredder
Staples SPL-X21G shredder won't turn off
Blow canned air down into the feed slot.
Sep 22, 2009 | Office Equipment & Supplies
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Shredding no more
if the unit is pulling paper thru but not shredding your cutters have separated for some reason. If not pulling paper thru but machine is running you probally have a broken gear causing cutters to no longer turn you may hear a clunking or grinding noise or gear may be stripped if shredder sounds like it is spinning freely. Contact manufacturer for parts availability.
Nov 26, 2007 | Royal CIA 12X Shredder
Tech Solution TS-8000 Cross-Cut Shredder Logo
108 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
