Question about Kenwood Car Audio & Video
Kenwood dnx7240bt radio problems Will not stay tuned in on FM, also the TMC is very erratic. I have to keep turning the ignition off & and on to the Live traffic symbol. I am using version 1.7.0 firmwar, this is up to date according to the Kenwood site. Have you any advice. Wammer G
  • 4 Answers
SOURCE: Very weird Radio Tuning Problem
This is a USA model and by default in the USA all FM stations end in an Odd number. This is completely normal. you can try holding preset 1 and 5 down while pressing the reset button on the unit and it may allow you to switch to a Europe style of tuning.
Posted on Oct 10, 2007
Eagleeyes
  • 199 Answers
SOURCE: JVC KD-PDR30 remote switch wire
hi sounds like theunit is faulty, you will need to have the unit repaired, or have the amp switched via the ignition this would be the cheapest option.
Regards
Mark
www.blueice-electronics.co.uk
Posted on Feb 25, 2008
  • 5 Answers
SOURCE: Kenwood Tuner Frequency Steps Problem
MichaelBlackDo you know where I can find the remote key combination to do the same with KDC-MP538U? (To transform it to the European system)
Thanks in advance!
Posted on Sep 09, 2008
  • 5 Answers
SOURCE: Kenwood KDC-MP335
I have a car stereo purchased from the US and I can’t pick up all radio stations in Europe/UK, what can I do?
If you have purchased a car stereo from the US you will find that it will not pick up many European radio stations. This is due to the fact that US radio frequency steps are different to here in Europe.
You may be able to set the tuner to European stations by following this procedure.
Press and hold down the SRC button to power down the unit completely.
While the unit is off press button 1 & 5 together, while momentarily pressing the SRC button.
If this does not work try the following proceedure;
Press and hold buttons 1 and 5 together, while momentarily pressing the reset button.
If this does not work then the unit is not designed to pick up European frequency steps.
Posted on Sep 16, 2008
  • 1114 Answers
SOURCE: when i turn the ignition off i lose all radio
The Yellow wire is 12volt battery constant on after- market receiver heads.
Posted on Aug 16, 2009
Testimonial: "THANK U SO MUCH THATS ALL I NEEDED TO KNOW!!!"
The tmc function of the satnav unit in my 2012 Ford Galaxy has stopped working.
this may be a function you have to pay for seperately & the service dept. may not know
Mar 03, 2014 | Ford Cars & Trucks
How can I program the kenwood kdc252u to turn on and off with the ignition? As of now the unit stays on after I turn the vehicle off, or stays off after I turn it on.
you have wires crossed or not hook up ignition switch for radio stereo power wire connects to cars ignition.stereo memory (yellow or orange wire) connects to constant power for radios memory(rad stations /clock)
Feb 26, 2014 | Kenwood KDC-252U
How do I set the FM radio stations on buttons 1 to 8
Try tuning to the station you want and then just keep the button pressed down on the preset you want to store it to until it saves
Jan 30, 2014 | Kenwood Kt-56 Stereo Synthesizer Tuner
My Kenwood Radio (New) for my boat doesn't tune properly on FM. For example, it only tunes to 94,1 or 94,3 but not to 94,2 It is just ,1 digit off the frequency on most stations. Tried it on manua
Kenwood receivers are usually tuned for their intended destination country, hence the frequency "stepping" of the tuners may differ between countries.
Was this receiver originally intended for your country's frequency? If yes, then contact Kenwood customer service for further advice.
If not, contact your local Kenwood service agent and ask whether the frequency stepping can be reprogrammed.
Feb 20, 2013 | Kenwood Car Audio & Video
Can i get it to start on channel 1 and not channel 9
You should be able to. It sounds like your radio is hooked up in a manner that disconnects it from ALL the power once the ignition is turned off. This causes the radio to return to channel 9 by default program when powered on again.
Try connecting the radio hotwire to the fusebox at the factory am/fm radio fuse junction (be sure the amps for the cb + the am/fm don't exceed the rating for the fuse). This should keep power supplied to the radio even with the engine off, and it should remain tuned to channel one every time you turn it on.
Oct 15, 2009 | Midland 77-099 CB Radio
HAVE A KENWOOD AMP MODEL KAC-9102D . iT KEEPS SHUTTING OFF WHEN i TURN THE RADIO LOUD. ANY SUGGESTIONS
either bad ohm load or over heat if the ohs on the speaker wires to the amp are lower than specified use in the manual it will act funny cause it is pusing harder than its meant to and if it gets too hot either bad location or bad amp you can try turning the gain down a little until the amp stays on constantly at high volume
May 18, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Stop kenwood KDC-mp239 loosing radio settings with ignition off
You have two power leads bringing battery power into the radio. One is switched off when the ignition is off and the other power lead is always on. That second one is the one you may have wired wrong. You need to check that one out to make sure it stays on when the key is turned off. Good luck.
Nov 11, 2008 | Car Audio & Video
Comunicating between different models, can it be done?
sometime your program is wrong... so plz go this website and u can get soft the prob :)
this website have sofware :) so nice man!
http://www.twowayradioearpieces.com/Programming-Cable-for-KENWOOD-C178-1.htm
Jun 13, 2008 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Car Audio & Video Logo
67 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
