Question about Apple iPod touch
Itouch speaker playing while headphones are connected.
My itouch speaker and headphones are playing at the same time.
    Guru:
  • 192 Answers
1> Disconnect the ear buds from the itouch
2> Reset the ipod - by holding down the sleep wake button and the home button at the same time until you see the apple logo - the ipod will reboot
3> reconnect ear buds mace sure they are flush with the top of the unit ( no gaps )
play a song to test
**If it is still playing out of both - call apple for repair or go to apple store
Posted on May 16, 2010
I want to play my music from my itouch on my Aiwa NSX-TR77 system (because of the speakers) but do not know how to, or if this is even possible to do so?
It is in fact possible... you can play whatever source to whatever sound system with the correct cable... you need a cable with at one end a headphone output connector (compatible with your Itouch) to an input of your choice on the Aiwa system... usually RCA input (RED & WHITE RCA type connectors) at the other end of the cable...
Cheers!
Aug 31, 2011 | Audio Players & Recorders
My zeppelin speaker is not connecting properly to my itouch. When docked, my Itouch plays music, but no sound from speaker & the remote will not operate my itouch. (it used to work fine).
if it charges, and there is no red flashing light, probably the board that feeds the arm, or the arm itelf, as different ipods have different connections. if the aux feed words it is the arm.
Jan 07, 2011 | B&W Bowers and Wilkins Zeppelin iPod Music...
IPhone will not play over speakers. As soon as plugged in it says no volume available on iPhone. I'm pushing play/pause button and is on iPhone source
Usually the iPhone only supports certain headphone jacks into its system. When some devices are connected to the iPhone the iPhone does not produce sound because it does not support the device on the other end. The iPhone unlike the iTouch is sensitive to the kind of device which it is connected to most of the time.
Hope this explains the problem?
Jan 01, 2011 | Audio Players & Recorders
Headphone jack must be moved around to get right speaker working
You will find that sound comes from the right side speaker only when it is bent at a certain point. By trial and error you can roughly locate the point. Then you can cut the wire at that point, cut 1 inch each from both ends, strip the cables, and connect the conductors. What has happened is, due to unusual bending, the conductors to the right-side speaker has damaged (broken). After roughly locating the place and removing 1 additional inch each, you will remove the wire section with the broken terminal. Now you can strip the wires and make the connections again. If you are not good at stripping and soldering wires, better to to take it to an electrician. (You need to take only the headphone pin and parts attached to it). This repair won't cost much. Good luck!
Jun 25, 2009 | Logitech Z-2300 Computer Speakers
ITouch 2nd g only plays music throuhg left side of all headphones
Try playing with the headphone plug, until you can also hear the right
channel and also try a different set of headphones as it is probably a
matter of an intermittent headphone jack, or plug, owing to sudden
snatching of the headphone plug from same, a very common problem.
Eliminate this cause before submitting your Touch for much more
expensive remedies
Apr 16, 2009 | Apple iPod touch
Itouch does not play through fm transmitter
i had the same problem... like it played through the itouch speakers and not through the radio how do i get it to play through the radio
Apr 07, 2009 | Griffin Technology iTrip Auto FM...
Docked itouch emits song, but nothing through logitech speakers
Talked to both Apple and Logitech, and uploaded newest firmware ( had assumed since this was a recent purchase it had same), presto, it works.
Jan 29, 2009 | Apple iPod touch
Itouch volume realy messed up! plz help!
and you are sure the volume is all the way up? If the headphone jack thinks there is something in there the ipod touch will only play through the headphones. you can try to blow out any dust in there with a can of air and that might solve your problem.
Jan 27, 2009 | Apple iPod touch
Apple i touch 8 gb speaker not working
maybe u have the 1st gen itouch. the 1st gen itouch doesnt havent speakers. Your friend probably have 2sec gen which has speakers. If u look at each other's itouch carefully, u'll notice a slight difference near the edges. your friend's itouch's edge is probably curved like in the 2sec gen one while urs probably isnt.
This answer is my best shot at helping ya. Good Luck!
Shocker2cool
Jan 09, 2009 | Olympus Camedia D-425 / C-170 Digital...
Itouch charging
Some speaker systems which are only compatible for charging the ipod nanos and classics do not work with the iPod Touch and the iPhone, the internals are slighly different from one another which will not allow that speaker system to charge your iTouch.
To play & Charge your touch, i suggest getting a speaker system that supports the iPod touch platform.
Hope this helps ?!
Oct 28, 2008 | Apple iPod touch
Apple iPod touch Logo
161 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
