Does my TV Samsung L40M86BDXIXEU has a HDCP compliant HDMI port? It seems that without it I cannot watch blu-ray discs from my laptop.
  • 736 Answers
Yes your tv is hdcp compliant.
This may not help but often when this message comes up it is the hdmi cable you are using. I do not know whether or not you are using an hdmi to dvi cable or an adaptor or and hdmi to hdmi connection. The cables available for purchase at beachaudio.com are not expensive but they usually work when you need to try another hdmi cable because of this particular message.
Posted on May 10, 2010
Testimonial: "Tanx a zillion. Got the answer (simple and clear) the very same day. "
I have a 2009 Lg 37lh30 Tv and for the most part it works until recently. I am now getting a HDCP rejection when using an Apple tv or Roku and no screen when using my bluRay Player (which use to work
Some TV's & cables are not HDCP compliant . Sometimes you can replace the cable to fix the problem & other times you have to replace the tv because its not HDCP compliant . First check to see if your tv is HDCP compliant .
Jan 03, 2015 | LG 37LH30 37 in. LCD HDTV
I have a Samsung C230 LED monitor and I'm wondering if I can use it with a Roku XD/S in place of a TV via the hdmi cable?
as far as i can tell this monitor is not HDCP compliant ( High Def Copy Protection ) and therefore will not be suitable as a TV monitor. Computers can use non HDCP compliant monitors but TV Tuners, Satellite Receivers, DVD players etc with HDMI are HDCP compliant and must have a HDCP display... HDMI has two formats basically HDCP and non HDCP
Sep 04, 2013 | Samsung Syncmaster 940BW LCD Monitor
Hdcp error mesage when connected to my freeview hd box.
What is a HDCP error? Here is a real life situation that happened that could happen to you. You just bought a Blu-ray Disc Player and connected it to your older HDTV with a HDMI cable. When you tried playing a Blu-ray disc a HDCP error was shown on the screen. The movie wouldn't play.
This is a known issue with HDCP, and it's one of the biggest hassles consumers will have to deal with when utilizing a HDMI cable on their HDTV. You will get a HDCP error if you try watching HDCP encoded content when using a HDMI cable.
The problem is that if HDCP exists anywhere in the video stream then all devices and cables accessing this content must be HDCP compliant. If one device or cable isn't HDCP compliant then you get a HDCP error.
The only solution is to either replace the HDMI cable with a non-digital cable or replace the HDCP-less device. This could mean buying a new HDTV. In fact, I worked with a reader last year troubleshooting a HDCP error on his TV. What happened is that he bought a Blu-ray Disc Player and connected everything properly only to get a HDCP error. After a few emails back and forth we discovered that his HDTV wasn't HDCP compatible, which is why he got the HDCP error.
The reader ended up buying a newer HDTV with HDCP, and his Blu-ray Disc Player worked perfectly with HDMI cables.
Nov 22, 2010 | Televison & Video
I have a VL470M and am trying to connect a LGBD570 Blu-Ray through HDMI. It works fine through the composite input, but the HDMI says "no signal". Am I doing something wrong?
There are two possible issues. 1) The resolutions are mismatched. (output of the player and input of the TV) 2) the player can not confirm that the TV supports HDCP over the HDMI connection. Only 3 of the 4 HDMI ports are HDCP (high def copy protection) compatible.
Try a different HDMI port and make sure that you have the input set to the correct HDMI port. (There is an input button on the side of the TV as well as on the remote.)
The easiest things to check are turn off the Blu-Ray player and then turn it on again. Then press the Home button and navigate to the Setup Menu. Select Display and press the right arrow button, then select Resolution and press Enter. Then set the desired resolution and press Enter to confirm the selection. (Your TV should support 1080p from the Blu-ray player.) Then turn off the player since changing the resolution can lead to video issues.
I hope this helps.
(the manuals for the TV and the blu-ray player are available on line: http://www.vizio.com/vl470m.html and http://www.lg.com/us/tv-audio-video/video/LG-blu-ray-dvd-player-BD570.jsp Click on Support on either site.
Nov 13, 2010 | Televison & Video
Panasonic PT-AE2000U All three HDMI Ports stoped working. I have tried different HDMI cable and a three different HDMI Feeds. I can get a picture using the red green blue component cable. Any ideas?
WOW. I just experienced the same thing. None of my HDMI ports are working, though component is fine. I've had my unit since November 2007 and had no problems until this. I think the HDMI board has gone bad and will require replacing.
May 20, 2010 | Panasonic PT-AE2000U Projector
Will not play movie - continually displays "Copyrighted Movie HDMI HDCP frail with TV "
There are several reasons for this but exactly knowing which is one isn't possible without first knowing what products you are using such as your connector, player and television.
HDCP is the acronym for high definition content protection. It is a digital signature embedded into the disc software designed to prevent copying of the disc. On certain occasions due to the hardware such as the HDMI port on the television, or the connection type, the signal will not be allowed to pass through. The HDMI port on the television may not be HDCP compliant for example. In this case if possible you can try a different HDMI input on the TV if available or use the component video input instead.
Jan 09, 2010 | LG DR787T DVD Recorder
Blu-ray player won't play through hdmi with yamaha reciever
The problem is some intermediate connections do not allow the HDCP signal to reach the telivison. Electronic HDMI switches have this issue. I have one HDMI port on my Telivision and I have a Blu-ray player & HD satellite reciever. I had purchased a two in one electronic switch and found that the satellite reciever signal would make it to the tv and was working but the blu-ray player was not. I had to by a passive push button switch and it allows the HDCP signal thru. The funny thing is the electronic switch was supposed to be HDCP compliant and it still did not work.
Sep 06, 2009 | Yamaha Audio Players & Recorders
Blue-ray Player HDMI jack to existing TV DVI-HDTV connector
Unless your TV is HDCP compliant (sorry, don't have to research this for you), you may not be able to watch Blu-Ray movies from your Blue-Ray player in 1080p. So first find out if your TV can do HDCP via the DVI port (i doubt it). If it can, you can get an HDMI-to-DVI adapter (you can find them real cheap off Amazon.com)
-Eddie V.
Dec 31, 2008 | Denon AVR-485 Receiver
Help for a friend; ln-s4095d, hdmi and blu-ray.. no picture
email141.
I had the exactr same problem with P#3 and the same model of TV, I turned of the 24 hz setting as you suggested and it si workign great! The only thing I am wondering is what ewxactly the 24 Hz setting is. The actual title is "BD 108P 24 HZ output. I didn't turn off 1080P did I? Don't think so as picture looks great. Even though I didn't ask the original question I REALLY appreciate the answer!
Dec 24, 2007 | Samsung LN-S4095D 40 in. LCD HDTV
You may want to try a good, Monster Cable, HDMI cable. Visit this page: http://www.monstercable.com/HDMI/advancedhdmi.asp
If you have a standard HDMI cable, it will not support 1080P.
So this is one of the few times that I will recommend spending the money for a better cable.
The better cable improves picture color quality, from 8 bit to 12 bit and it improves audio quality.
Dec 24, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
Televison & Video Logo
421 people viewed this question
Top Televison & Video Experts
Electro Med Services...
