Question about Dell 3000cn Color Laser Printer
Dell Color laser printer - 3010cn
I am having a problem trying to get my printer to print. The machine is powered up and the diagnostic on the front says 'ready to print'
However, it will not print and upon clicking the printer icon on the tool bar
the message under the status column says 'power off'
Can anybody help with my problem,please?
  • 871 Answers
Try to manually trouble shoot the connections of your printer and your pc. if not, follow Ekse ' s advice to reset the device and settings to start from scratch.
Having a diagnostic which says ready to print and printer icon that says printer is off, the connection is the first thing that comes into my mind. kindly jump from 1 usb slot to another. this may also help fix your issue.
Posted on Mar 29, 2008
  • Dell Master
  • 13,434 Answers
Try reseting the device, and its settings.
SOURCE:
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Apr 10, 2013 | Dell 3010cn Laser Printer
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
Problem printing with Dell 3010cn Laser
Check for damage to the fuser located right were the paper exits. damaged fuser can cause lines
Feb 10, 2009 | Dell 3110cn Laser Printer
Dell 3010CN Color Laser Printer is leaving vertical smudge/bleeding. Is there a toner dump box to empty? It is just cyan streaking.
Try a new Cyan toner cartridge. If nogo, will need a new transfer roller or transfer belt (I used to work on these printers but forgot if they use a belt or not... I will check on the DCSE site and post back)
Jan 05, 2009 | Dell 3010cn Laser Printer
Streak in color printing only
Try this page from the Dell Community Support Forum. <a href="http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=26221&query.id=335768#M2622" target="_blank">Click Here</a>
Aug 22, 2008 | Dell 3010cn Laser Printer
Dell 3010cn Color Laser Printing Quality
yes..it's almost certainly the drum..did you get a new one or was it simply refurbished?
Aug 20, 2008 | Dell 3100cn Laser Printer
Printer
Firstly, BE SURE TO USE LASER PRINTER TRANSPARANCIES. The cheaper inkjet kind will melt in the fuser.
Then, in all 3: driver, software program and on the printer itself using the front panel, change the paper type to transparency.
Good luck.
Jul 15, 2008 | Dell 3010cn Laser Printer
Streaking
Replace toner cartridge . Must be originals
Jun 17, 2008 | Dell 3010cn Laser Printer
Dell 3000cn Color Laser Printer Logo
117 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
