Question about Kenmore Washing Machines
I have a Kenmore Elite HE front loader washer. Model #- 11045088400, Serial#=CSS3011498. At the end of a cycle the machine stops and the message panel flashes F2. The machine is not spinning at the end of the cycle. What does F2 mean and is there anything I can do to fix it? Thank you, Necole
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on May 10, 2010
Kenmore Elite washer - control light is on and ii cannot do anything? Please help how do i unlock this feature??
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 29, 2010 | Kenmore Elite 45986 Front Load Washer
Tip
Kenmore Elite & Whirlpool Duet Washer and Dryer Control Panel Locked
Hopefully, this simple advice will save you an expensive service call.
on Jun 27, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite smartwash and the machine says contols locked, is there any way to reset that?
Sep 25, 2010 | Kenmore Elite 45986 Front Load Washer
It says "Control Locked".
Sep 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Elite 45986 Front Load Washer: HI My lchild lock was activated on my kenmore elit...
May 17, 2010 | Kenmore Elite 45986 Front Load Washer
Bellow for Kenmore Elite front-loader washer
The Bellow should be available at a appliance part store. be sure to call with the model number and serial number, that way if they don't have it they will have time to order it.
Apr 12, 2010 | Kenmore Elite 45986 Front Load Washer
Why the control locked is on , i have a kenmore elite HE 4t washer can't do nothing to make it go away so won't let me make a wash
Mar 10, 2010 | Kenmore Elite 45986 Front Load Washer
My washingmacine stopped working completely. it started with one cycle going out , then a week later another cycle stopped working. now none work. when i turn the machine on i can here a hum , but nothing...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.))))
Feb 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washer 110.45981 400
Hold down 'end of cycle' for 3 seconds. Power shd be on.
Feb 09, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
48 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
