Question about Hitachi P50H401 50 in. Plasma HDTV
My hitachi hdtv suddenly stopped receiving hdtv channels over the air. it received them for about 2 months them stopped . the signal strength for the digital channel is usually arround 75-78. i receive the channels over the air.
  • Anonymous Mar 25, 2009
    I have a Mitsubishi WD-52725 HDTV that worked fine and received all the digital channels in my area (San Diego, CA.) after I rescanned the after the transition with a $20 set of rabbit ears. Last week I lost all digital reception and tried rescanning with no success. I bought a new $50 hdtv antenna but nothing changed I get only some analog channels that haven't converted yet or channels from Mexico. Any ideas as to why I lost digital reception?
    Problem Solver:
  • 11 Answers
Have you checked your aerial is connected? It may be necessary to do a manual re-scan. Make sure you choose the option to 'replace' current channels.
Posted on Mar 28, 2008
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See or for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
Sep 06, 2011 | Hitachi 65F59 65" HDTV
I bought HDTV/UHF/VHF/FM INDOOR PASSIVE ANTENNA please help me to install it it is not working
Is the antenna the correct one for your environment? Do you have the antenna pointed at the stations you want to receive? Use or to get an idea of the location and likely channels you can receive at your location. Antennaweb assumes an outdoor antenna but is very conservative in the list of channels you can receive. (These may match the limits of the indoor antenna.) TVfool lists the stations and the appropriate antenna that will likely receive each station.
Tall trees and buildings will block the signal. Get the antenna as high as possible. Move the rabbit ears and UHF loop to maximize your signal strength. Then make sure the TV is set to use the OTA tuner (ATSC for digtal stations). (That may mean changing the source in the setup menu.)
Then scan for channels. Move your antenna or parts of it and rescan or edit the channel list. (For some TVs there is a weak signal setup option that will let you manually enter the station number (including sub-channel). Then it will provide the signal strength information as you move your antenna.)
I hope this helps. An amplifier may help you bring in weak stations with enough signal strength for the tv to see them.
Jan 19, 2011 | Philips Televison & Video
I would like to know if the Hitachi 51UWX20B television can be connected to the internet.
Your Hitachi 51UWX20B is an HDTV-Ready TV. No Digital Tuner. HDTV-Ready means that your TV set is capable of displaying analog and high-definition digital pictures, but without a digital tuner, it cannot receive the digital signal. An HDTV-Ready requires an external high-definition TV receiver (digital tuner) in order to receive HDTV signals. These external receivers can be called an HDTV Tuner, set-top-box, decoder or DTV Converter Box . So you will be required to purchase a converter box to receive over the air programming from an external antenna.
Jul 03, 2010 | Hitachi 51UWX20B 51" Rear Projection...
Digital Channels??
Direct from the Hitachi website - "Integrated HDTV Tuners: Hitachi's new top-of-the-line XWX series features built-in ATSC terrestrial and cable HDTV tuners to provide integrated high resolution, high-definition signal decoding." You will need a seperate HDTV tuner if you do not have cable or satellite and want to watch off-air High Definition channels.
Apr 30, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Dish Vip211K receiver locks up on one channel
yes your signal is very good but it hangs up, the most important is the quality of your picture, cause signal is composed of so many impurities including noise, so dish be orientated once more.thanks.
Mar 27, 2009 | DISH Network ViP 211 DTV Receiver
Very odd tv problem
Digital receivers whether external to the TV (converter box, satellite) or built in are digital processors(computers). Just like computers there are times when they freeze up. This can happen if the data stream is corrupted too much to render the picture, but enough signal to lock. The processor attempts to "wait" long enough to gather enough information to begin. Just like computers, these need to be re-booted by turning on or off and sometimes unplugged and plugged in. You have either too low of signal quality or too high of signal strength, which is a problem with digital receivers.
Mar 03, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Media Center can't find digital TV channels for TV Wonder HD 600
Just to make sure, you do have analog tuners setup right?  Media Center 2005 requires analog tuners be working before digital tuners are allowed.
Oct 11, 2008 | ATI TV Wonder HD 600 PCI PC TV Tuner...
Hitachi P50H401 50 in. Plasma HDTV Logo
153 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
