Question about Uniden BC340CRS Base Scanner
Clearing memory i have the 340 scanner and it say to hold 2,9, and hold when turning it back on to clear and that doesn;t work. any other way to clear the memory?
  • jim1175 May 23, 2008
    HAVING SAME PROBLEM WHEN i PRESS 2 9 HOLD SCANNER WON'T TURN ON AT ALL TO CLEAR THE MEMORY THIS MACHINE IS BOUGHT 3 WEEKS AGO
  • Anonymous Jan 06, 2009
    yes I have the very nsame problem with this scanner from day one!
    my nane is
    RONNIE V CROWELL
    1313 SOUTH VAN NESS AVE
    LOS ANGELES ,CA 90019
    PHONE 323 730 8019
    EMAIL / [email protected]
    and this scanner is brand new, can I GET MY MONEY BACK PLEASE, OR GIVE ME A BETTER SCANNER!!!
  • 3 Answers
WELL, After a year I alone, without any help from UNIDEN, FIGURED IT OUT.
1. TURN IT OFF, UNPLUG AC JACK IN THE BACK!
2. REMOVE Backup battery cover "underneath" scanner! TAKE ALL 3 BATTERIES OUT.
3. I PUSHED THE POWER BUTTON TO BLEED ANYTHING OFF IN THE CAPACITORS, IF IT HAS ANY INSIDE?
4. PUSH THE"2", "9", AND "HOLD BUTTONS DOWN, THEN PLUG THE A.C. BACK IN ON THE BACK OF THE SCANNER.
5.You WILL notice while you are doing STEP#4 THAT THE DISPLAY SAY'S "CLEAR". ALL FREQUENCIES WILL BE CLEARED IN THE MEMORY!! THEN TURN Scanner OFF reinstall the BATTERIES, TURN BACK ON AND START PROGRAMMING!! THIS WAS FOR A "BC340CRS" SCANNER
Posted on Feb 24, 2009
SOURCE:
How do you reprogram a Uniden Bearcat BC 340 CRS
Uniden BC340CRS Owner Manual
Resetting the Scanner (Clearing all Memories)
To reset the scanner to factory defaults, turn off the scanner. Then, while holding down 2, 9, and HOLD, turn on the scanner. All scanner memory contents are erased.
May 14, 2016 | Uniden Radio Communications
How to reset my Uniden BC75XLT Bearcat Scanner .
If the scanner's display locks up or stops operating properly,
you might need to reset the scanner.
CAUTION: This procedure clears all the information
you have stored in the scanner. Before you reset
the scanner, try turning it off and back on to see if
it begins working properly. Reset the scanner only
when you are sure it is not working properly.
1. Turn off the scanner.
2. While holding down 2, 9, and Hold, turn on the scanner.
It takes about 3 seconds to initialize and CLEAr appears.
Jul 08, 2014 | Uniden Bearcat BC75XLT Police Scanner
How to clear programming on bc370crs
The above is from page 36 of the manual.
Jun 12, 2012 | Uniden BC370CRS Base Scanner
I need to know how to clear and format to new out of the box it is a MC3090 motorola Symbol because it doesn't have enough memory and it doesn't save many codes thank you
1. Press and simultaneously hold the 1, 9 and Power keys. Do not hold down any other keys or buttons. As the mobile computer
initializes, the Symbol splash window appears for about a minute.
2. Calibrate the touch screen. See Calibration Screen to calibrate the mobile computer screen.
Hope this helps,
Ben
Sep 12, 2011 | Computers & Internet
HOW DO YOU RESET IT?
Hi!
From your owner's manual (Page 27)
Here's the link to your manual as well:
http://www.uniden.com/pdf/BC340CRSom.pdf
Hope this helps.
Sep 12, 2010 | Uniden BC340CRS Base Scanner
My Radioshack Pro-82 Scanner is stuck. I turned it on, held down the "lock" button until the keypad locked. The screen didn't display the "locked" symbol, but I can't use the keypad either. Even if I try...
First reset the scanner. This will not remove frequencies from memory. Turn the scanner off and then on again. Use a straightened our paper clip to gently push the "Reset" button on the side of the case (small hole). If that doesn't work, the next thing to do is to reinitilize the radio. This blows everything away so its the last resort. If you have the cable adapter and CD ROM for the radio, you may still be able to back up the scanner and reload after you do this. If not, be prepared to reprogram.
Turn the radio off and back on again. Hold down the "Tune/Clear button and again push the reset button. The display should clear. When the display returns, release the "Tune/Clear button
Now reprogram.
Aug 16, 2010 | Radio Shack Pro-82 Scanner
How to clear all my frequencies from my portable scanner
To clear all information that you've programmed into the scanner you can perform a RESET to original factory settings:
2. While holding down the 2 and 9 keys, turn on the
scanner. CLEAR flashes for about 5 seconds as
the scanner clears its memory.
Note: Do not turn off the scanner again until CLEAR
stops flashing. Otherwise, the scanner might not clear its memory properly.
Bill B
Apr 03, 2010 | Radio Shack Pro-94 Scanner
Radio Shack Pro-94
No telling what he did, but if you've tried deleting his entries and the scanner is still locked up, you'll need to reset it. This procedure will clear all the information you have have stored in the scanner.
1. Turn the scanner OFF.
2. While holding down the 2 and 9 keys, turn the scanner ON. CLEAR will flash for about 5 seconds while the scanner clears its memory.
NOTE: Do not turn the scanner OFF until CLEAR stops flashing.
Need the operating manual for your scanner? You can download;/print it here:
http://support.radioshack.com/support_electronics/doc61/61426.pdf
Bill B
Feb 17, 2010 | Radio Shack Pro-94 Scanner
Scanner says WIRED when i turn it on, and it won't do anything
A RESET may clear the problem, but it will also erase all frequencies and data that you've programmed into the scanner. To RESET the PRO-94,
- Turn the scanner OFF
- While holding the 2 and 9 keys down, turn the scanner ON. CLEAR will flash for about 5 seconds as the scanner clears its memory and restores factory settings. Do NOT turn the scanner OFF until CLEAR stops flashing.
Bill B
Jan 22, 2010 | Radio Shack Pro-94 Scanner
Uniden BC340CRS Base Scanner Logo
642 people viewed this question
Top Uniden Radio Communications Experts
Jason
Robert McClure
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
