Question about Tecnik TKC8525 Double Oven
No control markings TKC8525/2
I have moved into a house with a TKC8525/2 & there are no markings around any of the dials for temp control - what can I do?
I have moved into a house with a TCK8525 double oven and all the control information is missing from the dials, there isnt a manual either. How can I get a picture of the dials?
Gaynor,
That number does not come up in my search as a good number. What brand of oven is this and can you look to find either a different number or a complete number for the model #?
Jun 10, 2015 | Ovens
Temperature setting
try cleaning if that does not work you need to go for replacement .......
no other way........
regarding skills you should be very careful and taking all precautionary steps before cleaning.......
Oct 23, 2008 | Neff B1691 Single circotherm super...
Ariston tc720 dials have rubbed off
We had the same problem when our cleaner rubbed off the markings. Ariston "customer services" were very unhelpful (the model is now so old they don't offer any replacement facias for it) but managed to get replacement stickers from Mark at
http://www.ovenlettering.co.uk/. They come with a diagram for all four dials showing where they should go and are very easy to apply. Would highly recommend.
Jan 19, 2014 | Ariston Technologies Ariston FO98P...
Our ARG7302WW range is missing the temperature sticker for the dial...where should 350 degrees be and does it go up in temp clockwise?
Hello- The background panel is screened with gradients, but is expensive and hard to find. The easiest solution is to purchase an oven thermometer and allow to set for about 20 min at an indicated 350deg. Make sure that dial knob is tight and mark with a line at that point. Use a fine point sharpy, and clean surface before marking. Turn off, let cool, and turn to the new 350 mark and see if temp comes up and matches 350deg on thermometer. If it works ok, try marking 325, 375, 400, etc. ---Yes,  Clockwise is up in temp. Let me know if this info helps.   Have more if needed-  Thanks - Ed
Mar 16, 2010 | Ovens
Dials of our smeg oven have rubbed off
You need to disclose the model for any help.
Mar 06, 2017 | Smeg Ovens
Pizza, banana bread, etc. doesn't get done in the middle.
some oven temperature dials are adjustable by pulling knob off,turning a bit and pushing it back on in a different position.use an oven thermometer to determine the accuracy of your control knob.adjust knob or make note of difference between dial setting & thermometer reading.i.e.knob is at 350* thermometer says 300* set knob to 400* to achieve an oven temp of 350. could you E-mail me a slice of banna bread?
Sep 27, 2009 | Ovens
Vulcan convection oven has pilot lit and fan blows but no ignition. The schematic is too small, grease smeared and partly ripped to be of use. Is a schematic available or is the cause obvious to an...
The list of problems is as long as the one Obama inherited when he took over. Good news though, the most expensive part works, the blower motor! The pilot is established which rules out a gas issue. The two most common problems are, either the temp controller or the infinate switch is bad. Your unit has one or the other but, not both. Controller has several wires leading to it & has a green or tan circuit board on it, infinate switch is a small black or white 2 inch square box with 4 or 5 wires leading to it. Each one of these are mounted thru the front control panel & both have knobs. Temp board around $180, infinate switch around $45. As far as the schematic is concerned, Vulcan was bought by Hobart & they DO NOT give out schematics or service manuals.
Jul 10, 2009 | Vulcan Convection Oven - VC44EC-208-1
Tecnik TKC8525 Double Oven Logo
Top Tecnik Ovens Experts
ashburton
Timllfixit
Are you a Tecnik Oven Expert? Answer questions, earn points and help others
