Question about Pool & Spa
The collar cracked over the winter on my purex triton tagelus ta 50/500 pool pump. When I turn the top handle to backwash, water leaks out where above the top of the tank but under handle. What parts do I need to replace and where can I get them?
drifter2600
  • 3 Answers
SOURCE: sand in backwash
You need to replace the seal in the head unit of the filter.. The sand should be replaced every three years or buy a cleaning solution.
Posted on Jun 18, 2009
  • 2976 Answers
SOURCE: water dripping out of backwash port when handle is on filter
You might have it overfilled with sand. It's getting into the seats of the valves.
Posted on Jun 20, 2009
  • 93 Answers
SOURCE: sand in above ground pool
what type of sand make sure its for pools should only have 2 bags max in filter
Posted on Jul 25, 2009
  • 93 Answers
SOURCE: hayward filter problem
YOUR HANDLE IS NOT SEATING IN THE RIGHT POSITION THERE IS A SPROCKET UNDER HANDLE THAT MAY BE DAMAGED TRYSETTING HANDLE TO DIFFERENT POSITIONS SEVERAL TIMES IT MAY HAVE DEBRIS UNDER IT MAKE SURE PUMP IS OFF.TAKE HANDLE ASSEMBLY OFF AND CHECK SPOCKET
Posted on Aug 06, 2009
SOURCE: air in filter on hayward above ground pool.
This is common the first 30-60 seconds after turning the filter on. The filter is purging its self of the air, sometimes algae or small debris will shoot back into the pool as well.
If it is constantly getting air then replace your o-ring on the that clear cover (Strainer Cover) make sure you use a lubricant, and like djtc66 said re-wrap all threaded areas with teflon tape.
Posted on Sep 04, 2009
Old triton pool sand filter....2 orange valves.. What is the position for filtering and backwashing?
orange valves are for the returns the backwash is the skinny rod with the black handle check flow of pool I think up is backwash down is filter
Sep 09, 2015 | Pool & Spa
Pentair tagelus t60d filter filtering algae back into pool
Have you backwashed the unit? That would clean out remaining algae.
Jun 18, 2014 | Pentair Tagelus TA 60D Filter
Just had the spider gasket replaced and now water is "gushing" out the handle
Hi Shari,
I see two possibilities. 1. The diverter shaft o-rings are not sized correctly (or missing). 2. When valve handle was reinstalled it was not oriented properly with the diverter position in valve body.
Hope this helps you.
Jun 14, 2014 | Hayward SAND FILTER, PRO SERIES
Not filtering
too many chemicals will cloud contact the company website or did you maybe its the water change the water
Feb 28, 2017 | Pentair Tagelus TA 60D Filter
Triton Purex minimax 400
dan i belive you have a faulty thermastat switch
Apr 01, 2012 | Pentair MiniMax CH Natural Gas Pool...
Can't get my creepy crawler to work in my pool, i have a purex triton filter system, i can't get any suction on from the crawler
It sounds like your automatic pool cleaner might have a leak that is causing the pump to lose its prime. Check the hose to make sure that there are no leaks or cracks. Check the vacuum connection. It should be submerged so no air enters the system. Look and check the pump basket lid for looseness, cracks, and worn or missing O-rings.
Feb 26, 2011 | Universal Kreepy Krauly In-Ground Pool...
I have an older pool, and it has a purex triton whisper flo pool pump and don't know how to back wash. I am not seeing anything that says backwask or a lever to turn. I need to back wash because my...
You can not backwash a catridge filter. If cleaning them doesn't work they need to be replaced. A common 'issue' with cartridge filters - replacing the expensive elements every few years. There is no other way to clean them that will not in turn destroy the filter material in the process so new ones are your only choice.
John
Jan 14, 2011 | Pentair Plumbing
Pool & Spa Logo
54 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
